Hi All,
Audio out jack popped out of the beagle board ( along with metal layer on PCB) . Could any one tell me the alternate points on the board where i can tap out the audio out lines or any ways to fix the same to the board ?
Hi ShankarGanesh,
Please take a look at the schematics (http://beagle.s3.amazonaws.com/BEAGLEBOARD_B7.pdf) page 6.
You can access the signals at either R44, R46, D8, D9 or C57, C56.
At least on Rev B7 (I assume it’s similar for all revisions) you should connect to the end located closest to the connector in order to get a connected to CONN_HSOL and CONN_HSOR. For your convenience I have attached the relevant part of the layout
In case you won’t solder, I think you could go for a RMA instead, but I’m not into the details about this…
Please consult Gerald before doing any modifications to the board in case you would like to go for the RMA process…
Best regards - Good luck
Søren
There are several places. Refer to the schematic and it will indicate those places. You can also send it in for repair.
