[bbai] - [ti-sdk] gpio toggling
I am using beaglebone-ai with processor sdk 06.03.00.106. I am trying to toggle the gpio3_10. connected to a header p9_12.
The changes i did in dts file.
cape_pins: cape_pins {
compatible = “gpio-leds”;
pinctrl-names = “default”;
label = “gpio74”;
gpios = <&gpio3 10 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&cape_pins_default>;
cape_pins_default: cape_pins_default {
pinctrl-single,pins = <
DRA7XX_CORE_IOPAD(0x350C, PIN_OUTPUT | MUX_MODE14)
when i run using the sysfs commands the value is changing but the pin is not toggling.
U-Boot 2019.01-g323d51410c-dirty (Jan 09 2023 - 11:30:56 +0530)
CPU : DRA752-GP ES2.0
Model: BeagleBoard.org BeagleBone AI
Board: BeagleBone AI REV 00A1
DRAM: 1 GiB
MMC: no pinctrl state for default mode
omap_hsmmc_init_setup: timedout waiting for cc2!
mmc@480d1000 - probe failed: -110
OMAP SD/MMC: 0, OMAP SD/MMC: 1no pinctrl state for default mode
Loading Environment from FAT… OK
Net: eth0: ethernet@48484000
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
** Unable to read file boot.scr **
222 bytes read in 2 ms (108.4 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc0 …
Running uenvcmd …
90200 bytes read in 6 ms (14.3 MiB/s)
4456960 bytes read in 199 ms (21.4 MiB/s)
Flattened Device Tree blob at 88080000
Booting using the fdt blob at 0x88080000
Loading Device Tree to 8ffe6000, end 8ffff057 … OK
Starting kernel …
[ 0.000000] Linux version 4.19.94-gbe5389fd85 (atl@Ramesh) (gcc version 8.3.0
(GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #1 S
MP PREEMPT Sat Jan 7 19:37:40 IST 2023
[ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: BeagleBoard.org BeagleBone AI
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000095800000, s
ize 56 MiB
[ 0.000000] OF: reserved mem: initialized node ipu2-memory@95800000, compatib
le id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, s
ize 64 MiB
[ 0.000000] OF: reserved mem: initialized node dsp1-memory@99000000, compatib
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009d000000, s
ize 32 MiB
[ 0.000000] OF: reserved mem: initialized node ipu1-memory@9d000000, compatib
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000009f000000, s
ize 8 MiB
[ 0.000000] OF: reserved mem: initialized node dsp2-memory@9f000000, compatib
[ 0.000000] cma: Reserved 24 MiB at 0x00000000be400000
[ 0.000000] OMAP4: Map 0x00000000bfd00000 to (ptrval) for dram barrier
[ 0.000000] Hit pending asynchronous external abort (FSR=0x00001211) during f
irst unmask, this is most likely caused by a firmware/bootloader bug.
[ 0.000000] DRA752 ES2.0
[ 0.000000] random: get_random_bytes called from start_kernel+0xb4/0x470 with
crng_init=0
[ 0.000000] percpu: Embedded 15 pages/cpu s32396 r8192 d20852 u61440
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 153472
[ 0.000000] Kernel command line: console=ttyS0,115200n8 root=/dev/mmcblk0p2 r
ootfstype=ext4 rootwait
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 439200K/618496K available (10240K kernel code, 335K rwdat
a, 2800K rodata, 2048K init, 268K bss, 23648K reserved, 155648K cma-reserved, 10
3424K highmem)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xe0800000 - 0xff800000 ( 496 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0x(ptrval) - 0x(ptrval) (12256 kB)
[ 0.000000] .init : 0x(ptrval) - 0x(ptrval) (2048 kB)
[ 0.000000] .data : 0x(ptrval) - 0x(ptrval) ( 336 kB)
[ 0.000000] .bss : 0x(ptrval) - 0x(ptrval) ( 269 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] OMAP clockevent source: timer1 at 32786 Hz
[ 0.000000] arch_timer: cp15 timer(s) running at 6.14MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles:
0x16af5adb9, max_idle_ns: 440795202250 ns
[ 0.000005] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 43980
46511023ns
[ 0.000019] Switching to timer-based delay loop, resolution 162ns
[ 0.000294] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff
, max_idle_ns: 58327039986419 ns
[ 0.000304] OMAP clocksource: 32k_counter at 32768 Hz
[ 0.000731] Console: colour dummy device 80x30
[ 0.000777] Calibrating delay loop (skipped), value calculated using timer fr
equency.. 12.29 BogoMIPS (lpj=61475)
[ 0.000792] pid_max: default: 32768 minimum: 301
[ 0.000913] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000927] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001499] CPU: Testing write buffer coherency: ok
[ 0.001537] CPU0: Spectre v2: using ICIALLU workaround
[ 0.001765] /cpus/cpu@0 missing clock-frequency property
[ 0.001786] /cpus/cpu@1 missing clock-frequency property
[ 0.001798] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.059922] Setting up static identity map for 0x80200000 - 0x80200060
[ 0.079929] rcu: Hierarchical SRCU implementation.
[ 0.100122] EFI services will not be available.
[ 0.119988] smp: Bringing up secondary CPUs …
[ 0.200313] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.200319] CPU1: Spectre v2: using ICIALLU workaround
[ 0.200443] smp: Brought up 1 node, 2 CPUs
[ 0.200455] SMP: Total of 2 processors activated (24.59 BogoMIPS).
[ 0.200464] CPU: All CPU(s) started in HYP mode.
[ 0.200472] CPU: Virtualization extensions available.
[ 0.200919] devtmpfs: initialized
[ 0.217718] VFP support v0.3: implementor 41 architecture 4 part 30 variant f
rev 0
[ 0.217978] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma
x_idle_ns: 19112604462750000 ns
[ 0.217997] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 0.220819] pinctrl core: initialized pinctrl subsystem
[ 0.221352] DMI not present or invalid.
[ 0.221633] NET: Registered protocol family 16
[ 0.222765] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.223714] omap_hwmod: l3_main_2 using broken dt data from ocp
[ 0.417890] cpuidle: using governor ladder
[ 0.417925] cpuidle: using governor menu
[ 0.419303] ------------[ cut here ]------------
[ 0.419326] WARNING: CPU: 0 PID: 1 at drivers/bus/omap_l3_noc.c:147 l3_interr
upt_handler+0x330/0x380
[ 0.419337] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER1_P3 (Read)
: Data Access in User mode during Functional access
[ 0.419346] Modules linked in:
[ 0.419361] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.19.94-gbe5389fd85 #1
[ 0.419370] Hardware name: Generic DRA74X (Flattened Device Tree)
[ 0.419378] Backtrace:
[ 0.419397] [] (dump_backtrace) from [] (show_stack+0x18/
0x1c)
[ 0.419410] r7:c0dfdec4 r6:60000193 r5:00000000 r4:c12506dc
[ 0.419426] [] (show_stack) from [] (dump_stack+0x9c/0xb0
[ 0.419442] [] (dump_stack) from [] (__warn+0xdc/0xf8)
[ 0.419453] r7:c0dfdec4 r6:00000009 r5:00000000 r4:df87b8ec
[ 0.419465] [] (_warn) from [] (warn_slowpath_fmt+0x50/0
x6c)
[ 0.419478] r9:df9cf9c0 r8:e0882164 r7:c0dfddf0 r6:c0dfdd30 r5:c0dfde94 r4:c
1204c48
[ 0.419491] [] (warn_slowpath_fmt) from [] (l3_interrupt
handler+0x330/0x380)
[ 0.419501] r3:dfa030c0 r2:c0dfde94
[ 0.419510] r5:00000002 r4:80080003
[ 0.419526] [] (l3_interrupt_handler) from [] (__handle_i
rq_event_percpu+0x68/0x140)
[ 0.419539] r10:c12522f8 r9:df9fef00 r8:00000017 r7:df87ba18 r6:00000000 r5:
df9fef68
[ 0.419547] r4:dfa03580
[ 0.419562] [] (_handle_irq_event_percpu) from [] (handl
e_irq_event_percpu+0x34/0x88)
[ 0.419573] r10:60000013 r9:df87a000 r8:df80c000 r7:00000001 r6:df9fef00 r5:
df9fef68
[ 0.419581] r4:c1204c48
[ 0.419595] [] (handle_irq_event_percpu) from [] (handle
irq_event+0x40/0x64)
[ 0.419605] r6:c120a434 r5:df9fef68 r4:df9fef00
[ 0.419618] [] (handle_irq_event) from [] (handle_fasteoi
_irq+0xc0/0x168)
[ 0.419629] r7:00000001 r6:c120a434 r5:df9fef68 r4:df9fef00
[ 0.419641] [] (handle_fasteoi_irq) from [] (generic_hand
le_irq+0x2c/0x3c)
[ 0.419652] r7:00000001 r6:00000000 r5:00000000 r4:c1068cfc
[ 0.419665] [] (generic_handle_irq) from [] (__handle_dom
ain_irq+0x64/0xbc)
[ 0.419679] [] (_handle_domain_irq) from [] (gic_handle
irq+0x44/0x80)
[ 0.419690] r9:df87a000 r8:fa213000 r7:df87bae0 r6:fa212000 r5:fa21200c r4:c
1205104
[ 0.419704] [] (gic_handle_irq) from [] (__irq_svc+0x58/0
x8c)
[ 0.419713] Exception stack(0xdf87bae0 to 0xdf87bb28)
[ 0.419725] bae0: df9fef68 60000013 00000004 00000005 df9fef00 dfa03580 00000
000 00000017
[ 0.419737] bb00: df9fefd0 df9fef68 60000013 df87bb3c df87bb40 df87bb30 c028b
9ec c0a2f61c
[ 0.419746] bb20: 60000013 ffffffff
[ 0.419758] r9:df87a000 r8:df9fefd0 r7:df87bb14 r6:ffffffff r5:60000013 r4:c
0a2f61c
[ 0.419775] [] (_raw_spin_unlock_irqrestore) from [] (__s
etup_irq+0x3bc/0x718)
[ 0.419789] [] (_setup_irq) from [] (request_threaded_ir
q+0xe0/0x154)
[ 0.419801] r10:df9fef14 r9:00000000 r8:00000017 r7:00000000 r6:df9fef00 r5:
00000000
[ 0.419809] r4:dfa03580
[ 0.419823] [] (request_threaded_irq) from [] (devm_reque
st_threaded_irq+0x70/0xc4)
[ 0.419835] r10:00000000 r9:c0566dec r8:df9f4e10 r7:00000017 r6:df9cf9c0 r5:
df9cfcc0
[ 0.419843] r4:c0dfdc60 r3:00000000
[ 0.419857] [] (devm_request_threaded_irq) from [] (omap
l3_probe+0x1d4/0x27c)
[ 0.419868] r10:00000002 r9:df9cf9c0 r8:df9f4e10 r7:c1288aec r6:00000008 r5:
df9cf9c0
[ 0.419876] r4:00000000
[ 0.419892] [] (omap_l3_probe) from [] (platform_drv_prob
e+0x50/0xa0)
[ 0.419903] r10:00000000 r9:c122425c r8:00000000 r7:00000000 r6:c122425c r5:
00000000
[ 0.419911] r4:df9f4e10
[ 0.419925] [] (platform_drv_probe) from [] (really_probe
+0x204/0x2c0)
[ 0.419935] r7:00000000 r6:c128d988 r5:df9f4e10 r4:c128d984
[ 0.419948] [] (really_probe) from [] (driver_probe_devic
e+0x68/0x180)
[ 0.419960] r10:00000000 r9:c128d960 r8:00000001 r7:c06c6828 r6:df9f4e10 r5:
c122425c
[ 0.419968] r4:df9f4e10 r3:00000000
[ 0.419982] [] (driver_probe_device) from [] (__device_at
tach_driver+0xa4/0xc8)
[ 0.419993] r9:c128d960 r8:00000001 r7:c06c6828 r6:df9f4e10 r5:df87bd04 r4:c
122425c
[ 0.420006] [] (_device_attach_driver) from [] (bus_for
each_drv+0x88/0xcc)
[ 0.420017] r7:c06c6828 r6:df87bd04 r5:c1204c48 r4:00000000
[ 0.420029] [] (bus_for_each_drv) from [] (_device_attac
h+0xd8/0x140)
[ 0.420039] r7:c1236f48 r6:df9f4e44 r5:c1204c48 r4:df9f4e10
[ 0.420052] [] (device_attach) from [] (device_initial
probe+0x14/0x18)
[ 0.420063] r8:df9f4e10 r7:c1236f48 r6:c12370f0 r5:df9f4e10 r4:df9f4e18
[ 0.420076] [] (device_initial_probe) from [] (bus_probe
device+0x8c/0x94)
[ 0.420088] [] (bus_probe_device) from [] (device_add+0x3
7c/0x620)
[ 0.420098] r7:c1236f48 r6:00000000 r5:c1204c48 r4:df9f4e18
[ 0.420113] [] (device_add) from [] (of_device_add+0x3c/0
x44)
[ 0.420125] r10:00000000 r9:c1213418 r8:00000000 r7:dff767bc r6:00000000 r5:
00000000
[ 0.420133] r4:df9f4e00
[ 0.420147] [] (of_device_add) from [] (of_platform_devic
e_create_pdata+0x98/0xc0)
[ 0.420163] [] (of_platform_device_create_pdata) from []
(of_platform_bus_create+0x1a4/0x248)
[ 0.420174] r9:c1213418 r8:c1213418 r7:00000000 r6:00000000 r5:c1204c48 r4:d
ff7676c
[ 0.420189] [] (of_platform_bus_create) from [] (of_platf
orm_populate+0x74/0xd4)
[ 0.420200] r10:00000001 r9:00000000 r8:c1213418 r7:c1053ccc r6:00000000 r5:
dff74cfc
[ 0.420208] r4:dff7676c
[ 0.420225] [] (of_platform_populate) from [] (pdata_quir
ks_init+0x78/0x88)
[ 0.420236] r10:c1060768 r9:c104b828 r8:00000000 r7:c1003ca0 r6:ffffe000 r5:
c1204c48
[ 0.420244] r4:c1053ccc
[ 0.420257] [] (pdata_quirks_init) from [] (omap_generic
init+0x18/0x20)
[ 0.420266] r5:c1204c48 r4:c1253e00
[ 0.420281] [] (omap_generic_init) from [] (customize_mac
hine+0x28/0x30)
[ 0.420296] [] (customize_machine) from [] (do_one_initca
ll+0x84/0x1b0)
[ 0.420309] [] (do_one_initcall) from [] (kernel_init_fre
eable+0x1c4/0x258)
[ 0.420320] r8:c104b848 r7:c10004f0 r6:c1253e00 r5:c1253e00 r4:00000004
[ 0.420333] [] (kernel_init_freeable) from [] (kernel_ini
t+0x10/0x11c)
[ 0.420344] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:
c0a29428
[ 0.420352] r4:00000000
[ 0.420364] [] (kernel_init) from [] (ret_from_fork+0x14/
0x3c)
[ 0.420373] Exception stack(0xdf87bfb0 to 0xdf87bff8)
[ 0.420383] bfa0: 00000000 00000000 00000
000 00000000
[ 0.420394] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000
000 00000000
[ 0.420404] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 0.420413] r5:c0a29428 r4:00000000
[ 0.420426] —[ end trace 0676312ef42d0b4b ]—
[ 0.429102] OMAP GPIO hardware version 0.1
[ 0.453848] No ATAGs?
[ 0.453920] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint
registers.
[ 0.453935] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.454773] OMAP DMA hardware revision 0.0
[ 0.466251] edma 43300000.edma: memcpy is disabled
[ 0.469705] edma 43300000.edma: TI EDMA DMA engine driver
[ 0.476922] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (
LinkedList1/2/3 supported)
[ 0.480516] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[ 0.480737] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[ 0.481000] omap-iommu 58882000.mmu: 58882000.mmu registered
[ 0.481243] omap-iommu 55082000.mmu: 55082000.mmu registered
[ 0.481603] omap-iommu 41501000.mmu: 41501000.mmu registered
[ 0.481788] omap-iommu 41502000.mmu: 41502000.mmu registered
[ 0.482069] iommu: Adding device 58820000.ipu to group 1
[ 0.482156] iommu: Adding device 55020000.ipu to group 2
[ 0.482287] iommu: Adding device 40800000.dsp to group 0
[ 0.482507] iommu: Adding device 41000000.dsp to group 3
[ 0.483733] SCSI subsystem initialized
[ 0.484768] palmas 0-0058: Irq flag is 0x00000008
[ 0.513580] palmas 0-0058: Muxing GPIO 2b, PWM 0, LED 0
[ 0.515280] SMPS12: supplied by regulator-dummy
[ 0.516929] SMPS3: supplied by vdd_5v
[ 0.518440] SMPS45: supplied by regulator-dummy
[ 0.520225] SMPS6: supplied by vdd_5v
[ 0.521853] SMPS7: supplied by vdd_5v
[ 0.523627] SMPS8: supplied by vdd_5v
[ 0.524817] SMPS9: supplied by vdd_5v
[ 0.525180] random: fast init done
[ 0.525728] LDO1: supplied by vdd_5v
[ 0.541245] LDO2: supplied by vdd_5v
[ 0.561123] LDO3: supplied by vdd_5v
[ 0.581138] LDO4: supplied by vdd_5v
[ 0.601167] LDO5: supplied by regulator-dummy
[ 0.601822] LDO6: supplied by regulator-dummy
[ 0.602468] LDO7: supplied by regulator-dummy
[ 0.603111] LDO8: supplied by regulator-dummy
[ 0.603759] LDO9: supplied by vdd_5v
[ 0.621495] LDOLN: supplied by vdd_5v
[ 0.641209] LDOUSB: supplied by vdd_5v
[ 0.663391] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[ 0.663889] omap_i2c 4807a000.i2c: bus 3 rev0.12 at 100 kHz
[ 0.664081] media: Linux media interface: v0.10
[ 0.664118] videodev: Linux video capture interface: v2.00
[ 0.664193] pps_core: LinuxPPS API ver. 1 registered
[ 0.664202] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome
tti giometti@linux.it
[ 0.664224] PTP clock support registered
[ 0.664255] EDAC MC: Ver: 3.0.0
[ 0.665028] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[ 0.665276] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
[ 0.680834] Advanced Linux Sound Architecture Driver Initialized.
[ 0.681606] clocksource: Switched to clocksource arch_sys_counter
[ 0.689954] NET: Registered protocol family 2
[ 0.690541] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144
bytes)
[ 0.690570] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.690609] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.690898] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.690980] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.691005] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.691129] NET: Registered protocol family 1
[ 0.711570] RPC: Registered named UNIX socket transport module.
[ 0.711581] RPC: Registered udp transport module.
[ 0.711590] RPC: Registered tcp transport module.
[ 0.711625] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.712607] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[ 0.712802] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counte
rs available
[ 0.713784] Initialise system trusted keyrings
[ 0.713918] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 0.719008] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.729513] NFS: Registering the id_resolver key type
[ 0.729540] Key type id_resolver registered
[ 0.729550] Key type id_legacy registered
[ 0.729591] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.731254] Key type asymmetric registered
[ 0.731266] Asymmetric key parser ‘x509’ registered
[ 0.731317] bounce: pool size: 64 pages
[ 0.731351] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2
45)
[ 0.731362] io scheduler noop registered
[ 0.731372] io scheduler deadline registered
[ 0.731468] io scheduler cfq registered (default)
[ 0.731479] io scheduler mq-deadline registered
[ 0.731489] io scheduler kyber registered
[ 0.736692] pinctrl-single 4a003400.pinmux: 282 pins, size 1128
[ 0.743880] vtt_fixed: supplied by smps3
[ 0.793057] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 0.796592] console [ttyS0] disabled
[ 0.796648] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 43, base_baud =
3000000) is a 8250
[ 2.419161] console [ttyS0] enabled
[ 2.423613] 48068000.serial: ttyS5 at MMIO 0x48068000 (irq = 44, base_baud =
3000000) is a 8250
[ 2.434472] omap_rng 48090000.rng: Random Number Generator ver. 20
[ 2.435028] random: crng init done
[ 2.444298] omapdss_dss 58000000.dss: Linked as a consumer to regulator.20
[ 2.451328] DSS: OMAP DSS rev 6.1
[ 2.457584] omapdss_hdmi5 58040000.encoder: Linked as a consumer to regulator
.14
[ 2.465118] omapdss_hdmi5 58040000.encoder: Dropping the link to regulator.14
[ 2.485165] brd: module loaded
[ 2.494822] loop: module loaded
[ 2.502819] libphy: Fixed MDIO Bus: probed
[ 2.561631] davinci_mdio 48485000.mdio: davinci mdio revision 1.6, bus freq 1
000000
[ 2.569326] libphy: 48485000.mdio: probed
[ 2.575485] davinci_mdio 48485000.mdio: phy[4]: device 48485000.mdio:04, driv
er Atheros 8035 ethernet
[ 2.585277] cpsw 48484000.ethernet: Detected MACID = 50:51:a9:9b:65:f6
[ 2.591916] cpsw 48484000.ethernet: initialized cpsw ale version 1.4
[ 2.598300] cpsw 48484000.ethernet: ALE Table size 1024
[ 2.603606] cpsw 48484000.ethernet: cpts: overflow check period 500 (jiffies)
[ 2.612102] i2c /dev entries driver
[ 2.620632] cpu cpu0: Linked as a consumer to regulator.4
[ 2.626158] cpu cpu0: Linked as a consumer to regulator.27
[ 2.633687] sdhci: Secure Digital Host Controller Interface driver
[ 2.639894] sdhci: Copyright(c) Pierre Ossman
[ 2.644884] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.651154] omap_gpio 4805d000.gpio: Could not set line 27 debounce to 200000
microseconds (-22)
[ 2.659990] sdhci-omap 4809c000.mmc: Got CD GPIO
[ 2.664803] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.26
[ 2.671959] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.11
[ 2.678826] sdhci-omap 4809c000.mmc: Dropping the link to regulator.11
[ 2.685615] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.10
[ 2.692636] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.11
[ 2.699590] sdhci-omap 4809c000.mmc: no pinctrl state for sdr104 mode
[ 2.706100] sdhci-omap 4809c000.mmc: no pinctrl state for ddr50 mode
[ 2.712495] sdhci-omap 4809c000.mmc: no pinctrl state for sdr50 mode
[ 2.718874] sdhci-omap 4809c000.mmc: no pinctrl state for sdr25 mode
[ 2.725278] sdhci-omap 4809c000.mmc: no pinctrl state for sdr12 mode
[ 2.731683] sdhci-omap 4809c000.mmc: no pinctrl state for ddr_1_8v mode
[ 2.738323] sdhci-omap 4809c000.mmc: no pinctrl state for ddr_3_3v mode
[ 2.744973] sdhci-omap 4809c000.mmc: no pinctrl state for hs mode
[ 2.751089] sdhci-omap 4809c000.mmc: no pinctrl state for hs mode
[ 2.757230] sdhci-omap 4809c000.mmc: no pinctrl state for hs200_1_8v mode
[ 2.790628] mmc0: SDHCI controller on 4809c000.mmc [4809c000.mmc] using ADMA
[ 2.798178] sdhci-omap 480b4000.mmc: allocated mmc-pwrseq
[ 2.803968] sdhci-omap 480b4000.mmc: Linked as a consumer to regulator.12
[ 2.811176] sdhci-omap 480b4000.mmc: Dropping the link to regulator.12
[ 2.818302] sdhci-omap 480b4000.mmc: Linked as a consumer to regulator.12
[ 2.851406] mmc0: host does not support reading read-only switch, assuming wr
ite-enable
[ 2.859481] mmc1: SDHCI controller on 480b4000.mmc [480b4000.mmc] using ADMA
[ 2.866863] mmc0: new SDHC card at address 59b4
[ 2.871922] sdhci-omap 480d1000.mmc: allocated mmc-pwrseq
[ 2.877450] sdhci-omap 480d1000.mmc: 480d1000.mmc supply vqmmc not found, usi
ng dummy regulator
[ 2.882171] mmcblk0: mmc0:59b4 USD 14.9 GiB
[ 2.886348] sdhci-omap 480d1000.mmc: Linked as a consumer to regulator.0
[ 2.897510] sdhci-omap 480d1000.mmc: Dropping the link to regulator.0
[ 2.905579] sdhci-omap 480d1000.mmc: Linked as a consumer to regulator.10
[ 2.912686] sdhci-omap 480d1000.mmc: Cannot get pinctrl
[ 2.918104] mmcblk0: p1 p2
[ 2.918239] sdhci-omap 480d1000.mmc: Dropping the link to regulator.10
[ 2.929711] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.939525] NET: Registered protocol family 10
[ 2.944625] Segment Routing with IPv6
[ 2.948378] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 2.954799] NET: Registered protocol family 17
[ 2.959463] Key type dns_resolver registered
[ 2.963897] Registering SWP/SWPB emulation handler
[ 2.968733] omap_voltage_late_init: Voltage driver support not added
[ 2.975145] Power Management for TI OMAP4+ devices.
[ 2.980596] Loading compiled-in X.509 certificates
[ 2.994412] mmc1: new HS200 MMC card at address 0001
[ 3.010267] mmcblk1: mmc1:0001 TB2916 14.6 GiB
[ 3.010683] dmm 4e000000.dmm: workaround for errata i878 in use
[ 3.015430] mmcblk1boot0: mmc1:0001 TB2916 partition 1 4.00 MiB
[ 3.022326] dmm 4e000000.dmm: initialized all PAT entries
[ 3.027264] mmcblk1boot1: mmc1:0001 TB2916 partition 2 4.00 MiB
[ 3.038339] mmcblk1rpmb: mmc1:0001 TB2916 partition 3 4.00 MiB, chardev (244:
0)
[ 3.038574] omapdss_hdmi5 58040000.encoder: Linked as a consumer to regulator
.14
[ 3.053224] omapdss_hdmi5 58040000.encoder: Dropping the link to regulator.14
[ 3.061855] omapdss_hdmi5 58040000.encoder: Linked as a consumer to regulator
.14
[ 3.069363] mmcblk1: p1
[ 3.073239] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_compone
nt_ops)
[ 3.081230] omapdss_dss 58000000.dss: bound 58040000.encoder (ops hdmi5_compo
nent_ops)
[ 3.089989] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 3.096660] [drm] No driver support for vblank timestamp query.
[ 3.103675] omapdss error: HDMI I2C Master Error
[ 3.111728] [drm] Enabling DMM ywrap scrolling
[ 3.120160] Console: switching to colour frame buffer device 128x48
[ 3.130493] omapdrm omapdrm.0: fb0: omapdrm frame buffer device
[ 3.137021] [drm] Initialized omapdrm 1.0.0 20110917 for omapdrm.0 on minor 0
[ 3.144639] leds-gpio cape_pins: ignoring dependency for device, assuming no
driver
[ 3.152725] hctosys: unable to open rtc device (rtc0)
[ 3.158333] ALSA device list:
[ 3.161310] No soundcards found.
[ 3.167959] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesyst
em
[ 3.175325] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 4.152816] omapdss error: HDMI I2C Master Error
[ 4.877186] EXT4-fs (mmcblk0p2): recovery complete
[ 4.894411] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. O
pts: (null)
[ 4.902589] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 4.925337] devtmpfs: mounted
[ 4.929332] Freeing unused kernel memory: 2048K
[ 4.934197] Run /sbin/init as init process
[ 5.481942] systemd[1]: System time before build time, advancing clock.
[ 5.537260] systemd[1]: systemd 239 running in system mode. (+PAM -AUDIT -SEL
INUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +
XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybr
id)
[ 5.559254] systemd[1]: Detected architecture arm.
Welcome to Arago 2019.11!
[ 5.613650] systemd[1]: Set hostname to .
[ 5.930833] systemd[1]: File /lib/systemd/system/systemd-journald.service:36
configures an IP firewall (IPAddressDeny=any), but the local system does not sup
port BPF/cgroup based firewalling.
[ 5.948025] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warni
ng is only shown for the first loaded unit using IP firewalling.)
[ 6.203649] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 6.232656] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 6.264520] systemd[1]: Created slice system-getty.slice.
[ OK ] Created slice system-getty.slice.
[ 6.291884] systemd[1]: Started Forward Password Requests to Wall Directory W
atch.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ 6.331727] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ OK ] Listening on udev Control Socket.
[ OK ] Listening on Journal Socket.
Mounting Kernel Debug File System…
Mounting Temporary Directory (/tmp)…
Starting Load Kernel Modules…
Starting udev Coldplug all Devices…
[ OK ] Started Hardware RNG Entropy Gatherer Daemon.
[ OK ] Listening on Process Core Dump Socket.
[ 6.632206] cmemk: loading out-of-tree module taints kernel.
[ 6.652817] CMEMK module: reference Linux version 4.19.94
[ 6.658845] allocated heap buffer 0x40500000 of size 0x100000
[ 6.669807] cmemk initialized
[ OK ] Created slice User and Session Slice.
[ 6.693668] cryptodev: driver 1.9 loaded.
[ OK ] Reached target Slices.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Reached target Paths.
[ 6.786318] usbcore: registered new interface driver usbfs
[ 6.792058] usbcore: registered new interface driver hub
[ 6.797481] usbcore: registered new device driver usb
[ OK ] Listening on Journal Socket (/dev/log).
[ 6.827907] usbcore: registered new interface driver ftdi_sio
[ 6.833809] usbserial: USB Serial support registered for FTDI USB Serial Devi
ce
Mounting POSIX Message Queue File System…
[ OK ] Listening on initctl Compatibility Named Pipe.
Starting File System Check on Root Device…
[ OK ] Created slice system-serial\x2dgetty.slice.
Starting Journal Service…
[ OK ] Mounted Kernel Debug File System.
[ OK ] Mounted Temporary Directory (/tmp).
[ OK ] Started Load Kernel Modules.
[ OK ] Mounted POSIX Message Queue File System.
Mounting Kernel Configuration File System…
Starting Apply Kernel Variables…
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Journal Service.
[ OK ] Started File System Check on Root Device.
Starting Remount Root and Kernel File Systems…
[ 7.241533] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ OK ] Started Remount Root and Kernel File Systems.
Starting Flush Journal to Persistent Storage…
Starting Create Static Device Nodes in /dev…
[ 7.359606] systemd-journald[100]: Received request to flush runtime journal
from PID 1
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Started udev Coldplug all Devices.
[ OK ] Reached target Local File Systems (Pre).
Mounting /media/ram…
Mounting /var/volatile…
[ OK ] Reached target Containers.
Starting udev Kernel Device Manager…
[ OK ] Mounted /media/ram.
[ OK ] Mounted /var/volatile.
Starting Load/Save Random Seed…
[ OK ] Reached target Local File Systems.
Starting Create Volatile Files and Directories…
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Load/Save Random Seed.
[ OK ] Started Create Volatile Files and Directories.
Starting Update UTMP about System Boot/Shutdown…
Starting Network Time Synchronization…
Starting Network Service…
[ 8.072606] omap-rproc 58820000.ipu: ignoring dependency for device, assuming
no driver
[ 8.080924] omap-rproc 58820000.ipu: ignoring dependency for device, assuming
no driver
[ OK ] Started Update UTMP about System Boot/Shutdow[ 8.109712] omap-rproc
58820000.ipu: assigned reserved memory node ipu1-memory@9d000000
n.
[ 8.132471] remoteproc remoteproc0: 58820000.ipu is available
[ 8.148900] leds-gpio cape_pins: ignoring dependency for device, assuming no
driver
[ 8.158151] omap-rproc 55020000.ipu: ignoring dependency for device, assuming
no driver
[ 8.191891] omap-rproc 55020000.ipu: ignoring dependency for device, assuming
no driver
[ 8.241928] omap-rproc 55020000.ipu: assigned reserved memory node ipu2-memor
y@95800000
[ 8.250055] remoteproc remoteproc1: 55020000.ipu is available
[ 8.296607] leds-gpio cape_pins: ignoring dependency for device, assuming no
driver
[ 8.304534] omap-rproc 40800000.dsp: ignoring dependency for device, assuming
no driver
[ 8.351776] omap-rproc 40800000.dsp: ignoring dependency for device, assuming
no driver
[ 8.359824] omap-rproc 40800000.dsp: assigned reserved memory node dsp1-memor
y@99000000
[ 8.392129] remoteproc remoteproc2: 40800000.dsp is available
[ 8.400246] omap-rproc 41000000.dsp: ignoring dependency for device, assuming
no driver
[ 8.412910] omap-rproc 41000000.dsp: ignoring dependency for device, assuming
no driver
[ 8.420957] omap-rproc 41000000.dsp: assigned reserved memory node dsp2-memor
y@9f000000
[ 8.430664] leds-gpio cape_pins: ignoring dependency for device, assuming no
driver
[ 8.454853] remoteproc remoteproc3: 41000000.dsp is available
[ OK ] Found device /dev/ttyS0.
[ 8.494008] leds-gpio cape_pins: ignoring dependency for device, assuming no
driver
[ 8.675520] Driver for 1-wire Dallas network protocol.
[ 8.687558] palmas-rtc 48070000.i2c:tps659038@58:tps659038_rtc: rtc core: reg
istered 48070000.i2c:tps659038@58:tps659038_rtc as rtc0
[ 8.687987] leds-gpio cape_pins: ignoring dependency for device, assuming no
driver
[ 8.725801] leds-gpio cape_pins: ignoring dependency for device, assuming no
driver
[ 8.871560] omap_rtc 48838000.rtc: registered as rtc1
[ 8.879106] leds-gpio cape_pins: ignoring dependency for device, assuming no
driver
[ 9.123637] leds-gpio cape_pins: ignoring dependency for device, assuming no
driver
[ 9.161654] omap_hdq 480b2000.1w: OMAP HDQ Hardware Rev 0.:. Driver in Interr
upt mode
[ 9.372372] leds-gpio cape_pins: ignoring dependency for device, assuming no
driver
[ 9.381225] w1_master_driver w1_bus_master1: Attaching one wire slave 01.0000
00000000 crc 3d
[ 9.392417] leds-gpio cape_pins: ignoring dependency for device, assuming no
driver
[ 9.396403] w1_master_driver w1_bus_master1: Family 1 for 01.000000000000.3d
is not registered.
[ 9.410920] leds-gpio cape_pins: ignoring dependency for device, assuming no
driver
[ 9.533175] phy phy-4a084000.phy.2: Linked as a consumer to regulator.21
[ 9.546234] leds-gpio cape_pins: ignoring dependency for device, assuming no
driver
[ 9.554366] phy phy-4a085000.phy.3: Linked as a consumer to regulator.21
[ 9.561676] leds-gpio cape_pins: ignoring dependency for device, assuming no
driver
[ 9.742129] remoteproc remoteproc1: powering up 55020000.ipu
[ 9.747826] remoteproc remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size
3747220
[ 9.755727] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
[ 9.816562] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 9.822134] remoteproc remoteproc1: registered virtio0 (type 7)
[ 9.824279] virtio_rpmsg_bus virtio0: creating channel rpmsg-rpc addr 0x65
[ 9.828077] remoteproc remoteproc1: remote processor 55020000.ipu is now up
[ 9.829173] leds-gpio cape_pins: ignoring dependency for device, assuming no
driver
[ 9.851745] virtio_rpmsg_bus virtio0: creating channel rpmsg-rpc addr 0x66
[ 9.877108] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 9.884694] leds-gpio cape_pins: ignoring dependency for device, assuming no
driver
[ 9.893710] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
[ OK ] Started Network Time Synchronization.
[ 9.907600] leds-gpio cape_pins: ignoring dependency for device, assuming no
driver
[ OK ] Reached target System Initialization.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on RPCbind Server Activation Socket.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ 10.090941] remoteproc remoteproc0: powering up 58820000.ipu
[ 10.097397] remoteproc remoteproc0: Booting fw image dra7-ipu1-fw.xem4, size
6887428
[ 10.108803] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
[ 10.110869] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 10.120870] remoteproc remoteproc0: registered virtio1 (type 7)
[ 10.140135] omap-des 480a5000.des: will run requests pump with realtime prior
ity
[ 10.141713] remoteproc remoteproc0: remote processor 58820000.ipu is now up
[ 10.164444] leds-gpio cape_pins: ignoring dependency for device, assuming no
driver
[ 10.185196] leds-gpio cape_pins: ignoring dependency for device, assuming no
driver
[ 10.282126] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
[ 10.289120] omap-aes 4b500000.aes: will run requests pump with realtime prior
ity
[ 10.298055] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
[ 10.304412] leds-gpio cape_pins: ignoring dependency for device, assuming no
driver
[ 10.312673] omap-aes 4b700000.aes: will run requests pump with realtime prior
ity
[ 10.322235] leds-gpio cape_pins: ignoring dependency for device, assuming no
driver
[ OK ] Listening on dropbear.socket.
[ 10.343690] net eth0: initializing cpsw version 1.15 (0)
[ OK ] Listening on D-Bus System Message Bus Socket.
[ 10.455405] Atheros 8035 ethernet 48485000.mdio:04: attached PHY driver [Athe
ros 8035 ethernet] (mii_bus:phy_addr=48485000.mdio:04, irq=POLL)
[ OK ] Reached target Sockets.
[ 10.484546] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ OK ] Reached target Basic System.
[ 10.583926] omap_gpio 48057000.gpio: Could not set line 13 debounce to 20000
microseconds (-22)
Starting RPC Bind Service…
[ 10.606737] leds-gpio cape_pins: ignoring dependency for device, assuming no
driver
[ OK ] Started Job spooling tools.
Starting Print notice about GPLv3 packages…
Starting rc.pvr.service…
[ 10.800016] vpe 489d0000.vpe: loading firmware vpdma-1b8.bin
[ 10.806209] leds-gpio cape_pins: ignoring dependency for device, assuming no
driver
[ 10.822273] [drm] Initialized pvr 1.17.4948957 20110701 for 56000000.gpu on m
inor 1
[ 10.830360] leds-gpio cape_pins: ignoring dependency for device, assuming no
driver
[ OK ] Started Periodic Command Scheduler.
[ OK ] Started D-Bus System Message Bus.
[ 11.071808] vpe 489d0000.vpe: Device registered as /dev/video0
Starting TI MultiCore Tools Daemon…
Starting Login Service…
Starting Reboot and dump vmcore via kexec…
[ OK ] Started Enable GPIO pins.
Starting TI IPC Daemon…
[ OK ] Reached target System Time Synchronized.
[ OK ] Started Daily rotation of log files.
[ OK ] Reached target Timers.
[ OK ] Started Network Service.
[ 11.265234] omap-hdmi-audio omap-hdmi-audio.0.auto: snd-soc-dummy-dai ↔ 580
40000.encoder mapping ok
[ OK ] Found device /dev/ttyS2.
[ 11.293276] omap-hdmi-audio omap-hdmi-audio.0.auto: ASoC: no DMI vendor name!
[ 11.312827] leds-gpio cape_pins: ignoring dependency for device, assuming no
driver
Starting Wait for Network to be Configured…
Starting Network Name Resolution…
[ 12.313220] vip 48990000.vip: loading firmware vpdma-1b8.bin
[ 12.321871] leds-gpio cape_pins: ignoring dependency for device, assuming no
driver
[ 12.341665] vip 48990000.vip: VPDMA firmware loaded
[ 13.388658] remoteproc remoteproc2: powering up 40800000.dsp
[ 13.394559] remoteproc remoteproc2: Booting fw image dra7-dsp1-fw.xe66, size
20482288
[ 13.402666] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0
[ 13.408563] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0
[ 13.428087] virtio_rpmsg_bus virtio2: rpmsg host is online
[ 13.430795] virtio_rpmsg_bus virtio2: creating channel rpmsg-proto addr 0x3d
[ 13.434085] remoteproc remoteproc2: registered virtio2 (type 7)
[ 13.446743] remoteproc remoteproc2: remote processor 40800000.dsp is now up
[ 13.488220] leds-gpio cape_pins: ignoring dependency for device, assuming no
driver
[ 13.724570] PVR_K: UM DDK-(4948957) and KM DDK-(4948957) match. [ OK ]
[ 13.876425] remoteproc remoteproc3: powering up 41000000.dsp
[ 13.887772] remoteproc remoteproc3: Booting fw image dra7-dsp2-fw.xe66, size
20482288
[ 13.911198] omap-iommu 41501000.mmu: 41501000.mmu: version 3.0
[ 13.917192] omap-iommu 41502000.mmu: 41502000.mmu: version 3.0
[ 14.022605] virtio_rpmsg_bus virtio3: rpmsg host is online
[ 14.022691] virtio_rpmsg_bus virtio3: creating channel rpmsg-proto addr 0x3d
[ 14.040641] remoteproc remoteproc3: registered virtio3 (type 7)
[ 14.061683] remoteproc remoteproc3: remote processor 41000000.dsp is now up
[ 14.088550] leds-gpio cape_pins: ignoring dependency for device, assuming no
driver
[ OK ] Started Login Service.
[ OK ] Started Network Name Resolution.
[ OK ] Started RPC Bind Service.
[ OK ] Started rc.pvr.service.
[ OK ] Started TI MultiCore Tools Daemon.
[ OK ] Started Reboot and dump vmcore via kexec.
[ OK ] Started TI IPC Daemon.
[ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[ OK ] Created slice system-systemd\x2dfsck.slice.
Starting weston.service…
[ OK ] Reached target Host and Network Name Lookups.
[ OK ] Reached target Network.
[ OK ] Started Redis In-Memory Data Store.
[ OK ] Started NFS status monitor for NFSv2/3 locking..
Starting Permit User Sessions…
Starting Enable and configure wl18xx bluetooth stack…
Starting Lightning Fast Webserver With Light System Requirements…
Starting Simple Network Management Protocol (SNMP) Daemon…
Starting Avahi mDNS/DNS-SD Stack…
[ OK ] Started Permit User Sessions.
[ OK ] Started Getty on tty1.
[ OK ] Started Serial Getty on ttyS0.
[ OK ] Started Serial Getty on ttyS2.
[ OK ] Reached target Login Prompts.
Starting Synchronize System and HW clocks…
[ OK ] Started Enable and configure wl18xx bluetooth stack.
[ OK ] Started Synchronize System and HW clocks.
[ OK ] Found device /dev/mmcblk1p1.
[ OK ] Started Lightning Fast Webserver With Light System Requirements.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
Starting File System Check on /dev/mmcblk1p1…
[ OK ] Started File System Check on /dev/mmcblk1p1.
[ 15.987211] dwc3 488d0000.usb: Failed to get clk ‘ref’: -2
[ 15.988390] leds-gpio cape_pins: ignoring dependency for device, assuming no
driver
[ 16.026391] leds-gpio cape_pins: ignoring dependency for device, assuming no
driver
[ 16.059109] dwc3 48890000.usb: Failed to get clk ‘ref’: -2
[ 16.066326] rpmsg_rpc virtio0.rpmsg-rpc.-1.101: probing service dce-callback
with src 1024 dst 101
[ 16.076153] leds-gpio cape_pins: ignoring dependency for device, assuming no
driver
[ 16.112864] leds-gpio cape_pins: ignoring dependency for device, assuming no
driver
[ 16.122430] rpmsg_rpc virtio0.rpmsg-rpc.-1.101: published functions = 4
[ 16.125225] rpmsg_rpc virtio0.rpmsg-rpc.-1.102: probing service rpmsg-dce wit
h src 1025 dst 102
[ 16.138484] OF: graph: no port node found in /ocp/ocp2scp@4a080000/phy@4a0840
00
[ 16.146635] leds-gpio cape_pins: ignoring dependency for device, assuming no
driver
[ 16.146944] rpmsg_rpc virtio0.rpmsg-rpc.-1.102: published functions = 9
[ 16.163374] leds-gpio cape_pins: ignoring dependency for device, assuming no
driver
[ 16.173799] NET: Registered protocol family 45
[ 16.202847] leds-gpio cape_pins: ignoring dependency for device, assuming no
driver
[ 16.248659] leds-gpio cape_pins: ignoring dependency for device, assuming no
driver
[ 16.260710] remoteproc remoteproc4: 4b234000.pru is available
[ 16.269450] pru-rproc 4b234000.pru: PRU rproc node pru@4b234000 probed succes
sfully
[ 16.279053] dwc3 48890000.usb: changing max_speed on rev 5533202a
[ 16.292312] leds-gpio cape_pins: ignoring dependency for device, assuming no
driver
[ 16.300633] remoteproc remoteproc5: 4b238000.pru is available
[ 16.307843] pru-rproc 4b238000.pru: PRU rproc node pru@4b238000 probed succes
sfully
[ 16.316917] leds-gpio cape_pins: ignoring dependency for device, assuming no
driver
[ 16.325135] remoteproc remoteproc6: 4b2b4000.pru is available
[ 16.331285] pru-rproc 4b2b4000.pru: PRU rproc node pru@4b2b4000 probed succes
sfully
[ 16.339651] leds-gpio cape_pins: ignoring dependency for device, assuming no
driver
[ 16.347737] remoteproc remoteproc7: 4b2b8000.pru is available
[ 16.353881] pru-rproc 4b2b8000.pru: PRU rproc node pru@4b2b8000 probed succes
sfully
[ 16.362086] leds-gpio cape_pins: ignoring dependency for device, assuming no
driver
[ 16.415373] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 16.421536] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus nu
mber 1
[ 16.430860] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f04c hci version 0x100
quirks 0x0000000002010010
[ 16.442899] xhci-hcd xhci-hcd.1.auto: irq 172, io mem 0x488d0000
[ 16.449276] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bc
dDevice= 4.19
[ 16.458398] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=
1
[ 16.465917] usb usb1: Product: xHCI Host Controller
[ 16.470835] usb usb1: Manufacturer: Linux 4.19.94-gbe5389fd85 xhci-hcd
[ 16.477842] usb usb1: SerialNumber: xhci-hcd.1.auto
[ 16.484372] hub 1-0:1.0: USB hub found
[ 16.488202] hub 1-0:1.0: 1 port detected
[ 16.493853] leds-gpio cape_pins: ignoring dependency for device, assuming no
driver
[ 16.503117] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 16.508671] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus nu
mber 2
[ 16.517691] leds-gpio cape_pins: ignoring dependency for device, assuming no
driver
[ 16.525624] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[ 16.533306] usb usb2: We don’t know the algorithms for LPM for this host, dis
abling LPM.
[ 16.541592] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bc
dDevice= 4.19
[ 16.550361] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=
1
[ 16.558082] usb usb2: Product: xHCI Host Controller
[ 16.563433] usb usb2: Manufacturer: Linux 4.19.94-gbe5389fd85 xhci-hcd
[ 16.570374] usb usb2: SerialNumber: xhci-hcd.1.auto
[ 16.576842] hub 2-0:1.0: USB hub found
[ 16.580660] hub 2-0:1.0: 1 port detected
[ 16.586443] leds-gpio cape_pins: ignoring dependency for device, assuming no
driver
[ 16.597028] leds-gpio cape_pins: ignoring dependency for device, assuming no
driver
[ OK ] Started Simple Network Management Protocol (SNMP) Daemon..
[ OK ] Started weston.service.
[ OK ] Found device /dev/mmcblk0p1.
Starting File System Check on /dev/mmcblk0p1…
Starting Save/Restore Sound Card State…
Starting Matrix GUI…
Starting telnetd.service…
Mounting /run/media/mmcblk1p1…
[ OK ] Started telnetd.service.
[ OK ] Started Save/Restore Sound Card State.
[ OK ] Reached target Sound Card.
Starting thttpd.service…
[ OK ] Started Matrix GUI.
[ 18.856991] EXT4-fs (mmcblk1p1): mounted filesystem with ordered data mode. O
pts: (null)
[ OK ] Mounted /run/media/mmcblk1p1.
[ OK ] Started thttpd.service.
[ 19.511125] omapdss error: HDMI I2C Master Error
[ OK ] Started File System Check on /dev/mmcblk0p1.
Mounting /run/media/mmcblk0p1…
| _ |___ ___ ___ ___ | _ |___ ___ ||__ | |
| | _| .'| . | . | | | | . | | | -| _| _|
|| |__,| || || || ||| ||||
| |_|
Arago Project http://arago-project.org am57xx-evm ttyS0
Arago 2019.11 am57xx-evm ttyS0
am57xx-evm login:
