I installed the demo image of Maverick as outlined here: http://elinux.org/BeagleBoardUbuntu . However, my serial port on my
BeagleBoard is not currently working and I would like a GUI install.
Does anyone know if I can edit the setup_sdcard.sh script or install
the GUI through my host PC rather than the BeagleBoard?
Unfortunately, my keyboard and mouse don't seem to be working with the
comand-line Ubuntu right off the bat so I cannot access anything
through the Beagleboard at all at the moment.
I can confirm. At least, ARM Maverick GUI rootfs
can be built by RootStock on a x86 Lucid desktop for me.
But, just as Nelson said, we need more detail, e.g. full bootlog.
Unfortunately, my keyboard and mouse don’t seem to be working with the
Where/How did you get the u-boot.bin?
I had a experience tells me maybe it’s u-boot problem.
I finally got the image of Maverick up and running but still no
keyboard/mouse. The hub I am using works with Angstrom, so I thought
Ubuntu wouldn't have any issues with it.
I have a rev C4 board, the usb hub is plugged into my OTG port. The
hub is USB 2.0 and has an external power source which I plug in and
all USB devices (keyboard and mouse only) are plugged in before I
power on.
Thanks for your reply. I switched to the netbook image from ubuntu.com. It's the most up to date one for OMAP3. Since I can't
connect the board to my pc to get the GUI up and running, I had to go
with their build.
I plugged my hub into the ehci port and everything works. I'm used to
using a Gumstix board and it only had the OTG port for the hub so I
just automatically used it for the BB. It still seems a little buggy
but everything works for the most part!
