We have a custom build system to generate our beaglebone images, and a couple of weeks ago the builds started to fail with:
Setting up bone101 (2.1.3-0rcnee13~buster+20200713) ...
Setting up: /var/lib/cloud9/ permissions
Updating Cloud9 examples from: https://github.com/beagleboard/cloud9-examples
fatal: detected dubious ownership in repository at '/var/lib/cloud9'
To add an exception for this directory, call:
git config --global --add safe.directory /var/lib/cloud9
dpkg: error processing package bone101 (--configure):
installed bone101 package post-installation script subprocess returned error exit status 128
Errors were encountered while processing:
bone101
E: Sub-process /usr/bin/dpkg returned an error code (1)
Our build system does the following:
- Clones GitHub - RobertCNelson/omap-image-builder: omap image builder
- Runs
./scripts/install_dependencies.sh - Runs
./RootStock-NG.sh -c custom-bbgg-image
Where the custom bbgg image is a copy of bb.org-debian-buster-iot-v4.19, but changes the default user/pass, adds a python package, and adds a chroot_before_hook script.
Trying to do the above sequence, using the provided -c bb.org-debian-buster-iot-v4.19 instead of our custom one, failed with the same error. I’ve tried to add git config --global --add safe.directory /var/lib/cloud9 to our sequence, but i think because of the chroot shenanigans it doesn’t properly percolate down into the chroot.sh call.
Do you have any recommendations/how was this properly built?
