bb-code-server is not working. Is there a reason this has failed recently? I am trying to track down the cause currently…
https://github.com/coder/code-server
That is the site I found so far via looking through the .service file. Anyway, I am not going to change things so far. I just wanted to give a heads up to anyone working on it.
P.S. Oh!
● bb-code-server.service - BeagleBoard.org Code Server
Loaded: loaded (/lib/systemd/system/bb-code-server.service; enabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Sat 2022-09-17 19:32:57 CDT; 10s ago
Docs: https://github.com/coder/code-server/tree/main/docs
Process: 2285 ExecStartPre=/bin/ln -sf /opt/vsx-examples/examples/ /home/debian/ (code=exited, status=0/SUCCESS)
Process: 2286 ExecStartPre=/bin/mkdir -p /home/debian/.local/share/code-server/User/ (code=exited, status=0/SUCCESS)
Process: 2287 ExecStartPre=/bin/cp /opt/vsx-examples/examples/settings.json /home/debian/.local/share/code-server/User/ (code=exited, status=0/SUCCESS)
Process: 2288 ExecStart=/opt/bb-code-server/app/bin/code-server --cert --auth none --disable-telemetry --disable-update-check --config /opt/bb-code-server/config/config.yaml --extensions>
Main PID: 2288 (code=exited, status=1/FAILURE)
CPU: 26.019s
I am currently working to make some posts work but to not a success in sight is the current times.
