baegley-ai no hdmi output
Hi, I jist got a new BeagleY-AI. I have flashed the latest desktop OS using Etcher. When I start up, I am happy the board is working as I can SSH to it and I get the expected challenge response. However when I plug into a monitor there is no output. I have tested the cables with a BB Black and Raspberry Pi and they both output video, so I am happy the cable is working. I Am I missing something?
Tony
This is fail safe on first bootup… Unless you set a password in sysconf.txt in the fat partition, xorg will not let you in… If you changed the password over ssh on first login over ssh…
sudo systemctl enable --now lightdm
Thanks, between posting my question and it being screened, I found that out. Also I missed a step from the setup. I’m OK now. I’m looking forward to playing around with the board
Tony
