Backporting u-boot "space key to halt boot" change into 2015.01 code - can't get the changes picked up by Make
I have some older BBB devices out in the world running some rather old OS code. Due to some bad capacitor choices, we’re seeing a lot of noise on the debug serial port that is interpreted as the “any key” a bit too often.
I’m trying to port the “space key to halt boot” fix from am335x: BeagleBones enable CONFIG_AUTOBOOT_KEYED (07684b99) · Commits · U-Boot / U-Boot · GitLab back into the 2015.01 u-boot code (updating the full OS on these is NOT in scope) and following instructions at Embedded Coding: Beaglebone Black Development Part 4 - Bootloader, Linux Kernel and Filesystem to rebuild the bootloader.
The file change went smoothly, as did the instructions for pulling in all of RCN’s assorted patches. When I run “make am335x_evm_defconfig”, though, the “CONFIG_AUTOBOOT_” entries are NOT making into the .config file that’s generated.
What am I missing, folks? This seems like it should be pretty obvious…
The u-boot tag of 2015.01 has those options:
So i’m guessing your patch is failing, or your not patching the config your building…
I agree - 2015.01 /should/ be nicely compatible with the changes outlied in the link from my original post.
As in the original change, I’ve modifed
  • configs/am335x_boneblack_defconfig
  • configs/am335x_boneblack_bvoot_defconfig
  • configs/am335x_evm_defconfig
… to add lines:
CONFIG_AUTOBOOT_KEYED=y
CONFIG_AUTOBOOT_PROMPT=“Press SPACE to abort autoboot in %d seconds\n”
CONFIG_AUTOBOOT_DELAY_STR=“d”
CONFIG_AUTOBOOT_STOP_STR=" "
…and checked all three into a clone of the u-boot repository that I branched at the 2015.01 tag.
My configs/am335x_evm_defconfig now reads
CONFIG_SPL=y
CONFIG_SYS_EXTRA_OPTIONS=“NAND”
CONFIG_CONS_INDEX=1
+S:CONFIG_ARM=y
+S:CONFIG_TARGET_AM335X_EVM=y
At the end of step 4.1 on the EmbeddedCoding.com steps, I have a u-boot.img file, but the strings table in it does NOT have anything for the CONFIG_AUTOBOOT_PROMPT in it.
Ah. I think I’ve found it. At 2015.01 the “CONFIG_AUTOBOOT_*” macros hadn’t been migrated out of the include/<board>.h files.
Adding those macros into the include/am335x_evm.h file gets me a u-boot.img that has the right strings showing up in it.
