Hello All;
I searched the group posts and the web and found numerous posts about using a Motorola Atrix docking station
with the Beaglebone Black.
Most seemed to suggest it would work with the Angstrom distribution shipped with the Beaglebone Black.
However mine won’t work. I am using the cable set from Special Computing, and installed it per their (minimal) instructions.
I found the following on the wiki:
Software
The microSD card cannot be used as a storage device when booting from microSD in the 3.8 kernel.
SGX support is not currently provided i the 3.8 kernel. 3) The latest production image 6_20_2013 does not work on Lapdocks.
I have a serial debug cable and I have attached the boot process displayed on the terminal.
I can SSH to the beaglebone, so I know it is working. Just not the GUI.
Could someone please point me at a working (with a docking station) version of Angstrom and/or Ubuntu ?
Thanks;
Bill
U-Boot SPL 2013.04-rc1-14237-g90639fe-dirty (Apr 13 2013 - 13:57:11)
musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, HB-ISO Rx, HB-ISO Tx, SoftConn)
musb-hdrc: MHDRC RTL version 2.0
musb-hdrc: setup fifo_mode 4
musb-hdrc: 28/31 max ep, 16384/16384 memory
USB Peripheral mode controller at 47401000 using PIO, IRQ 0
USB Host mode controller at 47401800 using PIO, IRQ 0
OMAP SD/MMC: 0
mmc_send_cmd : timeout: No status update
reading u-boot.img
reading u-boot.img
U-Boot 2013.04-rc1-14237-g90639fe-dirty (Apr 13 2013 - 13:57:11)
I2C: ready
DRAM: 512 MiB
WARNING: Caches not enabled
NAND: No NAND device found!!!
0 MiB
cpsw, usb_ether
Card did not respond to voltage select!
mmc0(part 0) is current device
No micro SD card found, setting mmcdev to 1
SD/MMC found on device 1
reading uEnv.txt
14 bytes read in 4 ms (2.9 KiB/s)
4215264 bytes read in 780 ms (5.2 MiB/s)
22780 bytes read in 44 ms (504.9 KiB/s)
Booting from mmc …
Booting kernel from Legacy Image at 80007fc0 …
Image Name: Angstrom/3.8.6/beaglebone
Data Size: 4215200 Bytes = 4 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum … OK
Flattened Device Tree blob at 80f80000
Booting using the fdt blob at 0x80f80000
XIP Kernel Image … OK
OK
Using Device Tree in place at 80f80000, end 80f888fb
Starting kernel …
[ 0.106010] pinctrl-single 44e10800.pinmux: prop pinctrl-0 index 0 invalid ph andle
[ 0.222718] omap2_mbox_probe: platform not supported
[ 0.492043] tps65217-bl tps65217-bl: no platform data provided
[ 0.574977] bone-capemgr bone_capemgr.8: slot #0: No cape found
[ 0.612083] bone-capemgr bone_capemgr.8: slot #1: No cape found
[ 0.649191] bone-capemgr bone_capemgr.8: slot #2: No cape found
[ 0.686300] bone-capemgr bone_capemgr.8: slot #3: No cape found
[ 0.770828] pinctrl-single 44e10800.pinmux: pin 44e1080c already requested by mmc.4; cannot claim for gpio-leds.7
[ 0.781652] pinctrl-single 44e10800.pinmux: pin-3 (gpio-leds.7) status -22
[ 0.788863] pinctrl-single 44e10800.pinmux: could not request pin 3 on device pinctrl-single
systemd-fsck[82]: Angstrom: clean, 64457/112672 files, 357111/449820 blocks
[ 10.427182] libphy: PHY 4a101000.mdio:01 not found
[ 10.432267] net eth0: phy 4a101000.mdio:01 not found on slave 1
.—O—.
.-. o o
__ | —'| ‘–.| .-’| | |
The Angstrom Distribution beaglebone ttyO0
Angstrom v2012.12 - Kernel 3.8.6
beaglebone login: root
Last login: Sat Jan 1 00:02:12 UTC 2000 on ttyO0
root@beaglebone:~# ifconfig
eth0 Link encap:Ethernet HWaddr C8:A0:30:AC:BF:56
inet addr:192.168.10.108 Bcast:192.168.10.255 Mask:255.255.255.0
inet6 addr: fe80::caa0:30ff:feac:bf56/64 Scope:Link
RX packets:244 errors:0 dropped:0 overruns:0 frame:0
TX packets:52 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:57456 (56.1 KiB) TX bytes:10070 (9.8 KiB)
Interrupt:56
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
usb0 Link encap:Ethernet HWaddr E2:38:D6:9A:79:F5
inet addr:192.168.7.2 Bcast:192.168.7.3 Mask:255.255.255.252
UP BROADCAST MULTICAST MTU:1500 Metric:1
