BBAI64 Kernel 6.12.53 PCIe not working for Intel AX210 & AX201
Hello, I realized that the 6.12.x kernel don’t work with the Intel WLAN AX210 & AX201 anymore. Kernel 6.6.53 works off the shelf. To verify I just downloaded BBAI64 Debian 13.2 2025-11-25 Minimal Flasher (v6.12.x-ti). After flashing booting fails with the attached boot-log
BootLog-Debian13.2-2025-11-25-MinimalFlasher.txt (81.8 KB)
Any hints on how to solve this?
Best regards,
Bernd
thanks for reporting this.. for the last month I’ve been re-ordering other modules, figured it was just something wrong with my board..
So no i need to git bisect and see where it broke..
I’ve got this between v6.11.x and v6.12.x right now…
our 6.11.x config on 6.12.x…
voodoo@bbai64-51:~$ uname -r
6.12.66-arm64-k3-r37.2
voodoo@bbai64-51:~$ dmesg | grep iwlwifi
[   10.123971] iwlwifi 0000:01:00.0: enabling device (0000 -> 0002)
[   10.222034] iwlwifi 0000:01:00.0: Detected crf-id 0x400410, cnv-id 0x400410 wfpm id 0x80000000
[   10.236262] iwlwifi 0000:01:00.0: PCI dev 2725/0024, rev=0x420, rfid=0x10d000
[   10.248805] iwlwifi 0000:01:00.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz
[   10.352514] iwlwifi 0000:01:00.0: capa flags index 4 larger than supported by driver
[   10.366021] iwlwifi 0000:01:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.42
[   10.382858] iwlwifi 0000:01:00.0: loaded firmware version 89.7207fc64.0 ty-a0-gf-a0-89.ucode op_mode iwlmvm
[   10.856360] iwlwifi 0000:01:00.0: WFPM_UMAC_PD_NOTIFICATION: 0x20
[   10.875712] iwlwifi 0000:01:00.0: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[   10.901982] iwlwifi 0000:01:00.0: WFPM_AUTH_KEY_0: 0x90
[   10.901999] iwlwifi 0000:01:00.0: CNVI_SCU_SEQ_DATA_DW9: 0x0
[   10.920662] iwlwifi 0000:01:00.0: Detected RF GF, rfid=0x10d000
[   10.969687] iwlwifi 0000:01:00.0: loaded PNVM version 285b3568
[   11.062107] iwlwifi 0000:01:00.0: base HW address: 28:a4:4a:d7:f1:e0
[   12.122542] iwlwifi 0000:01:00.0: WFPM_UMAC_PD_NOTIFICATION: 0x20
[   12.131471] iwlwifi 0000:01:00.0: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[   12.143206] iwlwifi 0000:01:00.0: WFPM_AUTH_KEY_0: 0x90
[   12.153964] iwlwifi 0000:01:00.0: CNVI_SCU_SEQ_DATA_DW9: 0x0
[   12.399655] iwlwifi 0000:01:00.0: Registered PHC clock: iwlwifi-PTP, with index: 2
i think it might be ‘rt’… i hope not.. that was a huge change in v6.12.x…
Pretty sure, the main fix is… CONFIG_SOCIONEXT_SYNQUACER_PREITS=y after a few dozen tests… i need to spend some time retesting everyting but yeah…
yeap… we need that everywhere…
Images hosted thru bb-imager have been fixed with this change.
Hello Robert - wlan works now! Thanks a lot for fixing it.
I detected an issue with linuxptp which is not around in 6.6, but I need to dig further into it… I will keep you updated! (With linuxptp I achieve synchronization of the bbai64 to a time master better than 100ns peak)
Thanks a lot for helping!
Best regards,
Bernd
