ezio_H
August 14, 2018, 7:27am
1
Link on ti e2e: https://e2e.ti.com/support/arm/sitara_arm/f/791/t/710355 .
bb_x15 's DCAM1 don’t work on either ubuntu-16.04.3-minimal-armhf-2017-10-10 or TI’s Arogo
On Arogo,I use:
root@am57xx-evm:~# canconfig can0 bitrate 50000 ctrlmode triple-samplin
[ 757.361582] omap_hwmod: dcan1: _wait_target_disable failed
can0 bitrate: 50000, sample-point: 0.875
[ 757.376837] omap_hwmod: dcan1: _wait_target_disable failed
can0 ctrlmode: loopback[OFF], listen-only[OFF], tripple-sampling[ON],one-shot[OFF], berr-reporting[OFF]
root@am57xx-evm:~# ifconfig can0 up
And everything about CAN looks good
root@am57xx-evm:~# lsmod | grep can
can_raw 6589 2
can 29904 1 can_raw
c_can_platform 6638 0
c_can 9718 1 c_can_platform
can_dev 12397 1 c_can
root@am57xx-evm:~# cat /proc/device-tree/ocp/can\@481cc000/status
okay
Except: omap_hwmod: dcan1: _wait_target_disable failed.
What should I do with this error messagge
ezio_H
August 14, 2018, 8:14am
2
arch/arm/mach-omap2/omap_hwmod.c: line 1845
_omap4_disable_module - enable CLKCTRL modulemode on OMAP4
@oh : struct omap_hwmod *
Now can you use dcan on bb-x15?
If yes, please advise me how do open it
I see this link https://e2e.ti.com/support/processors/f/791/p/715990/2645332#pi239031349=1
but it cannot use
เมื่อ วันอังคารที่ 14 สิงหาคม ค.ศ. 2018 14 นาฬิกา 27 นาที 31 วินาที UTC+7, ezio H เขียนว่า:
ezio_H
October 24, 2018, 9:43am
4
Hello ,Thanks for reply.
en…Good news is that DCAN can work in loopback mode !
Bad news is still that DCAN can’t use in nomal mode .I keep consulting the TI engineer.
referring to https://e2e.ti.com/support/processors/f/791/p/739907/2731843#2731843
在 2018年10月11日星期四 UTC+8下午7:53:59,arim…@gmail.com写道:
Within the past week I tried to open DCAN. Now it work.
I can send and receive package through DCAN.
I follow cross-compiler kernel this link
https://www.digikey.com/eewiki/display/linuxonarm/BeagleBoard-X15
After step download kernel I edit file am57xx-beagle-x15-common.dtsi by reference from am57xx-idk-common.dtsi
&dra7_pmx_core {
dcan1_pins_default: dcan1_pins_default {
pinctrl-single,pins = <
DRA7XX_CORE_IOPAD(0x37d0, PIN_OUTPUT_PULLUP | MUX_MODE0) /* dcan1_tx /
DRA7XX_CORE_IOPAD(0x37d4, PIN_INPUT_PULLUP | MUX_MODE0) / dcan1_rx */
dcan1_pins_sleep: dcan1_pins_sleep {
DRA7XX_CORE_IOPAD(0x37d0, MUX_MODE15 | PULL_UP) /* dcan1_tx.off /
DRA7XX_CORE_IOPAD(0x37d4, MUX_MODE15 | PULL_UP) / dcan1_rx.off */
&dcan1 {
status = “okay”;
pinctrl-names = “default”, “sleep”, “active”;
pinctrl-0 = <&dcan1_pins_sleep>;
pinctrl-1 = <&dcan1_pins_sleep>;
pinctrl-2 = <&dcan1_pins_default>;
After login debian I open dcan with command : ip link set can0 type can; ifconfig can0 up;
you can see my forum talked with TI engineer
Thank
เมื่อ วันพุธที่ 24 ตุลาคม ค.ศ. 2018 16 นาฬิกา 43 นาที 09 วินาที UTC+7, ezio H เขียนว่า:
ezio_H
November 2, 2018, 3:08am
6
Thanks for reply.
Good for you ,but I still can’t make dcan1 work using am57xx-beagle-x15-revc.dtb.And what’s more ,I even meet a problem that pin (dcan_tx) cannot be control by cpu,no matter in what pin mode (really really annoying ,and I try another bb_X15 board.Then it worked normally .I think that pin is broken ).
Now intead ,I am using dcan2 ,and it works perfectly ,referring to https://e2e.ti.com/support/processors/f/791/p/739907/2743480#2743480 .
在 2018年10月25日星期四 UTC+8上午2:13:01,arim…@gmail.com写道:
