For the sake of completeness I will add the complete log here:
July 18, 2024; 19:20, with initrd image.
U-Boot SPL 2024.07 (Jul 04 2024 - 20:44:24 +0000)
SYSFW ABI: 3.1 (firmware rev 0x000a '10.0.1--v10.00.01 (Fiery Fox)')
Trying to boot from MMC2
U-Boot 2024.07 (Jul 04 2024 - 20:44:24 +0000)
SoC: J721E SR1.1 GP
Model: BeagleBoard.org BeagleBone AI-64
DRAM: 2 GiB (effective 4 GiB)
Core: 126 devices, 33 uclasses, devicetree: separate
MMC: mmc@4f80000: 0, mmc@4fb0000: 1
Loading Environment from nowhere... OK
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1
Net: eth0: ethernet@46000000port@1
Press SPACE to abort autoboot in 2 seconds
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
Failed to load 'uEnv.txt'
Scanning for bootflows in all bootdevs
Seq Method State Uclass Part Name Filename
Scanning bootdev 'mmc@4fb0000.bootdev':
0 extlinux ready mmc 1 mmc@4fb0000.bootdev.part_ /extlinux/extlinux.conf
** Booting bootflow 'mmc@4fb0000.bootdev.part_1' with extlinux
1: Linux microSD
Retrieving file: /Image
Retrieving file: /Image-initramfs-beaglebone-ai64.bin
append: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/mmcblk1p2 rw rootfstype=ext4 rootwait net.ifnames=0
Retrieving file: /ti/k3-j721e-beagleboneai64.dtb
ERROR: RD image overlaps OS image (OS=82000000..8ba40000)
Boot failed (err=-14)
1 efi ready mmc 1 mmc@4fb0000.bootdev.part_ /EFI/BOOT/BOOTAA64.EFI
** Booting bootflow 'mmc@4fb0000.bootdev.part_1' with efi
No EFI system partition
Failed to persist EFI variables
Booting /\EFI\BOOT\BOOTAA64.EFI
error: no such device: ((hd0,msdos1)/EFI/BOOT)/EFI/BOOT/grub.cfg.
error: serial port `com0' isn't found.
GNU GRUB version 2.12
�*boot � │
Use the �▲ and �▼ keys to select which entry is highlighted.
Press enter to boot the selected OS, `e' to edit the commands
before booting or `c' for a command-line.
The highlighted entry will be executed automatically in 0s.
Booting `boot'
EFI stub: Booting Linux Kernel...
EFI stub: EFI_RNG_PROTOCOL unavailable
EFI stub: Using DTB from configuration table
EFI stub: Exiting boot services...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Reserved shared memory is enabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[ 0.000000] Linux version 6.1.69-ti (oe-user@oe-host) (aarch64-agl-linux-gcc (GCC) 13.2.0, GNU ld (GNU Binutils) 2.42.0.20240216) #1 SMP PREEMPT_DYNAMIC Mon Jun 10 06:13:20 UTC 2024
[ 0.000000] Machine model: BeagleBoard.org BeagleBone AI-64
[ 0.000000] efi: EFI v2.100 by Das U-Boot
[ 0.000000] efi: RTPROP=0xfce54040 SMBIOS 3.0=0xfdebd000 MEMRESERVE=0xfcd73040
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff]
[ 0.000000] node 0: [mem 0x000000009e800000-0x00000000a8ffffff]
[ 0.000000] node 0: [mem 0x00000000a9000000-0x00000000a9ffffff]
[ 0.000000] node 0: [mem 0x00000000aa000000-0x00000000abbfffff]
[ 0.000000] node 0: [mem 0x00000000abc00000-0x00000000fce53fff]
[ 0.000000] node 0: [mem 0x00000000fce54000-0x00000000fce54fff]
[ 0.000000] node 0: [mem 0x00000000fce55000-0x00000000fce55fff]
[ 0.000000] node 0: [mem 0x00000000fce56000-0x00000000fce77fff]
[ 0.000000] node 0: [mem 0x00000000fce78000-0x00000000fdebcfff]
[ 0.000000] node 0: [mem 0x00000000fdebd000-0x00000000fdebdfff]
[ 0.000000] node 0: [mem 0x00000000fdebe000-0x00000000ffebffff]
[ 0.000000] node 0: [mem 0x00000000ffec0000-0x00000000ffecffff]
[ 0.000000] node 0: [mem 0x00000000ffed0000-0x00000000ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] cma: Reserved 144 MiB at 0x00000000de600000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.5
[ 0.000000] percpu: Embedded 29 pages/cpu s81448 r8192 d29144 u118784
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Spectre-v3a
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: ARM erratum 1742098
[ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 516096
[ 0.000000] Kernel command line: BOOT_IMAGE=/Image-initramfs-beaglebone-ai64.bin root=PARTUUID=dba7902b-02 rootwait rootfstype=ext4
[ 0.000000] Unknown kernel command line parameters "BOOT_IMAGE=/Image-initramfs-beaglebone-ai64.bin", will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[ 0.000000] Memory: 131072K/2097152K available (18304K kernel code, 2912K rwdata, 6764K rodata, 128576K init, 1166K bss, 399404K reserved, 147456K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] ftrace: allocating 57171 entries in 224 pages
[ 0.000000] ftrace: allocated 224 pages with 3 groups
[ 0.000000] trace event string verifier disabled
[ 0.000000] Dynamic Preempt: voluntary
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x0000000080200000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080210000
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.000204] Console: colour dummy device 80x25
[ 0.000533] printk: console [tty0] enabled
[ 0.000563] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.000573] pid_max: default: 32768 minimum: 301
[ 0.000682] LSM: Security Framework initializing
[ 0.000730] landlock: Up and running.
[ 0.000735] Yama: becoming mindful.
[ 0.000812] AppArmor: AppArmor initialized
[ 0.000822] TOMOYO Linux initialized
[ 0.000844] LSM support for eBPF active
[ 0.000922] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.000938] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.002040] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.002056] cblist_init_generic: Setting shift to 1 and lim to 1.
[ 0.002109] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.002116] cblist_init_generic: Setting shift to 1 and lim to 1.
[ 0.002171] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.002178] cblist_init_generic: Setting shift to 1 and lim to 1.
[ 0.002292] rcu: Hierarchical SRCU implementation.
[ 0.002298] rcu: Max phase no-delay instances is 1000.
[ 0.003038] Platform MSI: msi-controller@1820000 domain created
[ 0.003238] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.003403] Remapping and enabling EFI services.
[ 0.003701] smp: Bringing up secondary CPUs ...
[ 0.012435] Detected PIPT I-cache on CPU1
[ 0.012500] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[ 0.012513] GICv3: CPU1: using allocated LPI pending table @0x0000000080220000
[ 0.012544] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[ 0.012624] smp: Brought up 1 node, 2 CPUs
[ 0.012645] SMP: Total of 2 processors activated.
[ 0.012650] CPU features: detected: 32-bit EL0 Support
[ 0.012654] CPU features: detected: 32-bit EL1 Support
[ 0.012660] CPU features: detected: CRC32 instructions
[ 0.012752] CPU: All CPU(s) started at EL2
[ 0.012768] alternatives: applying system-wide alternatives
[ 0.035857] node 0 deferred pages initialised in 20ms
[ 0.036697] devtmpfs: initialized
[ 0.044368] Registered cp15_barrier emulation handler
[ 0.044396] Registered setend emulation handler
[ 0.044581] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.044624] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.047075] pinctrl core: initialized pinctrl subsystem
[ 0.047459] SMBIOS 3.7.0 present.
[ 0.047478] DMI: beagle BeagleBoard.org BeagleBone AI-64/BeagleBoard.org BeagleBone AI-64, BIOS 2024.07 07/01/2024
[ 0.047884] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.048755] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[ 0.048881] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.049029] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.049066] audit: initializing netlink subsys (disabled)
[ 0.049216] audit: type=2000 audit(0.048:1): state=initialized audit_enabled=0 res=1
[ 0.049497] thermal_sys: Registered thermal governor 'fair_share'
[ 0.049501] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.049508] thermal_sys: Registered thermal governor 'step_wise'
[ 0.049512] thermal_sys: Registered thermal governor 'user_space'
[ 0.049517] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.049643] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.049690] ASID allocator initialised with 32768 entries
[ 0.058893] platform 4a00000.dss: Fixed dependency cycle(s) with /bus@100000/dp-bridge@a000000/ports/port@0/endpoint
[ 0.060567] platform connector: Fixed dependency cycle(s) with /bus@100000/dp-bridge@a000000/ports/port@4/endpoint
[ 0.060807] KASLR enabled
[ 0.064962] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.064979] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.064985] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.064989] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[ 0.064994] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.064999] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.065003] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.065007] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[ 0.065851] raid6: skipped pq benchmark and selected neonx8
[ 0.065864] raid6: using neon recovery algorithm
[ 0.066163] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
[ 0.067063] iommu: Default domain type: Translated
[ 0.067074] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.067264] SCSI subsystem initialized
[ 0.067454] usbcore: registered new interface driver usbfs
[ 0.067474] usbcore: registered new interface driver hub
[ 0.067497] usbcore: registered new device driver usb
[ 0.067764] pps_core: LinuxPPS API ver. 1 registered
[ 0.067770] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.067779] PTP clock support registered
[ 0.067919] Registered efivars operations
[ 0.068271] Advanced Linux Sound Architecture Driver Initialized.
[ 0.068621] NetLabel: Initializing
[ 0.068629] NetLabel: domain hash size = 128
[ 0.068633] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.068674] NetLabel: unlabeled traffic allowed by default
[ 0.068866] vgaarb: loaded
[ 0.069200] clocksource: Switched to clocksource arch_sys_counter
[ 0.069506] VFS: Disk quotas dquot_6.6.0
[ 0.069541] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.069637] FS-Cache: Loaded
[ 0.069880] CacheFiles: Loaded
[ 0.070182] AppArmor: AppArmor Filesystem Enabled
[ 0.073895] NET: Registered PF_INET protocol family
[ 0.074042] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.075056] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[ 0.075123] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.075155] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.075295] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.075761] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.076155] MPTCP token hash table entries: 2048 (order: 3, 49152 bytes, linear)
[ 0.076249] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.076291] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.076441] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.081473] RPC: Registered named UNIX socket transport module.
[ 0.081487] RPC: Registered udp transport module.
[ 0.081491] RPC: Registered tcp transport module.
[ 0.081495] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.081503] NET: Registered PF_XDP protocol family
[ 0.081513] PCI: CLS 0 bytes, default 64
[ 0.085569] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.085922] kvm [1]: IPA Size Limit: 44 bits
[ 0.086557] kvm [1]: vgic-v2@6f020000
[ 0.086574] kvm [1]: GIC system register CPU interface enabled
[ 0.086663] kvm [1]: vgic interrupt IRQ9
[ 0.086716] kvm [1]: Hyp mode initialized successfully
[ 0.431895] Initialise system trusted keyrings
[ 0.432118] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[ 0.434852] zbud: loaded
[ 0.436348] NFS: Registering the id_resolver key type
[ 0.436380] Key type id_resolver registered
[ 0.436385] Key type id_legacy registered
[ 0.436433] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.436441] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.436533] fuse: init (API version 7.37)
[ 0.457826] NET: Registered PF_ALG protocol family
[ 0.457854] xor: measuring software checksum speed
[ 0.458976] 8regs : 8845 MB/sec
[ 0.460007] 32regs : 9599 MB/sec
[ 0.461288] arm64_neon : 7740 MB/sec
[ 0.461294] xor: using function: 32regs (9599 MB/sec)
[ 0.461304] Key type asymmetric registered
[ 0.461311] Asymmetric key parser 'x509' registered
[ 0.471011] alg: self-tests for CTR-KDF (hmac(sha256)) passed
[ 0.471110] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.471207] io scheduler mq-deadline registered
[ 0.473670] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[ 0.474094] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[ 0.476846] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 0.478767] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
[ 0.479205] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
[ 0.479692] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
[ 0.480744] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[ 0.482110] SPI driver tps6594 has no spi_device_id for ti,tps6594-q1
[ 0.482124] SPI driver tps6594 has no spi_device_id for ti,tps6593-q1
[ 0.482129] SPI driver tps6594 has no spi_device_id for ti,lp8764-q1
[ 0.482437] megasas: 07.719.03.00-rc1
[ 0.484927] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.484947] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.484981] sky2: driver version 1.30
[ 0.485507] VFIO - User Level meta-driver version: 0.3
[ 0.486071] usbcore: registered new interface driver usbserial_generic
[ 0.486088] usbserial: USB Serial support registered for generic
[ 0.486122] usbcore: registered new interface driver cp210x
[ 0.486133] usbserial: USB Serial support registered for cp210x
[ 0.487016] i2c_dev: i2c /dev entries driver
[ 0.487048] usbcore: registered new interface driver i2c-tiny-usb
[ 0.487756] sdhci: Secure Digital Host Controller Interface driver
[ 0.487763] sdhci: Copyright(c) Pierre Ossman
[ 0.487884] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.488478] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.488767] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.488950] hid: raw HID events driver (C) Jiri Kosina
[ 0.489153] usbcore: registered new interface driver usbhid
[ 0.489161] usbhid: USB HID core driver
[ 0.490017] optee: probing for conduit method.
[ 0.490042] optee: revision 4.2 (12d7c4ee)
[ 0.506478] optee: dynamic shared memory is enabled
[ 0.506715] optee: initialized driver
[ 0.507305] usbcore: registered new interface driver snd-usb-audio
[ 0.507693] NET: Registered PF_INET6 protocol family
[ 0.517033] Segment Routing with IPv6
[ 0.517086] In-situ OAM (IOAM) with IPv6
[ 0.517137] mip6: Mobile IPv6
[ 0.517152] NET: Registered PF_PACKET protocol family
[ 0.517293] Key type dns_resolver registered
[ 0.517301] mpls_gso: MPLS GSO support
[ 0.517641] registered taskstats version 1
[ 0.517661] Loading compiled-in X.509 certificates
[ 0.518171] zswap: loaded using pool lzo/zsmalloc
[ 0.518483] Key type .fscrypt registered
[ 0.518490] Key type fscrypt-provisioning registered
[ 0.519806] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=yes
[ 0.520008] Key type encrypted registered
[ 0.520022] AppArmor: AppArmor sha1 policy hashing enabled
[ 0.520075] ima: secureboot mode disabled
[ 0.520085] ima: No TPM chip found, activating TPM-bypass!
[ 0.520105] ima: Allocated hash algorithm: sha256
[ 0.520140] ima: No architecture policies found
[ 0.520188] evm: Initialising EVM extended attributes:
[ 0.520194] evm: security.selinux
[ 0.520198] evm: security.SMACK64 (disabled)
[ 0.520202] evm: security.SMACK64EXEC (disabled)
[ 0.520206] evm: security.SMACK64TRANSMUTE (disabled)
[ 0.520210] evm: security.SMACK64MMAP (disabled)
[ 0.520214] evm: security.apparmor
[ 0.520217] evm: security.ima
[ 0.520221] evm: security.capability
[ 0.520224] evm: HMAC attrs: 0x1
[ 0.527117] ti-sci 44083000.system-controller: ABI: 3.1 (firmware rev 0x000a '10.0.1--v10.00.01 (Fiery Fox)')
[ 0.553610] ti-sci-clk 44083000.system-controller:clock-controller: recalc-rate failed for dev=152, clk=19, ret=-19
[ 0.553733] ti-sci-clk 44083000.system-controller:clock-controller: recalc-rate failed for dev=152, clk=20, ret=-19
[ 0.553836] ti-sci-clk 44083000.system-controller:clock-controller: recalc-rate failed for dev=152, clk=21, ret=-19
[ 0.570321] omap_i2c 42120000.i2c: bus 0 rev0.12 at 400 kHz
[ 0.570891] omap_i2c 2000000.i2c: bus 4 rev0.12 at 400 kHz
[ 0.571360] omap_i2c 2010000.i2c: bus 5 rev0.12 at 400 kHz
[ 0.571859] omap_i2c 2020000.i2c: bus 2 rev0.12 at 100 kHz
[ 0.572363] omap_i2c 2030000.i2c: bus 6 rev0.12 at 400 kHz
[ 0.572869] omap_i2c 2040000.i2c: bus 3 rev0.12 at 100 kHz
[ 0.573340] omap_i2c 2050000.i2c: bus 7 rev0.12 at 400 kHz
[ 0.573824] omap_i2c 2060000.i2c: bus 1 rev0.12 at 100 kHz
[ 0.574050] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 137 domain created
[ 0.574165] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 131 domain created
[ 0.574276] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 213 domain created
[ 0.574451] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[ 0.584703] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[ 0.584726] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[ 0.584732] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[ 0.586738] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[ 0.586758] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[ 0.586764] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[ 0.587315] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 196, base_baud = 3000000) is a 8250
[ 2.640191] printk: console [ttyS2] enabled
[ 2.646734] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
[ 2.693207] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 2.705948] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 2.714253] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[ 2.727084] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[ 2.734297] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[ 2.740679] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[ 2.751337] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[ 2.861403] mmc0: CQHCI version 5.10
[ 2.867348] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[ 2.874222] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[ 2.881073] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[ 2.887912] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[ 2.894741] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[ 2.905983] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[ 2.906815] j721e-pcie-host 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 2.921494] j721e-pcie-host 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 2.930070] j721e-pcie-host 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 2.938606] j721e-pcie-host 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 2.995133] mmc0: Command Queue Engine enabled
[ 2.999588] mmc0: new HS200 MMC card at address 0001
[ 3.005028] mmcblk0: mmc0:0001 TB2916 14.6 GiB
[ 3.010581] mmcblk0: p1 p2
[ 3.013716] mmcblk0boot0: mmc0:0001 TB2916 4.00 MiB
[ 3.019319] mmcblk0boot1: mmc0:0001 TB2916 4.00 MiB
[ 3.024899] mmcblk0rpmb: mmc0:0001 TB2916 4.00 MiB, chardev (237:0)
[ 3.950122] j721e-pcie-host 2910000.pcie: PCI host bridge to bus 0000:00
[ 3.956825] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 3.962312] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x18001000-0x18010fff])
[ 3.971777] pci_bus 0000:00: root bus resource [mem 0x18011000-0x1fffffff]
[ 3.978664] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
[ 3.984660] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[ 3.994363] pci 0000:00:00.0: supports D1
[ 3.998366] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[ 4.005792] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 4.013940] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 4.020558] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 4.025782] pcieport 0000:00:00.0: PME: Signaling with IRQ 434
[ 4.031778] pcieport 0000:00:00.0: AER: enabled with IRQ 434
[ 4.038515] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[ 4.049784] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
[ 4.062232] cdns-mhdp8546 a000000.dp-bridge: invalid resource
[ 4.068005] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[ 4.083189] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 0
[ 4.090480] tidss 4a00000.dss: [drm] Cannot find any crtc or sizes
[ 4.096804] tidss 4a00000.dss: [drm] Cannot find any crtc or sizes
[ 4.103582] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
[ 4.149205] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 4.161921] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 4.170226] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[ 4.183075] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[ 4.190289] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[ 4.196644] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[ 4.207164] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[ 4.216196] mmc1: CQHCI version 5.10
[ 4.225620] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
[ 4.225851] random: crng init done
[ 4.235785] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 4.248751] ti-sci-clk 44083000.system-controller:clock-controller: is_prepared failed for dev=152, clk=21, ret=-19
[ 4.259363] ti-sci-clk 44083000.system-controller:clock-controller: is_prepared failed for dev=152, clk=20, ret=-19
[ 4.265219] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[ 4.269844] ti-sci-clk 44083000.system-controller:clock-controller: is_prepared failed for dev=152, clk=19, ret=-19
[ 4.294132] ALSA device list:
[ 4.297104] No soundcards found.
[ 4.369414] Freeing unused kernel memory: 128576K
[ 4.383019] Checked W+X mappings: passed, no W+X pages found
[ 4.388725] Run /init as init process
[ 4.396338] mmc1: new high speed SDHC card at address 1234
[ 4.402437] mmcblk1: mmc1:1234 SA16G 14.4 GiB
[ 4.408911] mmcblk1: p1 p2
Starting systemd-udevd version 255.4^
Waiting for removable media...
[ 14.305861] platform bus@100000:wiz@5030000: deferred probe pending
