I am newbie and trying to compile kernel and using TFTP want to boot my beaglebone black .
My problem is , my board gets hanged up at "starting Kernel "
Log is as below . Thank you for any help .
U-Boot# setenv ipaddr 192.168.1.7
U-Boot# setenv serverip 192.168.1.5
U-Boot# tftpboot 0x80F80000 am335x-boneblack.dtb
link up on port 0, speed 100, full duplex
Using cpsw device
TFTP from server 192.168.1.5; our IP address is 192.168.1.7
Filename ‘am335x-boneblack.dtb’.
Load address: 0x80f80000
Loading: T ####
9.8 KiB/s
done
Bytes transferred = 58133 (e315 hex)
U-Boot# tftpboot 0x80007fc0 uImage-BBB
Using cpsw device
Filename ‘uImage-BBB’.
Load address: 0x80007fc0
Loading: T
TFTP error: ‘File not found’ (1)
Not retrying…
U-Boot# tftpboot 0x80007FC0 uImage-BBB
Using cpsw device
Loading: T #################################################################
Thanks for the links , at last I am able to go ahead from startin Kernel .
Issue was the dtb address .
After this I am getting stuck at below .
[ 6.109739] init: Error while reading from descriptor: Bad file descriptor
[ 6.117091] init: Error while reading from descriptor: Bad file descriptor
[ 6.125627] init: plymouth-ready (startup) main process (119) terminated with sta7
[ 6.134105] init: plymouth-upstart-bridge main process (120) terminated with stat1
[ 6.142219] init: plymouth-upstart-bridge main process ended, respawning
[ 6.152647] init: hwclock main process (123) terminated with status 127
[ 6.289465] init: ureadahead main process (124) terminated with status 5
[ 6.298215] init: plymouth-upstart-bridge main process (129) terminated with stat1
[ 6.306361] init: plymouth-upstart-bridge main process ended, respawning
[ 6.314406] init: plymouth main process (131) terminated with status 71
[ 6.406667] init: mountall main process (136) terminated with status 127
Full Log is as below .
U-Boot# setenv ipaddr 192.168.1.5;setenv serverip 192.168.1.8;tftpboot 0x8FFEE000 am0
Using cpsw device
TFTP from server 192.168.1.8; our IP address is 192.168.1.5
Load address: 0x8ffee000
Loading: T #####
10.7 KiB/s
done
Bytes transferred = 60627 (ecd3 hex)
Using cpsw device
Loading: T T #################################################################
