I have been attempting to setup shared memory between a Linux program and code running on an R5F core. My current attempted setup is to have MCU2_0/R5F0_0 and Linux share a 16mb chunk of memory at 0x90000000. I feel like I am very close to getting things to work, not quite there yet. Probably have a device tree issue. If anyone has guidance that would be awesome.
Current status of things:
- The shared memory at 0x90000000 seems to be half reserved. If I look at /proc/iomem, the 16mb
at 0x90000000 is reserved. From the Linux kernel logs, not so much. - Below I have a test linux program that reads and writes to the memory at 0x90000000. As long
as a don’t use weird alignment, the code works fine. - My R5F firmware will not start if I have the shared memory array uncommented. From system
logs I see this errorbad phdr da 0x90000000 mem 0x1000000. Seems to either be an issue
with my linker script or device tree overlay.
The firmware that I have on the R5F is based off GitHub - FredEckert/bbai64_cortex-r5_example at r5_toggle. The linker script has been modified accordingly to link shared memory at address 0x90000000.
Below I have cut down versions of my R5F linker script, device tree overlay, R5F code, and test linux code:
Here is a cut down snippet showing the parts of my linker script for my R5F firmware that should setup shared memory:
/* R5 memory locations */
__DDR0_ALLOCATED_START = 0xA0000000;
__MCU2_0_ALLOCATED_START = __DDR0_ALLOCATED_START + 0x02000000; /* Same for kernel 5 and 6 */
__MCU2_0_EXT_DATA_BASE = __MCU2_0_ALLOCATED_START + 0x00100000;
__MCU2_0_R5F_MEM_TEXT_BASE = __MCU2_0_ALLOCATED_START + 0x00200000;
__MCU2_0_R5F_MEM_DATA_BASE = __MCU2_0_ALLOCATED_START + 0x00300000;
__MCU2_0_DDR_SPACE_BASE = __MCU2_0_ALLOCATED_START + 0x00400000;
# bla bla bla
MEMORY
# bla bla bla the obvious
/* Shared memory region at 0x90000000 */
DDR0_SHARED_r5f0_0 (rwx) : ORIGIN = 0x90000000, LENGTH = 0x1000000 /* 16MB */
ENTRY("vectors")
SECTIONS
/* The TI libraries will not link without *(.ARM.exidx*) discarded */
/DISCARD/ : {
*(.ARM.exidx*)
# bla bla bla stuff was cut out here
/* This memory is for Linux and the r5f0_0 core to share */
.shared_memory_r5f0_0_and_linux : ALIGN(4096) {
*(.shared_memory_r5f0_0*)
} > DDR0_SHARED_r5f0_0
For my device tree overlay I have this
/dts-v1/;
/plugin/;
#include <dt-bindings/gpio/gpio.h>
#include <dt-bindings/interrupt-controller/arm-gic.h>
#include <dt-bindings/interrupt-controller/irq.h>
#include <dt-bindings/pinctrl/k3.h>
#include <dt-bindings/board/k3-j721e-bone-pins.h>
#include <dt-bindings/soc/ti,sci_pm_domain.h>
#include <dt-bindings/input/linux-event-codes.h>
&{/chosen} {
overlays {
MotorControl.kernel = __TIMESTAMP__;
// enable epwm4b for use from r5f (irrelevant to this post, left here just because)
&bone_pwm_4 {
status = "okay"; // EHRPWM4-B on P9-25
&reserved_memory {
#address-cells = <2>;
#size-cells = <2>;
fragment@1 {
target = <&reserved_memory>;
__overlay__ {
shared_memory_r5f_linux: buffer@90000000 {
compatible = "shared-dma-pool";
reg = <0x0 0x90000000 0x0 0x01000000>; // 16 MB region, gap in k3-j721e-rotos-memory-map.dtsi
no-map;
reusable;
status = "okay";
&mcu_r5fss0_core0 {
fragment@2 {
target = <&main_r5fss0_core0>;
__overlay__ {
memory-region = <&vision_apps_mcu_r5fss0_core0_dma_memory_region>,
<&vision_apps_mcu_r5fss0_core0_memory_region>,
<&shared_memory_r5f_linux>;
Here’s my R5F C code (Cut down for simplicity)
#include <stdint.h>
#include <string.h>
#include <stdio.h>
#include <stdlib.h>
#include <ti/csl/csl_gpio.h>
#include <ti/csl/soc.h>
#define SHARED_MEM_SIZE 0x1000000
// if I uncomment this line the firmware crashes, does not even start
__attribute__((section(".shared_memory_r5f0_0_and_linux"), aligned(4096))) char shared_mem[SHARED_MEM_SIZE];
// if I uncomment this line things work fine, no crash
//__attribute__((section(".log_shared_mem"))) char shared_mem[SOME_SIZE_I_DO_NOT_REMEMBER];
int main()
printf("Program started from main\n");
#define DELAY 20000000
for(int i = 0;; i++)
// Some IO test code was here
for(volatile int j=0; j< DELAY; j++);
// Attempt to use shared memory
strcpy(shared_mem + 0x64, shared_mem);
printf("%c\n", shared_mem[0]);
return 0;
R5F MPU memory regions:
MpuP_RegionConfig gMpuRegionConfig[] = {
// position in this array MATTERS, later stuff wins....INCLUDING UNDEFINED STUFF!
// Complete 32-bit address space
.baseAddr = 0x0u,
.size = our_MpuP_RegionSize_4G,
.attrs = {
.isEnable = 1,
.isCacheable = 0,
.isBufferable = 0, // Maybe could be 1, this is the arm B bit https://developer.arm.com/documentation/ddi0460/d/System-Control/Register-descriptions/c6--MPU-memory-region-programming-registers?lang=en
.isSharable = 0,
.isExecuteNever = 0,
.tex = 1, // 0
.accessPerm = our_MpuP_AP_ALL_RW,
.subregionDisableMask = 0x0u,
// MSRAM region
.baseAddr = 0x70000000u,
.size = our_MpuP_RegionSize_8M,
.attrs = {
.isEnable = 1,
.isCacheable = 1,
.isBufferable = 1,
.isSharable = 0,
.tex = 7, // 5
// DDR region
.baseAddr = 0x80000000u,
.size = our_MpuP_RegionSize_2G,
.attrs = {
.isEnable = 1,
.isCacheable = 1,
.isBufferable = 1,
.isSharable = 0, // 1... If this is set to `1` the R5 runs very slow, like 30x slower
.tex = 7, // 5
// rpmsg region
.baseAddr = 0xA2000000u,
.size = our_MpuP_RegionSize_1M,
.attrs = {
.isEnable = 1,
.isCacheable = 0,
.isBufferable = 0,
.isSharable = 1,
.isExecuteNever = 1,
.tex = 1,
// r5f-linux shared memory region
.baseAddr = 0x90000000u,
.size = our_MpuP_RegionSize_16M,
.attrs = {
.isEnable = 1,
.isCacheable = 0,
.isBufferable = 0,
.isSharable = 1,
.tex = 1,
Here’s my linux code, works fine. It seems that I have to write on some kinda of alignment..
#include <stdio.h>
#include <fcntl.h>
#include <unistd.h>
#include <sys/mman.h>
#include <errno.h>
#include <stdlib.h>
#include <string.h>
#define SHARED_MEM_BASE 0x90000000
int main() {
int fd = open("/dev/mem", O_RDWR | O_SYNC);
if (fd < 0) {
perror("open");
exit(EXIT_FAILURE);
// Map shared memory
void* mapped_base = mmap(NULL, SHARED_MEM_SIZE, PROT_READ | PROT_WRITE, MAP_SHARED, fd, SHARED_MEM_BASE);
if (mapped_base == (void *) -1) {
perror("mmap");
close(fd);
exit(EXIT_FAILURE);
// write and read from shared memory
const char data[4096] = "Tux was here";
printf("Made it to line %d\n",__LINE__);
fflush(stdout);
*((unsigned char *) mapped_base) = 0x55 + *((unsigned char *) mapped_base);
printf("Read from shared memory: %c\n", *((unsigned char *) mapped_base));
// memcpy(mapped_base, data, 31); // bus error
// memcpy(mapped_base, data, 3); // bus error
// memcpy(1 + mapped_base, data, 1); // bus error
memcpy(mapped_base, data, 1); // works
memcpy(mapped_base, data, 2); // works
memcpy(mapped_base, data, 4); // works
memcpy(mapped_base, data, 32); // works
memcpy(mapped_base, data, 4096); // works
printf("Read from shared memory: %c\n", *((unsigned char *) mapped_base)); // works
// printf("Written to shared memory: %s\n", ((unsigned char *) mapped_base)); will crash with bus error
// for (size_t i = 0; i < 10000; i++)
// printf("Read from %d: %s\n", SHARED_MEM_BASE + 0x100, mapped_base + 0x100);
// Clean up
if (munmap(mapped_base, SHARED_MEM_SIZE) == -1) {
perror("munmap");
close(fd);
printf("Yay I made it to the end\n");
return 0;
Error logs and so on:
Here’s journalctl after an attempt to run my r5f code. There’s a bad phdr error.
debian@BeagleBone:~/r5f_firmware$ sudo journalctl -k | tail -5
Dec 13 18:55:16 BeagleBone kernel: remoteproc remoteproc16: powering up 5c00000.r5f
Dec 13 18:55:16 BeagleBone kernel: remoteproc remoteproc16: Booting fw image r5f_r5f0_0_kernel_5.elf, size 22812300
Dec 13 18:55:16 BeagleBone kernel: remoteproc remoteproc16: bad phdr da 0x90000000 mem 0x1000000
Dec 13 18:55:16 BeagleBone kernel: remoteproc remoteproc16: Failed to load program segments: -22
Dec 13 18:55:16 BeagleBone kernel: remoteproc remoteproc16: Boot failed: -22
Here is /proc/iomem showing that 0x90000000 has been successfully reserved by my device tree overlay:
debian@BeagleBone:~/r5f_firmware/tmp_linux_shared_mem_test$ sudo cat /proc/iomem | tail -33
70000000-707fffff : 70000000.sram sram@70000000
80000000-8fffffff : System RAM
82000000-8364ffff : Kernel code
83650000-839fffff : reserved
83a00000-83cfffff : Kernel data
8f6a9000-8f6dcfff : reserved
8f6e1000-8fffffff : reserved
90000000-90ffffff : reserved.................(LOOK AT THIS!)
91000000-9e7fffff : System RAM
91800000-9e7fffff : reserved
9e800000-aeffffff : reserved
af000000-afffffff : System RAM
b0000000-b7ffffff : reserved
b8000000-d7ffffff : System RAM
b8000000-d7ffffff : reserved
d8000000-fcffffff : reserved
fd000000-ffffffff : System RAM
880000000-88fffffff : reserved
890000000-8ffffffff : System RAM
8fb000000-8feffffff : reserved
8ff2fc000-8ff35bfff : reserved
8ff35c000-8ff95cfff : reserved
8ff95d000-8ff99cfff : reserved
8ff99f000-8ff9a0fff : reserved
8ff9a1000-8ff9a1fff : reserved
8ff9a2000-8ff9a7fff : reserved
8ff9a8000-8ffffffff : reserved
4d80800000-4d80847fff : 4d80800000.dsp
4d80e00000-4d80e07fff : 4d80800000.dsp
4d80f00000-4d80f07fff : 4d80800000.dsp
4d81800000-4d81847fff : 4d81800000.dsp
4d81e00000-4d81e07fff : 4d81800000.dsp
4d81f00000-4d81f07fff : 4d81800000.dsp
Here’s some filtered output from dmesg showing that 0x90000000 does not seem to be reserved, or something:
debian@BeagleBone:~/r5f_firmware$ sudo dmesg | egrep "reserved mem|90000000"
[ 0.000000] OF: reserved mem: node buffer@90000000 compatible matching fail
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a8000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a8100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a9000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a9100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@aa000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@aa100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@b2000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
[ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d8000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-queues@fb000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-buffers@fb800000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
[ 0.000000] node 0: [mem 0x0000000090000000-0x0000000090ffffff]
[ 0.000000] node 0: [mem 0x0000000890000000-0x00000008ffffffff]
[ 7.548157] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a9000000
[ 7.627898] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a8000000
[ 7.735405] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@aa000000
[ 8.361383] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
[ 8.368685] remoteproc15#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
[ 8.381330] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
[ 8.407434] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
[ 8.455005] platform 5e00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
[ 8.497513] platform 5f00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000
[ 62.183218] remoteproc remoteproc16: bad phdr da 0x90000000 mem 0x1000000
Random notes;
My Beaglebone is using kernel 5.10, the firmware image is from April 2023.
I am very new to device trees and shared memory, learning this all through struggling with my BeagleBone.
