I want auto mount a SD card, with fstab no problem.
But when i boot with a SD card in slot, the device is assigned to /dev/mmcblk0p1 and if i boot without SD card, the device is assigned to /dev/mmcblk1p1 after i insert SD card.
In my project I do not know if the SD card are in the slot during the boot. What is the best way for auto mount an SD card ? (With and Without SD card in slot during the boot)
Thanks.
Thanks.
Best Regards.
For more options, visit http://beagleboard.org/discuss
You received this message because you are subscribed to the Google Groups "BeagleBoard" group.
To unsubscribe from this group and stop receiving emails from it, send an email to beagleboard+unsubscribe@googlegroups.com.
For more options, visit https://groups.google.com/d/optout.
just a shot in the dark:
use lsusb -v as root to examine the "attributes" (correct
word?...sorry I am no native english speaker...) of the usb port
of the hub on the beaglebone.
Then build an udev rule to assign it a constant name additonally to
the already given one (mmcblk*) in case of other programs use that
one.
Can you give me an example or a method to automatically mount ?
How i can execute a script after SD is inserted ? (Such as /etc/network/if-up.d/ for the network…)
I tested a script at startup who edit fstab file depending if SD card is in slot at startup. It work but when i remove (if it is in slot) and insert the SD, the SD was not mount. For mount it i need to execut mount -a command and it’s not autonomous…
