Dear All!
I’m using beagle bone green for my project. What I need is a couple of gpios, spi bus, second ethernet with usb or spi (I have custom wiznet5200 board). I was planning to have minimalistic system, which could run with busybox rootfs on ramdisk.
What I did is:
git clone GitHub - beagleboard/linux: The official BeagleBoard and BeagleBone kernel repository,
git clone GitHub - u-boot/u-boot: "Das U-Boot" Source Tree,
git clone GitHub - mirror/busybox: BusyBox mirror.
for kernel I use tag v5.18-rc4, made ‘make omap2def_config’ and after that menuconfig and switch off some drivers which I don’t need (audio, video, unneeded fs etc.).
for busybox I used default configuration
for uboot I used ‘make am335x_boneblack_vboot_defconfig’
with helps of uboot’s mkimage tool I make kernel image ‘make LOADADDR=0x80008000 uImage’ and image of busybox rootfs for ramdisk with ‘mkimage -C none -A arm -O linux -T ramdisk -d ramdisk uRamDisk’ (I copied files from busybox’s _install folder to ram disk together with kernel modules).
On sd card I have next files: MLO, u-boot, uEnv.txt, uImage, uRamDisk, am335x-bonegreen.dtb.
In uEnv.txt I have:
setenv bootargs console=/dev/ttyS0,115200n8 root=/dev/ram0 ramdisk_size=102500 init=/linuxrc rw
load mmc 0:1 ${loadaddr} uImage;
load mmc 0:1 ${rdaddr} uRamDisk;
load mmc 0:1 ${fdtaddr} am335-bonegreen.dtb;
bootm ${loadaddr} ${rdaddr} ${ftdaddr}
I connect serial to usb adapter to debug port and in minicom I see system loading from sd card. If I remove sd card I get debian system in emmc loading.
in the shell of my busybox system I execute:
cd /sys/class/gpio
export 67 > export
cd gpio67
The problem:
‘cat direction’ shows ‘in’, and then ‘cat value’ always shows 0 whatever I apply on P8_8 port.
after ‘echo out > direction’ both ‘cat 0 > value’ or ‘cat 1 > value’ does not change anything on input.
Hardware is ok, because if I remove sd card and load debian from emmc I can get gpio value and can control it by writing 0 or 1 in gpio67/value file.
Im feeling that I lack something in kernel configuration or there is something else in userspace that should made additional system configuration but I don’t have any clue what it could be.
Here is some fragment of kernel .config file:
$ grep 'GPIO_' .config
# CONFIG_INPUT_GPIO_BEEPER is not set
# CONFIG_INPUT_GPIO_DECODER is not set
# CONFIG_INPUT_GPIO_VIBRA is not set
# CONFIG_INPUT_GPIO_ROTARY_ENCODER is not set
# CONFIG_SERIO_GPIO_PS2 is not set
CONFIG_ARCH_HAVE_CUSTOM_GPIO_H=y
CONFIG_GPIO_SYSFS=y
CONFIG_GPIO_CDEV=y
CONFIG_GPIO_CDEV_V1=y
CONFIG_GPIO_GENERIC=y
# CONFIG_GPIO_74XX_MMIO is not set
# CONFIG_GPIO_ALTERA is not set
# CONFIG_GPIO_CADENCE is not set
# CONFIG_GPIO_DWAPB is not set
# CONFIG_GPIO_FTGPIO010 is not set
CONFIG_GPIO_GENERIC_PLATFORM=y
# CONFIG_GPIO_GRGPIO is not set
# CONFIG_GPIO_HLWD is not set
# CONFIG_GPIO_LOGICVC is not set
# CONFIG_GPIO_MB86S7X is not set
# CONFIG_GPIO_MPC8XXX is not set
CONFIG_GPIO_OMAP=y
# CONFIG_GPIO_SAMA5D2_PIOBU is not set
# CONFIG_GPIO_SIFIVE is not set
CONFIG_GPIO_SYSCON=y
# CONFIG_GPIO_XILINX is not set
# CONFIG_GPIO_ZEVIO is not set
# CONFIG_GPIO_AMD_FCH is not set
# CONFIG_GPIO_ADP5588 is not set
# CONFIG_GPIO_ADNP is not set
# CONFIG_GPIO_GW_PLD is not set
# CONFIG_GPIO_MAX7300 is not set
# CONFIG_GPIO_MAX732X is not set
CONFIG_GPIO_PCA953X=m
# CONFIG_GPIO_PCA953X_IRQ is not set
# CONFIG_GPIO_PCA9570 is not set
CONFIG_GPIO_PCF857X=y
# CONFIG_GPIO_TPIC2810 is not set
# CONFIG_GPIO_LP873X is not set
CONFIG_GPIO_LP87565=y
CONFIG_GPIO_PALMAS=y
# CONFIG_GPIO_TPS65218 is not set
# CONFIG_GPIO_TPS65910 is not set
CONFIG_GPIO_TWL4030=y
# CONFIG_GPIO_TWL6040 is not set
# CONFIG_GPIO_74X164 is not set
# CONFIG_GPIO_MAX3191X is not set
# CONFIG_GPIO_MAX7301 is not set
# CONFIG_GPIO_MC33880 is not set
# CONFIG_GPIO_PISOSR is not set
# CONFIG_GPIO_XRA1403 is not set
# CONFIG_GPIO_AGGREGATOR is not set
# CONFIG_GPIO_MOCKUP is not set
# CONFIG_GPIO_VIRTIO is not set
# CONFIG_GPIO_SIM is not set
# CONFIG_POWER_RESET_GPIO_RESTART is not set
# CONFIG_USB_GPIO_VBUS is not set
Thanks in advance for any ideas, documentation links or any other info.
