Azure IoT Edge Runtime on BeagleBone Green
Good Day everyone,
I have tried to install Azure IoT Edge runtime on my BeagleBone Board Green running Debian 10, 2020-04-06 image but encountered problem when I reach the stage to installing the Moby engine.
Basically, I follow the steps outlined in the below link :
https://docs.microsoft.com/en-us/azure/iot-edge/how-to-install-iot-edge?view=iotedge-2018-06
When I execute the below steps :
sudo apt-get install moby-engine
I got the below error :
Reading package lists… Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
moby-engine : Depends: moby-containerd (>= 1.4.3) but it is not going to be installed
Depends: moby-runc (>= 1.0.0~rc93) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
The microsoft document does have mentioned possible error on the Moby installation and they have provided some script to test the configuration. Below is the result :
debian@beaglebone:~$ curl -sSL https://raw.githubusercontent.com/moby/moby/master/contrib/check-config.sh -o check-config.sh
debian@beaglebone:~$ chmod +x check-config.sh
debian@beaglebone:~$ ./check-config.sh
info: reading kernel config from /proc/config.gz …
Generally Necessary:
  • cgroup hierarchy: properly mounted [/sys/fs/cgroup]
  • apparmor: enabled, but apparmor_parser missing
    (use “apt-get install apparmor” to fix this)
  • CONFIG_NAMESPACES: enabled
  • CONFIG_NET_NS: enabled
  • CONFIG_PID_NS: enabled
  • CONFIG_IPC_NS: enabled
  • CONFIG_UTS_NS: enabled
  • CONFIG_CGROUPS: enabled
  • CONFIG_CGROUP_CPUACCT: enabled
  • CONFIG_CGROUP_DEVICE: enabled
  • CONFIG_CGROUP_FREEZER: enabled
  • CONFIG_CGROUP_SCHED: enabled
  • CONFIG_CPUSETS: enabled
  • CONFIG_MEMCG: enabled
  • CONFIG_KEYS: enabled
  • CONFIG_VETH: enabled (as module)
  • CONFIG_BRIDGE: enabled (as module)
  • CONFIG_BRIDGE_NETFILTER: enabled (as module)
  • CONFIG_IP_NF_FILTER: enabled
  • CONFIG_IP_NF_TARGET_MASQUERADE: enabled (as module)
  • CONFIG_NETFILTER_XT_MATCH_ADDRTYPE: enabled (as module)
  • CONFIG_NETFILTER_XT_MATCH_CONNTRACK: enabled (as module)
  • CONFIG_NETFILTER_XT_MATCH_IPVS: enabled (as module)
  • CONFIG_NETFILTER_XT_MARK: enabled (as module)
  • CONFIG_IP_NF_NAT: enabled
  • CONFIG_NF_NAT: enabled
  • CONFIG_POSIX_MQUEUE: enabled
  • CONFIG_NF_NAT_IPV4: enabled
  • CONFIG_NF_NAT_NEEDED: enabled
Optional Features:
  • CONFIG_USER_NS: enabled
  • CONFIG_SECCOMP: enabled
  • CONFIG_SECCOMP_FILTER: enabled
  • CONFIG_CGROUP_PIDS: enabled
  • CONFIG_MEMCG_SWAP: enabled
  • CONFIG_MEMCG_SWAP_ENABLED: enabled
    (cgroup swap accounting is currently enabled)
  • CONFIG_IOSCHED_CFQ: enabled
  • CONFIG_CFQ_GROUP_IOSCHED: enabled
  • CONFIG_BLK_CGROUP: enabled
  • CONFIG_BLK_DEV_THROTTLING: enabled
  • CONFIG_CGROUP_PERF: enabled
  • CONFIG_CGROUP_HUGETLB: missing
  • CONFIG_NET_CLS_CGROUP: enabled (as module)
  • CONFIG_CGROUP_NET_PRIO: enabled
  • CONFIG_CFS_BANDWIDTH: enabled
  • CONFIG_FAIR_GROUP_SCHED: enabled
  • CONFIG_RT_GROUP_SCHED: enabled
  • CONFIG_IP_NF_TARGET_REDIRECT: enabled (as module)
  • CONFIG_IP_VS: enabled (as module)
  • CONFIG_IP_VS_NFCT: enabled
  • CONFIG_IP_VS_PROTO_TCP: enabled
  • CONFIG_IP_VS_PROTO_UDP: enabled
  • CONFIG_IP_VS_RR: enabled (as module)
  • CONFIG_SECURITY_SELINUX: enabled
  • CONFIG_SECURITY_APPARMOR: enabled
  • CONFIG_EXT4_FS: enabled
  • CONFIG_EXT4_FS_POSIX_ACL: enabled
  • CONFIG_EXT4_FS_SECURITY: enabled
  • Network Drivers:
  • “overlay”:
  • CONFIG_VXLAN: enabled (as module)
  • CONFIG_BRIDGE_VLAN_FILTERING: enabled
    Optional (for encrypted networks):
  • CONFIG_CRYPTO: enabled
  • CONFIG_CRYPTO_AEAD: enabled
  • CONFIG_CRYPTO_GCM: enabled
  • CONFIG_CRYPTO_SEQIV: enabled
  • CONFIG_CRYPTO_GHASH: enabled
  • CONFIG_XFRM: enabled
  • CONFIG_XFRM_USER: enabled (as module)
  • CONFIG_XFRM_ALGO: enabled (as module)
  • CONFIG_INET_ESP: enabled (as module)
  • CONFIG_INET_XFRM_MODE_TRANSPORT: enabled (as module)
  • “ipvlan”:
  • CONFIG_IPVLAN: enabled (as module)
  • “macvlan”:
  • CONFIG_MACVLAN: enabled (as module)
  • CONFIG_DUMMY: enabled (as module)
  • “ftp,tftp client in container”:
  • CONFIG_NF_NAT_FTP: enabled (as module)
  • CONFIG_NF_CONNTRACK_FTP: enabled (as module)
  • CONFIG_NF_NAT_TFTP: enabled (as module)
  • CONFIG_NF_CONNTRACK_TFTP: enabled (as module)
  • Storage Drivers:
  • “aufs”:
  • CONFIG_AUFS_FS: enabled (as module)
  • “btrfs”:
  • CONFIG_BTRFS_FS: enabled
  • CONFIG_BTRFS_FS_POSIX_ACL: enabled
  • “devicemapper”:
  • CONFIG_BLK_DEV_DM: enabled (as module)
  • CONFIG_DM_THIN_PROVISIONING: enabled (as module)
  • “overlay”:
  • CONFIG_OVERLAY_FS: enabled
  • “zfs”:
    - /dev/zfs: missing
    - zfs command: missing
    - zpool command: missing
Limits:
  • /proc/sys/kernel/keys/root_maxkeys: 1000000
The above checking revealed that there are 4 modules ‘missing’ but as these are not in the ‘GENERALLY NECESSARY’ group or the ‘Network Driver’ sections, it should not matters as stated by the Microsoft document.
Does anyone have any experience in installing the Azure IoT Edge Runtime on the BeagleBone Green ? Hope you can share some experience with me.
Thanks in advance and sorry for this long message.
Best Regards,
Stony Kong
Hi!
Hi Tarmo,
Thank you for your reply.
As I am really new to BeagleBone and Linux, and so I guess it would be too adventurous for me to try.
Anyway, thanks again for your advices.
Best Regards,
Stony Kong
