Howdy. After some years away I’ve come back to IoT and developing projects on my BeagleBone Black. And by some years, I mean the U-Boot method of loading overlays is completely new to me.
Here’s the .dts
I’m writing:
/dts-v1/;
/plugin/;
compatible = "ti,beaglebone", "ti,beaglebone-black";
/* identification */
part-number = "BB-MIKROCAPE-SPIHOST1";
version = "00A0";
/* state the resources this cape uses */
exclusive-use =
/* the pin header uses */
"P9.28", /* spi1_cs0 */
"P9.29", /* spi1_d0 */
"P9.30", /* spi1_d1 */
"P9.31", /* spi1_sclk */
/* the hardware ip uses */
"spi1";
fragment@0 {
target = <&am33xx_pinmux>;
__overlay__ {
spi1_pins_s0: spi1_pins_s0 {
pinctrl-single,pins = <
0x190 0x33 /* mcasp0_aclkx.spi1_sclk, INPUT_PULLUP | MODE3 */
0x194 0x33 /* mcasp0_fsx.spi1_d0, INPUT_PULLUP | MODE3 */
0x198 0x13 /* mcasp0_axr0.spi1_d1, OUTPUT_PULLUP | MODE3 */
0x19c 0x13 /* mcasp0_ahclkr.spi1_cs0, OUTPUT_PULLUP | MODE3 */
0x164 0x12 /* eCAP0_in_PWM0_out.spi1_cs1 OUTPUT_PULLUP | MODE2 */
fragment@1 {
target = <&spi1>; /* spi1 is numbered correctly */
__overlay__ {
#address-cells = <1>;
#size-cells = <0>;
status = "okay";
pinctrl-names = "default";
pinctrl-0 = <&spi1_pins_s0>;
/*cs-gpios = <0>;*/
spidev@1 {
compatible = "linux,spidev";
reg = <0>;
spi-max-frequency = <16000000>;
and I can compile it with dtc
, copy the *.dtbo
to /lib/firmware
and then reference it in /boot/uEnv.txt
debian@beaglebone:~/projects/mikro$ cat /boot/uEnv.txt
uname_r=4.19.94-ti-r73
#uuid=
#dtb=
###U-Boot Overlays###
###Documentation: http://elinux.org/Beagleboard:BeagleBoneBlack_Debian#U-Boot_Overlays
###Master Enable
enable_uboot_overlays=1
###Overide capes with eeprom
#uboot_overlay_addr0=/lib/firmware/<file0>.dtbo
#uboot_overlay_addr1=/lib/firmware/<file1>.dtbo
#uboot_overlay_addr2=/lib/firmware/<file2>.dtbo
#uboot_overlay_addr3=/lib/firmware/<file3>.dtbo
###Additional custom capes
#uboot_overlay_addr4=/lib/firmware/<file4>.dtbo
#uboot_overlay_addr5=/lib/firmware/<file5>.dtbo
#uboot_overlay_addr6=/lib/firmware/<file6>.dtbo
#uboot_overlay_addr7=/lib/firmware/<file7>.dtbo
###Custom Cape
dtb_overlay=/lib/firmware/BB-MIKROCAPE-SPIHOST1.dtbo
###Disable auto loading of virtual capes (emmc/video/wireless/adc)
#disable_uboot_overlay_emmc=1
disable_uboot_overlay_video=1
disable_uboot_overlay_audio=1
#disable_uboot_overlay_wireless=1
#disable_uboot_overlay_adc=1
###PRUSS OPTIONS
###pru_rproc (4.14.x-ti kernel)
#uboot_overlay_pru=/lib/firmware/AM335X-PRU-RPROC-4-14-TI-00A0.dtbo
###pru_rproc (4.19.x-ti kernel)
uboot_overlay_pru=/lib/firmware/AM335X-PRU-RPROC-4-19-TI-00A0.dtbo
###pru_uio (4.14.x-ti, 4.19.x-ti & mainline/bone kernel)
#uboot_overlay_pru=/lib/firmware/AM335X-PRU-UIO-00A0.dtbo
###Cape Universal Enable
#enable_uboot_cape_universal=1
###Debug: disable uboot autoload of Cape
#disable_uboot_overlay_addr0=1
#disable_uboot_overlay_addr1=1
#disable_uboot_overlay_addr2=1
#disable_uboot_overlay_addr3=1
###U-Boot fdt tweaks... (60000 = 384KB)
#uboot_fdt_buffer=0x60000
cmdline=coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 quiet
#In the event of edid real failures, uncomment this next line:
#cmdline=coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 quiet video=HDMI-A-1:1024x768@60e
##enable Generic eMMC Flasher:
##make sure, these tools are installed: dosfstools rsync
#cmdline=init=/opt/scripts/tools/eMMC/init-eMMC-flasher-v3.sh
Yet the overlay isn’t loaded:
debian@beaglebone:/opt/scripts/tools$ sudo ./version.sh
git:/opt/scripts/:[931449639670238ab1c2085c1e4769a0638c1660]
eeprom:[A335BNLT000C2914BBBK1443]
dogtag:[BeagleBoard.org Debian Buster IoT Image 2020-04-06]
bootloader:[microSD-(push-button)]:[/dev/mmcblk0]:[U-Boot SPL 2019.04-00002-g07d5700e21 (Mar 06 2020 - 11:24:55 -0600)]:[location: dd MBR]
bootloader:[microSD-(push-button)]:[/dev/mmcblk0]:[U-Boot 2019.04-00002-g07d5700e21]:[location: dd MBR]
bootloader:[eMMC-(default)]:[/dev/mmcblk1]:[U-Boot SPL 2018.03-00002-gac9cce7c6a (Apr 05 2018 - 13:07:46 -0500)]:[location: dd MBR]
bootloader:[eMMC-(default)]:[/dev/mmcblk1]:[U-Boot 2018.03-00002-gac9cce7c6a]:[location: dd MBR]
UBOOT: Booted Device-Tree:[am335x-boneblack-uboot-univ.dts]
UBOOT: Loaded Overlay:[AM335X-PRU-RPROC-4-19-TI-00A0]
UBOOT: Loaded Overlay:[BB-ADC-00A0.bb.org-overlays]
UBOOT: Loaded Overlay:[BB-BONE-eMMC1-01-00A0.bb.org-overlays]
kernel:[4.19.94-ti-r73]
nodejs:[v10.24.0]
/boot/uEnv.txt Settings:
uboot_overlay_options:[disable_uboot_overlay_video=1]
uboot_overlay_options:[disable_uboot_overlay_audio=1]
uboot_overlay_options:[uboot_overlay_pru=/lib/firmware/AM335X-PRU-RPROC-4-19-TI-00A0.dtbo]
uboot_overlay_options:[dtb_overlay=/lib/firmware/BB-MIKROCAPE-SPIHOST1.dtbo]
pkg check: to individually upgrade run: [sudo apt install --only-upgrade <pkg>]
pkg:[bb-cape-overlays]:[4.14.20210821.0-0~buster+20210821]
pkg:[bb-customizations]:[1.20221108.0-0~buster+20221108]
pkg:[bb-usb-gadgets]:[1.20220816.0-0~buster+20220816]
pkg:[bb-wl18xx-firmware]:[1.20211222.2-0~buster+20211222]
pkg:[kmod]:[26-1]
pkg:[librobotcontrol]:[1.0.5-git20200715.0-0~buster+20200716]
pkg:[firmware-ti-connectivity]:[20190717-2rcnee1~buster+20200305]
groups:[debian : debian adm kmem dialout cdrom floppy audio dip video plugdev users systemd-journal bluetooth netdev i2c gpio pwm eqep remoteproc admin spi iio docker tisdk weston-launch xenomai cloud9ide]
cmdline:[console=ttyO0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 quiet]
dmesg | grep remote
[ 53.187523] remoteproc remoteproc0: wkup_m3 is available
[ 53.267946] remoteproc remoteproc0: powering up wkup_m3
[ 53.267980] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217148
[ 53.268276] remoteproc remoteproc0: remote processor wkup_m3 is now up
[ 56.032002] remoteproc remoteproc1: 4a334000.pru is available
[ 56.046477] remoteproc remoteproc2: 4a338000.pru is available
dmesg | grep pru
[ 56.032158] pru-rproc 4a334000.pru: PRU rproc node pru@4a334000 probed successfully
[ 56.046666] pru-rproc 4a338000.pru: PRU rproc node pru@4a338000 probed successfully
dmesg | grep pinctrl-single
[ 0.955157] pinctrl-single 44e10800.pinmux: 142 pins, size 568
[ 1.206027] pinctrl-single 44e10800.pinmux: pin PIN100 already requested by ocp:P9_31_pinmux; cannot claim for 481a0000.spi
[ 1.217411] pinctrl-single 44e10800.pinmux: pin-100 (481a0000.spi) status -22
[ 1.224624] pinctrl-single 44e10800.pinmux: could not request pin 100 (PIN100) from group pinmux_bbb_spi1_pins on device pinctrl-single
dmesg | grep gpio-of-helper
[ 0.969045] gpio-of-helper ocp:cape-universal: ready
lsusb
END
I’ve tried to follow along with all of the “new” overlay documentation but have been unsuccessful in loading my overlay. I’m guessing this:
is the root of the problem.
