Hey All,
I am trying to use a Beaglebone blue with a cheap single pulse encoder (Sparkfun https://www.sparkfun.com/products/13260). I have connected the pulse output to both eQEP A and B connection on the blue thinking this will work, but I am not so sure that this is legitimate. I do see the pulse count up, but sometimes the accumulated pulse value will actually decrease. I suspect this might be a issue since the edge feeding the two inputs are aligned.
I am using Strawson Design Roboticscape code and I am displaying the count returned by the rc_get_encoder_pos function. Also the pulse train out of the encoder looks good.
From /etc/dogtag: BeagleBoard.org Debian Image 2017-03-19
As usual any help or thoughts is greatly appreciated.
Mark
Mark
I suspect your cheap encoder is incompatible with the Blue. The BB Blue is designed to operate with quadrature encoders. The Sparkfun site does not indicate your encoders are quadrature. There's a lot of other gobblygook in their encoder specifications...magnets and sensors etc...but sadly it's missing the word "quadrature".
Here is a link to a simple explaination of quadrature encoders....https://www.dynapar.com/Technology/Encoder_Basics/Quadrature_Encoder/
Note that the quadrature encoder A and B outputs are 90 degrees out of phase. This is critical. Without them being out of phase it is not possible to determine what direction the shaft is being rotated.
So find a way to watch both encoder outputs while you slowly turn the encoder in both directions. A dual channel oscilloscope or logic analyzer is best but you might be able to do it with LEDs or two voltmeters. The A and B pulses should never rise or fall at the same time. They need to be 90 degrees out of phase with each other.
Get back to me if you have more questions.
Clark
Thanks Clark for the info. The encoder is a hall effect sensor coupled with a disk that has a series of magnets. It is quite low resolution but does spin at motor speed which gives several hundred pulses per second. I am using it mainly for learning about motor control and I really don't care about direction at least for now.
I did notice the ePEP hardware does support a simple up (or down) count from the A input. If this is the case I might be able to change the Strawson library. I will post back one way or the other
Mark
Mark
Since you don’t care about direction, for now, you might try hooking the encoder to just the A channel. I’m not sure what will happen when the quadrature encoder input is missing the B channel, but it might work. Whatever you do, don’t hook the output from the sensor to both inputs, that will cause the quadrature input to be really confused….sometimes counting up and sometimes counting down.
If that doesn’t work then I think you will have to modify the eQEP code.
Clark
Yep as you and Clark have surmised, neither connecting the pulse to A and B would work nor connecting just the A input. The counter would sometimes decrement if A and B were connected, and the counter would simply toggle from 1 to -1 if only A was connected. However the good news is I was able to get it to work by changing one of the control registers in the eQEP hardware to a simple up count. The encoder pulse is connected to the A input whereas B is not used. The pulse count is now solid on both channels. Mark
Hi Mark,
I am interested in doing the same thing (i.e. a basic hall effect sensor connected to the encoder channel on BB Blue).
Can you provide more details on how you got it to work?
How did you change the control registers in the eQEP hardware?
Could you provide a code sample that I could use?
Justin
Depending on the mode the eQEP is configured the pulses may need to out of phase. The eQEP users guide explains this quite well
Hi Justin,
I modified the roboticscape source that changed the QDECCTL EQEP register. This changed
the encoder from expecting a quadrature input to a simple up counter. Input A should be used
to sense the hall effect pulses. I can't remember, but I do believe I had to ground input B
This will only work for the first three encoders as the fourth is handled by the PRU.
I fully intended to submit my changes so hopefully they would end up in mainline code,
however I am not familiar PRU what changes were needed for the PRU. Of course I
moved on to other projects.
I hope this helps
Mark
Here are the sections of code I changed:
In roboticscape.c (just a comment change)
* int rc_set_encoder_mode(int ch, int mode)
If the decoder is in quadrature mode, this probably won't work---it needs
the B channel signalling to disambiguate the direction, so I think the
counter will not change. This is just my guess based on general knowledge,
so I may be wrong---check it for yourself.
