bb-imager-rs 1.0.12/BeagleY-AI/UART-ttyAMA0 and Additional USB Issues? <fixed and solved>
I used the beagley-ai overlay for ttyAMA0 and the board is refusing to boot.
I thought this was a UART for utilization. I was going to try to port the newer source code to the BeagleY-AI for 3 or 5 DoF Arms.
I was unable to get the video to work on this newer image from bb-imager-rs 1.0.12 and then the refusal to boot happened.
I cannot provide any dmesg output or UART to TTY messaging since the board will not boot.
Update
I took out the .dtbo in question (ttyAMA0) for UART functionality. Now, the board is in a booting state.
The issue now is that video0 - 2 does not work any longer with this error:
-bash: ./matrice_opencv_track.py: cannot execute: required file not found
It is just like a prior example I was testing when example would not allow me to execute the file.
For instance, when I use sudo to test the file:
sudo: unable to execute ./matrice_opencv_track.py: No such file or directory
I know there is a file. I made the file and set permissions…
Update
I will get a debug probe on it…
I cannot figure out why I do not have control of the USB port yet on kernel 7.1.x.
On kernel 7.0.x, everything looked collective and followed orders. I was in control!
Now, with kernel 7.1.x, I change permissions and alter sudoers and try udev rules. I got notta so far. I am not sure exactly how I should go about debugging this effort…
Maybe this time I will look up cannot execute reasons and/or unable to execute ideas but I am pretty sure they lie in depth around some DTS filings. Anyway, if you know and if you are around at some point soon, let this brother know.
Oh and I got the debug probe out to look over the first 5000 lines. Yikes.
unzip my_life.zip is not what I thought it was while retrieving files.
C & P proved more valuable with my high intellect. Ha. It works! Now, onto mechanics. Yikes.
