I attach a log with the output of /opt/scripts/tools/eMMC/beaglebone-black-make-microSD-flasher-from-eMMC.sh and a fragment of output of e2fsck -f /dev/mmcblk0p1.
BBB can boot from it, then it gets slowly worse until halt. Still, BBB works normally with its eMMC. One of the reasons might be, that /dev/mmcblk0p1 is reported as having 4GB or 16GB, depending on the software.
Unattached inode 793363
Connect to /lost+found? yes
Inode 793363 ref count is 2, should be 1. Fix? yes
Unattached inode 793364
Inode 793364 ref count is 2, should be 1. Fix? yes
Unattached inode 793365
Inode 793365 ref count is 2, should be 1. Fix? yes
Unattached inode 793366
Inode 793366 ref count is 2, should be 1. Fix? yes
Unattached inode 793367
Inode 793367 ref count is 2, should be 1. Fix? yes
Unattached inode 793368
Inode 793368 ref count is 2, should be 1. Fix? yes
Unattached inode 793369
Inode 793369 ref count is 2, should be 1. Fix? yes
Unattached inode 793370
Inode 793370 ref count is 2, should be 1. Fix? yes
Inode 793421 ref count is 1, should be 2. Fix? yes
Inode 794552 ref count is 6, should be 4. Fix? yes
Inode 794553 ref count is 6, should be 4. Fix? yes
Inode 794554 ref count is 6, should be 4. Fix? yes
Inode 794555 ref count is 6, should be 4. Fix? yes
Unattached inode 794592
Inode 794592 ref count is 2, should be 1. Fix? yes
Unattached inode 794600
Inode 794600 ref count is 2, should be 1. Fix? yes
Unattached inode 794601
Inode 794601 ref count is 2, should be 1. Fix? yes
Unattached inode 794605
Inode 794605 ref count is 2, should be 1. Fix? yes
flasher.log (14.9 KB)
