my intention is to have some initial configuration (green light on). When I push the button, yellow, then red light shall be on.
When I start the code below, the function Ampel() will be called once in reverse order although I have not changed the input pin. After that “initialization phase” everything works as intended above. Furthermore, when I push the “stop” button in cloud9, the Ampel() function is called again, this time in correct order (but not expected).
How can I get rid of the “initialization phase” and the “afterrun”?
Help greatly appreciated.
Thank you!
BR Mathias
Code:
var b = require(‘bonescript’);
var red = “P8_13”;
var yellow = “P8_14”;
var green = “P8_15”;
var Button = ‘P8_19’;
var on = b.HIGH;
var off = b.LOW;
b.pinMode(red, b.OUTPUT);
b.pinMode(yellow, b.OUTPUT);
b.pinMode(green, b.OUTPUT);
b.pinMode(Button, b.INPUT);
b.attachInterrupt(Button, true, b.RISING, Ampel);
LED(red, on);
setTimeout(function() {LED(yellow, on);}, 1000);
setTimeout(function() {LED(red, off); LED(yellow, off); LED(green, on);}, 2000);
function Ampel() {
setTimeout(function() {LED(green, off); LED(yellow, on);}, 500);
setTimeout(function() {LED(yellow, off); LED(red, on);}, 1000);
setTimeout(function() {LED(red, off);},2000); // only debug code
function LED(xPin, xState){
b.digitalWrite(xPin, xState);}
