BB-XM - UART and FLASH memory questions - newbie
Dear all users of BB boards,
i’m totally newbie with that board and would like to ask you some simple questions :
  • how many UART are available on the connectors of the boards ? I need to use 3 distinct UART without handshake (only RX/TX pins)
  • I see a DB9 connector : is that for debug purpose ?
  • on the BB-XM, where is stored the OS ? is there any FLASH chip on the board, or the SD card is used for this purpose ?
thanks you very much for your answer
best regards
Phil
Did you look in the System Reference Manual?
http://circuitco.com/support/index.php?title=BeagleBoard-xM#Hardware_Design_Files
-DB9 is for debug purposes generally, or you can override it for your use.
-OS is stored in the SD card you plug into the board.
-There is no FLASH on the board.
I suggest you go back to my first question.
Hello Gerald,
thanks for your reply
yes I have a look to the reference manual, and I was a little confuse !
best regards
phil
Sorry for the confusion. I thought the feature table was pretty simple. But, If you need me to explain it, let me know.
