When I run sudo app_edgeai ./object_detection.yaml I keep getting this error I already ran the setup. Has anyone had this issue before? It ran before with the SD card image and now it doesn’t on eMMC?
After sudo apt install ti-edgeai-8.2-base ti-edgeai-8.2-src ti-vision-apps-eaik-firmware-8.2
Seems like remote firmwares are not loaded properly.
Can you please share the full boot logs (preferably along with uboot logs that comes on serial), if you don’t have serial, please share the dmesg output
Also please share the base SD card Image that you used, before installing edgeai packages
I was using the incorrect image. Thank you
