Hello to all,
After several research I did not find the answer to my question, so I turn to you.
I set up 2 SPI and I tested them, it works correctly.
However, I would like them to be in slave and not in master. Do you know if it is possible with debian and if the SOC supports it ?
If yes, is there a procedure?
I thank you in advance for your answer,
Louis
