[BBAI64] Debian with c7x TI vision_apps -- Recipe / Patch
Working with Claude I was able to get vision_apps (resnet18) example in edgeai-tidl-tools running on bbai64 with Debian GNU/Linux 12 (bookworm). This included using ONNX compiled artifacts through TIDL framework. Eventually the pipeline will be incorporated in my realtime project ‘openWearable’ project: GitHub - jonreal/openWearable · GitHub. For now there’s a only a recipe/patch and information to help.
This was non-trivial to get working. Four gaps separate stock Debian from a working C7x: the device tree needs TI’s vision_apps memory carveouts + reserved DSP tick-timers, the kernel needs CONFIG_REMOTEPROC_CDEV=y (stock Debian has it off), the PSDK-10.1 firmware trips a benign TI-SCI ABI 3-vs-4 skew against the board’s older Device Manager, and the C7x won’t start inference until the whole six-core vision_apps fleet clears its sync barrier. The fixes are small and reversible — one firmware patch (relax the ABI check) plus an ETHFW=off build flag, a device tree, and a stock apt kernel — all pinned to PSDK 10.01.00.04.
The full step-by-step is below, and the canonical, maintained version lives in the repo so I can fold in fixes/feedback from anyone who runs it: openWearable/docs/C7X-TIDL.md at am64x · jonreal/openWearable · GitHub
The patch overlay (one ABI relax + an ETHFW build flag), the device tree, and the build script are all in that repo too. If you try this and hit a snag — different kernel rev, a different model, a host-toolchain quirk — please reply here or open an issue; I’d like this to become a reliable recipe for the community. The full directions follow.
Running TIDL / vision_apps on the C7x (BeagleBone AI-64)
How to get neural-network inference running on the C7x + MMA deep-learning accelerator of
the TDA4VM/J721E, on the stock BeagleBoard.org Debian image (no full SDK reflash). The proof
target is the resnet18 OSRT example returning a real classification on the C7x.
TL;DR
Five moves across two machines — the board, and an x86_64 Linux build host. Full detail in the
numbered parts below.
  1. Board prep (BBAI64) — flash the Debian image, apt install kernel …-r64
    (CONFIG_REMOTEPROC_CDEV), build + select the openWearable -tidl device tree, build the A72
    ~/tidl runtime (Part 1), and clone edgeai-tidl-tools + drop in a
    compiled model artifact (Part 3).
  2. Host prep (x86 Linux) — install TI PSDK-RTOS 10.1 + the C7x/C66/R5F CGTs
    (MANIFEST — incl. the easily-missed libtinfo.so.5).
  3. Build the fleet (x86) — third_party/ti/build-firmware.sh applies the one ABI patch +
    the ETHFW-off flag and builds the 5 *.out ELFs (Part 2).
  4. Deploy (x86 → board) — copy the 5 ELFs to /lib/firmware, repoint the j7-* symlinks,
    reboot (§2.3).
  5. Run (board) — source ~/tidl/setenv.sh and run the resnet example
    (Part 4).
Done when the example prints Offloaded Nodes 52, Total Nodes 52 and a real top-1 class
(warplane on the airshow image) with IPC: Init … Done — the whole graph ran on the C7x.
Prereqs. Finish SETUP.md Parts A–C first (flashed image, ssh, toolchains,
and the openWearable device tree built + selected). This guide is BeagleBone AI-64 only.
Everything is pinned to PSDK 10.01.00.04 — the firmware, the A72 runtime libs, and the
model-compile tools must all be the same 10.1.0 version or you will chase ABI ghosts.
0. The mental model: TIDL is three separate pieces
Keep these straight or you will debug the wrong layer:
Piece Runs on Where it comes from
A72 runtime libs + Python wheel (onnxruntime_tidl, libtidl_onnxrt_EP.so, libvx_tidl_rt.so, libtivision_apps.so) A72 / Linux built from source on the board — Part 1
vision_apps firmware fleet (vx_app_rtos_linux_*.out for mcu2_0, mcu2_1, c6x_1, c6x_2, c7x_1) the R5F / C66 / C7x cores, via remoteproc built from the TI SDK with our patch-overlay — Part 2
Per-model artifacts (subgraph_*_tidl_net.bin) loaded into the C7x firmware at runtime compiled from ONNX on an x86 host — Part 3
The firmware is the inference engine; the A72 libs are useless without it; the .bin artifact
is the compiled network (≈ a serialized TensorRT engine), loaded at runtime. All three must
be the same 10.1.0 version.
Why the whole fleet — not just the C7x
The C7x’s TIDL runtime is built on TI’s vision_apps framework, and that framework will not
proceed until all six CPUs clear an all-or-nothing barrier (appLogCpuSyncInit):
mpu1_0 + mcu2_0 + mcu2_1 + c6x_1 + c6x_2 + c7x_1. A single dead core stalls everything —
so even a pure-C7x inference needs the two R5Fs and two C66s alive and synced. The TIDL graph
itself is C7x-only (resnet offloads 52/52 nodes to the C7x); the other cores run purely to
satisfy libtivision_apps. That framework cost is the central tension behind openWearable’s
own lean shared-memory design (see the architecture notes).
Cores ↔ remoteproc ↔ firmware
vision_apps CPU phys node firmware symlink ELF load base
mcu2_0 5c00000.r5f (main_r5fss0_core0) j7-main-r5f0_0-fw 0xa2100000
mcu2_1 5d00000.r5f (main_r5fss0_core1) j7-main-r5f0_1-fw 0xa4100000
c6x_1 4d80800000.dsp j7-c66_0-fw 0xa8100000
c6x_2 4d81800000.dsp j7-c66_1-fw 0xa9100000
c7x_1 64800000.dsp j7-c71_0-fw 0xb2100000
(device manager) 41000000.r5f — TIFS, never touch — —
Firmware names are derived from the node (no firmware-name DT property): a core at
main_r5fssX_coreY requests j7-main-r5fX_Y-fw. main_r5fss1 (“mcu3”, 5e00000/5f00000)
is disabled — not part of the fleet.
1. A72 runtime libraries
Build the A72-side TIDL/ONNX runtime from source. This is the same on every board.
1.1 Build storage (the build needs ~15 GB + swap; eMMC has neither)
Use an SD card:
lsblk                                   # identify the SD — NOT mmcblk0 (= eMMC)
mkfs.ext4 /dev/mmcblk1 && mkdir -p /mnt/build && mount /dev/mmcblk1 /mnt/build
fallocate -l 6G /mnt/build/swap && chmod 600 /mnt/build/swap && mkswap /mnt/build/swap && swapon /mnt/build/swap
mkdir -p /mnt/build/docker              # point Docker at the SD: "data-root":"/mnt/build/docker"
#   in /etc/docker/daemon.json, then:   systemctl restart docker
1.2 Build the libs (Docker, from TI’s sandbox repo)
cd /mnt/build && git clone https://github.com/TexasInstruments-Sandbox/edgeai-osrt-libs-build
cd edgeai-osrt-libs-build               # config.yaml `main` == PSDK 10.01.00.0x
BASE_IMAGE=debian:12.5 ./docker_build.sh
BASE_IMAGE=debian:12.5 ./docker_run.sh  # enter the container, then:
export CMAKE_POLICY_VERSION_MINIMUM=3.5  # ⚠️ CRITICAL — see note
./build_all.sh                          # downloads deps + builds (~7–8 h on the board)
:warning: The gotcha that stops you cold: onnxruntime 1.15 vendors an old date lib whose
cmake_minimum_required is rejected by the container’s CMake 4.x (“Compatibility with CMake
< 3.5 has been removed”). Export CMAKE_POLICY_VERSION_MINIMUM=3.5 before building or the
configure step dies in ~16 s.
Outputs (under …/workarea/ and ~/debian12.5-deps/):
  • onnxruntime_tidl-1.15.0-cp311-cp311-linux_aarch64.whl (cp311 = the board’s native Python 3.11)
  • arm-tidl-j721e_10.1.0-…tar.gz → libvx_tidl_rt.so.1.0, libtidl_onnxrt_EP.so.1.0, libtidl_tfl_delegate.so.1.0
  • libti-vision-apps-j721e_10.1.0-debian12.5.deb → libtivision_apps.so.10.1.0
1.3 Install the runtime to ~/tidl
mkdir -p ~/tidl/lib                     # place the 4 .so libs, each with its bare .so symlink:
#   libvx_tidl_rt.so -> .so.1.0     libtidl_onnxrt_EP.so -> .so.1.0
#   libtidl_tfl_delegate.so -> .so.1.0   libtivision_apps.so -> .so.10.1.0
python3 -m venv ~/tidl/venv && source ~/tidl/venv/bin/activate
pip install <…>/onnxruntime_tidl-1.15.0-cp311-cp311-linux_aarch64.whl numpy pillow pyyaml
cat > ~/tidl/setenv.sh <<'EOF'
export TIDL_HOME=$HOME/tidl
export LD_LIBRARY_PATH=$TIDL_HOME/lib:${LD_LIBRARY_PATH}
export TIDL_TOOLS_PATH=$TIDL_HOME/lib
source $TIDL_HOME/venv/bin/activate
EOF
Verify:
python -c "import onnxruntime as o; print(o.get_available_providers())"
# -> ['TIDLExecutionProvider', 'TIDLCompilationProvider', 'CPUExecutionProvider']
If you instead see only AzureExecutionProvider/CPUExecutionProvider, you are in the wrong
venv (stock onnxruntime). The TIDLExecutionProvider only exists in the ~/tidl venv built above.
2. The vision_apps firmware fleet
The fleet firmware is not what TI ships in the stock Debian image — the stock .tisdk
firmware keeps the cores offline, and the 10.1 SDK build needs several patches to boot on this
board against its stock boot firmware. The patches are tiny and fully captured as a
patch-overlay in ../third_party/ti/: a pinned manifest + .patch
files + a build driver. You build the TI SDK once, overlaid; the multi-GB SDK source stays out
of this repo.
2.1 What the bring-up needs, and where each piece lives
Booting the fleet takes changes at three layers — but only the firmware ones are actual
patches to TI source. The device-tree changes are openWearable’s own device tree (not a
patch against anything), and the kernel is a stock apt install. All of it is config/topology —
no boot-firmware (TIFS) swap.
1. openWearable’s custom device tree —
device-tree/k3-j721e-boneai64-openWearable-tidl.dts
(our file; already in-tree):
Provides Why
vision_apps memory carveouts (C7x/C66/IPC/dma-heap/per-core heaps) remoteproc must map each firmware’s PT_LOAD + runtime regions
reserved DSP tick-timers (main_timer0/1/2) C7x/C66 FreeRTOS tick timers were A72-owned → scheduler hung
SA2UL crypto disabled (&main_crypto) sa_sha_cra_exit oops killed wifi on the r64 kernel
mcu2_0 31 MB carveout merge; main_r5fss0 split-mode so mcu2_1 boots on 5d00000; main_r5fss1 disabled one carveout per PT_LOAD; mcu2_1 was on the wrong physical core → Sciclient hung
2. Kernel — stock apt install, no patch: linux-image-6.12.57-ti-arm64-r64
(CONFIG_REMOTEPROC_CDEV=y, for the /dev/remoteproc* cdev the runtime needs).
3. TI firmware patch-overlay — third_party/ti/ (the only actual
patches to TI source):
Patch Why
relax Sciclient_abiCheck (accept the ACK’d response) board DM speaks TISCI ABI 3, PSDK-10.1 fw expects 4
BUILD_ENABLE_ETHFW=no (mcu2_0 build flag) appEthFwInit hangs on the missing EVM GESI Ethernet card
The two firmware fixes, in one line each. (6) Sciclient_abiCheck() in the SDK’s
sciclient.c rejects the board’s ABI-major 3 because PSDK-10.1 hardcodes 4; the transport
works fine on ABI 3, so we drop the strict-major term (apply to all cores — guarding it to
the DSPs leaves the R5Fs hung). (7) mcu2_0 is the ethfw core and EthFwBoard_init expects an
EVM Ethernet card the AI-64 lacks, so we build mcu2_0 with ETHFW off.
2.2 Build the fleet (x86_64 host)
The C7x/C66 compilers (cl7x, cl6x) ship x86_64-only — there is no arm64 build, so the fleet
is cross-built on a Linux PC and the ELFs copied to the board. Install the TI PSDK-RTOS 10.01.00.04
and its compilers per the manifest, then:
# Point at your install (only TI_SDK_HOME is mandatory; the rest auto-detect under it, but these
# two are easy to get wrong, so set them explicitly):
export TI_SDK_HOME=$HOME                                     # root holding the PSDK + CGTs
export SDK_BUILDER=$HOME/psdk-rtos/ti-processor-sdk-rtos-j721e-evm-10_01_00_04/sdk_builder
export C6X_GEN_INSTALL_PATH=$HOME/ti/ti-cgt-c6000_8.3.7      # cl6x (C66)
export LD_LIBRARY_PATH=$HOME/locallibs:$LD_LIBRARY_PATH      # a dir with libtinfo.so.5 — tiarmclang
                                                            # (R5F) links ncurses5; modern distros
                                                            # ship only libtinfo.so.6
third_party/ti/build-firmware.sh        # applies the ABI patch + ETHFW-off, builds the 5 ELFs
The script preflights tiarmclang and stops early with a clear hint if libtinfo.so.5 is
missing (otherwise the R5F cores fail mid-build as a cryptic “ELF not found”). See
third_party/ti/README.md and
MANIFEST.md for toolchain versions and build flags. Outputs are
the 5 vx_app_rtos_linux_*.out ELFs in third_party/ti/out/.
2.3 Deploy to the board
Copy each ELF to /lib/firmware/ under a non-stock name and repoint the derived j7-* symlink
(keep the stock .tisdk as a rollback):
# per core, e.g. mcu2_1:
cp vx_app_rtos_linux_mcu2_1.out  /lib/firmware/vx_app_rtos_linux_mcu2_1.out.ow
ln -sf vx_app_rtos_linux_mcu2_1.out.ow /lib/firmware/j7-main-r5f0_1-fw
# (repeat: mcu2_0->j7-main-r5f0_0-fw, c6x_1->j7-c66_0-fw, c6x_2->j7-c66_1-fw, c7x_1->j7-c71_0-fw)
reboot                                  # cores cold-boot from the new firmware + DTB
:warning: Never warm-restart (stop→start) a vision R5F/DSP core — it hard-hangs the K3 fabric and
needs a power cycle. Always cold-boot via reboot. Never touch the MCU R5F core0
(41000000.r5f)
— it runs TIFS/the device manager that the whole SoC depends on.
2.4 Verify the fleet is up
for r in /sys/class/remoteproc/remoteproc*; do printf '%s ' "$(cat $r/firmware)"; cat $r/state; done
# expect j7-main-r5f0_0-fw, j7-main-r5f0_1-fw, j7-c66_0-fw, j7-c66_1-fw, j7-c71_0-fw all = running
Each core writes its boot log into a slot of the shared rtos-log@ac000000 carveout; a healthy
fleet shows every CPU reaching APP: Syncing with 5 CPUs ... Done. (A small reader is in
Part 5.)
3. Compiling a model artifact (x86 host)
The per-model .bin is compiled with TI’s edgeai-tidl-tools in a container on an x86 Linux
box (same place as the fleet build is fine). Pin the tool to the same 10.1.0 line as the
board: tag 10_01_00_02, SOC am68pa (TI’s name for the TDA4VM/J721E).
git clone https://github.com/TexasInstruments/edgeai-tidl-tools.git ~/edgeai-tidl-tools
cd ~/edgeai-tidl-tools && git checkout 10_01_00_02
# Build TI's container (FROM ubuntu:22.04 → Python 3.10, matches the cp310 OSRT wheels), then:
docker exec -e SOC=am68pa <container> bash -c "cd /home/root && source ./setup.sh"  # downloads am68pa tidl_tools
docker exec <container> pip3 install onnx_graphsurgeon                              # onnxOpt dep
Compile with a minimal options dict (TI’s onnxrt_ep.py injects am69a-only options that
fail EP init on am68pa). A self-contained compile.py:
import os, glob, shutil, numpy as np, onnxruntime as rt
from PIL import Image
art = "/home/root/r18_artifacts"
shutil.rmtree(art, ignore_errors=True)        # artifacts_folder MUST be empty, else EP -> CPU fallback
os.makedirs(art, exist_ok=True)
mp = "/home/root/models/public/resnet18_opset9_4batch.onnx"   # input [4,3,224,224] UINT8 (norm folded in)
opts = {
    "tidl_tools_path": os.environ["TIDL_TOOLS_PATH"],
    "artifacts_folder": art,
    "platform": "J7", "tensor_bits": 8, "accuracy_level": 1, "debug_level": 1,
    "advanced_options:calibration_frames": 4, "advanced_options:calibration_iterations": 4,
so = rt.SessionOptions(); so.log_severity_level = 1
sess = rt.InferenceSession(mp, providers=["TIDLCompilationProvider", "CPUExecutionProvider"],
                           provider_options=[opts, {}], sess_options=so)
assert "TIDLExecutionProvider" in sess.get_providers(), "TIDL EP fell back to CPU!"
inp = sess.get_inputs()[0]
imgs = sorted(glob.glob("/home/root/test_data/*.jpg"))
load = lambda p: np.asarray(Image.open(p).convert("RGB").resize((224, 224))).transpose(2, 0, 1)
for f in range(4):
    batch = np.stack([load(imgs[(f*4+k) % len(imgs)]) for k in range(4)]).astype(np.uint8)
    sess.run(None, {inp.name: batch})         # calibration frames
del sess                                       # finalize artifacts
print("ARTIFACTS:", sorted(os.listdir(art)))
Run it with SOC=am68pa, TIDL_TOOLS_PATH=/home/root/tidl_tools,
LD_LIBRARY_PATH=/home/root/tidl_tools:/home/root/tidl_tools/osrt_deps. Success =
Subgraph Compiled Successfully and a C7x: 52 / CPU: 0 node split. Outputs:
subgraph_0_tidl_net.bin (the network) + subgraph_0_tidl_io_1.bin (IO config) +
allowedNode.txt + onnxrtMetaData.txt. Copy these to the board’s model-artifacts folder.
Compile gotchas
Symptom Cause / fix
status == true was false EP error onnxrt_ep.py am69a opts → use the minimal options dict above
artifacts_folder is not empty shutil.rmtree the folder before each compile
expected uint8, got float feed raw uint8 calib images (normalization is folded into the graph)
assert says EP failed but it didn’t get_providers() reports TIDLExecutionProvider, not …Compilation…
model download = 2 bytes git.ti.com 503s → use a model hosted on software-dl.ti.com
pip read-timeout / torch corrupt in container ENV PIP_DEFAULT_TIMEOUT=120 PIP_RETRIES=10; install CPU torch from download.pytorch.org/whl/cpu
4. Running inference on the board (the resnet proof)
With the fleet up (Part 2), the runtime installed (Part 1), and the artifact in place (Part 3):
source ~/tidl/setenv.sh                 # the ~/tidl venv with TIDLExecutionProvider
export SOC=am68pa
cd <edgeai-tidl-tools>/examples/osrt_python/ort
python3 onnxrt_ep.py -m cl-ort-resnet18-v1_4batch
Expected: libtidl_onnxrt_EP loaded, Final number of subgraphs created are : 1, Offloaded Nodes 52, Total Nodes 52, a real top-1 class (e.g. warplane on the airshow test image),
IPC: Init ... Done with no “Unable to create TX channels” errors, exit 0. Lingering
_rpmsg_char_find_* warnings during teardown are benign.
5. Debugging toolbox
  • Per-core boot log (best tool, no serial cable). Every core writes appLogPrintf output
    into a slot of the non-cacheable rtos-log@0xAC000000 carveout, so the A72 can read it through
    /dev/mem with no cache maintenance. Slot = 0xAC000000 + cpu_idx*0x4000; cpu_idx:
    mpu1_0=0, DM=1, mcu2_0=3, mcu2_1=4, c6x_1=7, c6x_2=8, c7x_1=9. Per-slot layout:
    +0x00 rd_idx, +0x04 wr_idx, +0x08 valid(==0x01357231), +0x0C sync_state, +0x10 name[16], +0x20 text. Read it with mmap("/dev/mem", O_SYNC, offset=0xAC000000) in Python (dd gets
    EFAULT; mmap works).
  • Firmware load map. readelf -l <fw>.out | grep LOAD → the PT_LOAD PhysAddr ranges drive
    carveout sizing; readelf -S | grep -i 'resource\|tracebuf\|vring' for IPC regions.
  • Topology. /sys/class/remoteproc/*/{state,firmware} + readlink device. The R5F
    firmware-name is derived (j7-main-r5fX_Y-fw for main_r5fssX_coreY) — there is no
    firmware-name DT property.
Benign messages (not failures)
  • dmesg: unsupported resource 65538 — a TI vendor resource the stock Debian remoteproc skips.
  • No remoteproc*/trace0 for the vision cores — they log to rtos-log@ac000000, not the
    mainline trace resource.
6. Known rough edges
  • mcu2_0 DSS-init abort (cosmetic). With the fleet synced, mcu2_0 runs past the barrier and
    aborts in the display (DSS) pipeline (DFAR=0xa010000) — a display DMA into an unmapped region.
    It does not affect TIDL inference (the graph is C7x-only and mcu2_0’s rpmsg endpoint
    registers before DSS). Fix by building mcu2_0 without DSS (this platform drives no display).
  • Reversibility. Everything here is firmware + device-tree only — the Debian kernel/userland
    is untouched. The stock .tisdk firmware symlinks and the recovery boot label (stock DTB) let
    you fall back at any point.
Awesome! Could the new Thames driver help at all? New DRM accel driver for Texas Instruments' C7x DSPs [LWN.net]
Nice writeup.
Did not notice that R5 MCU3_0 and MCU3_1 are free. Great to have those for real-time controls on the side.
that can be a quick fix, what kernel are you using?
Thanks for sharing this! – looks awesome and definitely gonna looking into it.
>> uname -a
Linux boneai64-0 6.12.57-ti-arm64-r64 #1 SMP PREEMPT_RT Mon May 11 20:34:52 UTC 2026 aarch64 GNU/Linux
>> cat /etc/os-release
PRETTY_NAME=“Debian GNU/Linux 12 (bookworm)”
NAME=“Debian GNU/Linux”
VERSION_ID=“12”
VERSION=“12 (bookworm)”
VERSION_CODENAME=bookworm
ID=debian
HOME_URL=“https://www.debian.org/”
SUPPORT_URL=“ Debian -- User Support ”
BUG_REPORT_URL=“I Challenge Thee
Thanks! For the TIDL vission_apps my understanding so far is that only the C7x (runs the graph) and the A72/Arm (Linux + onnxruntime host) do real work. The other four fleet cores (mcu2_0, mcu2_1, c6x_1, c6x_2) just boot and must clear vision_apps’ all-or-nothing appLogCpuSyncInit barrier, then sit idle. In theory you can put them to work, but only by adding your own TIOVX nodes or forking their FreeRTOS firmware inside vision_apps — not as free R5F/DSP cores.
On the spare R5Fs: you’re right the pair main_r5fss1 — the MCU3 cores (5e00000/5f00000) can be harnessed — right now they are actually disabled in my current -tidl device tree. One caveat if you want them for real-time control: I reuse that cluster’s default a4/a5 carveouts for mcu2_1 (its firmware link map is fixed there), which is why MCU3 is disabled — so to bring MCU3 up you’d re-enable it with fresh DDR carveouts (not a4/a5). mcu2_0/mcu2_1 are tied up by the fleet (but in theory they can be used for something else too), and the MCU-domain R5F core0 (41000000.r5f) is TIFS/the Device Manager — off-limits.
But yes — a free dual-R5F real-time control plane next to Linux + the C7x is exactly the longterm goal of openWearable project, I’m currently scaling from the AM335x PRUs to the whole fleet on bbai64 – although it’s slow going.
CONFIG_REMOTEPROC_CDEV got enabled in r34.1 in 6.12.x-ti branch… was there another config you found we needed: config: enable CONFIG_REMOTEPROC_CDEV · RobertCNelson/ti-linux-kernel-dev@06741d7 · GitHub
You’re right — CONFIG_REMOTEPROC_CDEV=y is in the current 6.12.x-ti kernels. Looking back at my notes I only hit it because we originally had r33, so it was off on my as-flashed image — apt install of a newer kernel fixes it, no rebuild. That was the only kernel config I needed. The only other kernel-side thing was a device-tree workaround for an SA2UL crypto-driver regression on r64 (it was oopsing the kernel / killing wifi at boot), not a config change. Claude helped me diagnose and proposes the fix, adding this to my custom device tree:
&main_crypto {
status = “disabled”;
I made a post about that a few days ago: kernel 6.12.57-ti-arm64-r64: sa2ul crypto driver oopses on iwd
Thanks Robert!
ah that was the change!! i was trying to get TI to use iwd so they could actually test the crypto path’s in their 6.12.x-ti tree, as i’ve seen an opps from time to time.. i’ve just been reverting their local cryto changes and switching it back to 6.12.x stable as is..
