Audio Cape for Ubuntu
I just bought the Audio cape rev B1 and trying to operate it on Beaglebone black under Ubuntu 13.04
I was trying to follow this
http://elinux.org/BBB_Audio_Cape_RevB_Getting_Started
But stopped after this
root@beaglebone:~# dtc -O dtb -o BB-BONE-AUDI-02-00A0.dtbo -b 0 -@ BB-BONE-AUDI-02-00A0.dts
The dtc does not support -@ option
I tried to do this
http://www.embedded-things.com/bbb/patching-the-device-tree-compiler-for-ubuntu/
But stopped after
git reset --hard f8cb5dd94903a5cfa1609695328b8f1d5557367f
This line finished with following error
HEAD is now at f8cb5dd utilfdt_read_err: use xmalloc funcs
Now I stuck. Is it possible to use it under Ubuntu 13.04 or I should switch to Angstrom distribution?
Artem
This actually works out of the box with ubuntu now:
http://elinux.org/BeagleBoardUbuntu#BeagleBone.2FBeagleBone_Black
cd /opt/scripts/tools
git pull
sudo ./update_kernel.sh
(reboot)
Then just disable "BB-BONELT-HDMI" in /boot/uboot/uEnv.txt , enable
with /etc/default/capemgr like the wiki shows..
Hi Robert,
Thank you very much for the answer. I am trying to follow your advises and now have another issue.
I did the following
  1. Download and unzip image https://rcn-ee.net/deb/microsd/trusty/bone-ubuntu-14.04-console-2014-06-05-2gb.img.xz on Windows
  2. Put the image to SD-card using Win32DiskImager tool
  3. Inserted SD-card to BBB device and power it on
  4. After a minute I see arm login prompt.
But after 10 min nothing was happened. I expected that system will be copied to eMMC but not.
I understand that installation script was not executed and I did the following (after login)
cd /
cd home
git clone https://github.com/RobertCNelson/boot-scripts.git
cd boot-scripts/tools
sudo sh init-eMMC-flasher.sh
The script was started
debug copying [/dev/mmcblk0 → /dev/mmcblk1]
But was finished with a lot of errors
permission denied…
rsync: read errors mapping…
failed verification – update discarded…
Could you please advise what was went wrong
Best regards,
Artem
Hi Robert,
I did the following
on Windows
to eMMC but not.
Well yeah.. The flasher is here:
http://elinux.org/BeagleBoardUbuntu#eMMC:_BeagleBone_Black
https://rcn-ee.net/deb/flasher/trusty/BBB-eMMC-flasher-ubuntu-14.04-console-2014-06-05-2gb.img.xz
(it has "flasher" in it's name..)
cd /
cd home
git clone GitHub - RobertCNelson/boot-scripts: Just a bunch of useful scripts placed under /opt/scripts/
That's the "init" script and it needs to be run by bash in single user mode...
If your going to run it from the command line run:
cd /opt/scripts/tools/
git pull
sudo ./beaglebone-black-eMMC-flasher.sh
Hi Robert,
Thank you very much. The Ubuntu on eMMC was updated and Audio Cape is working now!
If somebody needed exact steps I did the following.
  3. Insert SD-card to BBB device and power it on
  4. Edit the uEnv.txt at /boot/uboot. Uncomment these lines in the uEnv.txt file:
cape_disable=capemgr.disable_partno=BB-BONELT-HDMI
cape_enable=capemgr.enable_partno=BB-BONE-AUDIO-02
  1. Edit the following line in /etc/default/capemgr
CAPE=BB-BONE-AUDI-02
  1. Restart and check the audio
sudo apt-get install alsa-utils
sudo find / -iname ‘*.wav’
aplay /usr/share/sounds/alsa/Front_Center.wav
  1. Execute flasher manually
cd /home
  1. Restart
Best regards,
Artem
