Hi everyone,
I am using a BeagleBone Black running the latest Debian 13 (Trixie) image. I recently used the pre-installed bb-beagle-flasher tool to turn my microSD card into an auto-flasher to copy my setup over to the eMMC.
To do this, I booted from the eMMC with a blank microSD card inserted and ran:
sudo beagle-flasher
Once that completed, I booted from the microSD card once and ran:
sudo enable-beagle-flasher
sudo systemctl poweroff
The Issue:
The flashing process works perfectly. However, the microSD card is now stuck in a permanent flashing loop. Whenever I insert this microSD card and try to boot from it normally, it immediately starts flashing the eMMC all over again instead of booting into the OS.
I want this microSD card to function as a normal bootable card again now that the eMMC flashing is finished.
My Questions:
How do I disable or clear the persistent auto-flash script/flag on the microSD card so it boots normally?
Which file or environment variable (e.g., in
uEnv.txt) do I need to comment out or delete to stop theinit-beagle-flasherscript from triggering on every boot?
Any guidance on how to safely revert the card back to a standard bootable state would be greatly appreciated!
Thanks in advance.
