I will get information you requested when I can (the BBG is not physically with me at present).
In the meantime, uname -a gives Linux beaglebone 4.19.94-ti-r42 #1buster SMP PREEMPT Tue Mar 31 19:38:29 UTC 2020 armv7l GNU/Linux.
I don’t see way to attach log files so will insert.
U-Boot SPL 2015.01-00001-gb2412df (Jan 29 2015 - 15:01:06)
U-Boot 2015.01-00001-gb2412df (Jan 29 2015 - 15:01:06), Build: jenkins-github_Bootloader-Builder-105
Watchdog enabled
I2C: ready
DRAM: 512 MiB
Using default environment
Net: <ethaddr> not set. Validating first E-fuse MAC
cpsw
switch to partitions #0, OK
mmc0 is current device
Checking for: /uEnv.txt ...
Checking for: /boot.scr ...
Checking for: /boot/boot.scr ...
Checking for: /boot/uEnv.txt ...
1673 bytes read in 21 ms (77.1 KiB/s)
Checking if uname_r is set in /boot/uEnv.txt...
Running uname_boot ...
loading /boot/vmlinuz-3.8.13-bone68b ...
5507296 bytes read in 327 ms (16.1 MiB/s)
loading /boot/dtbs/3.8.13-bone68b/am335x-boneblack.dtb ...
26098 bytes read in 24 ms (1 MiB/s)
loading /boot/initrd.img-3.8.13-bone68b ...
2843062 bytes read in 177 ms (15.3 MiB/s)
debug: [console=ttyO0,115200n8 capemgr.disable_partno=BB-BONELT-HDMI,BB-BONELT-HDMIN root=UUID=e8e4d3da-3529-4fae-ac36-a8a1783311a9 ro rootfstype=ext4 rootwait fixrtc init=/opt/scripts/tools/eMMC/init-eMMC-flasher-v3.sh] ...
debug: [bootz 0x82000000 0x88080000:2b61b6 0x88000000] ...
Kernel image @ 0x82000000 [ 0x000000 - 0x5408e0 ]
## Flattened Device Tree blob at 88000000
Loading Ramdisk to 8fd49000, end 8ffff1b6 ... OK
Loading Device Tree to 8fd3f000, end 8fd485f1 ... OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.8.13-bone68b (colinbes@besterdesigns-ubuntu) (gcc version 4.7.3 20130328 (prerelease) (crosstool-NG linaro-1.13.1-4.7-2013.04-20130415 - Linaro GCC 2013.04) ) #2 SMP Wed Sep 21 14:27:02 CDT 2016
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=50c5387d
[ 0.000000] Machine: Generic AM33XX (Flattened Device Tree), model: TI AM335x BeagleBone
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] AM335X ES2.1 (l2cache sgx neon )
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c0d11000 s14080 r8192 d14592 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129792
[ 0.000000] Kernel command line: console=ttyO0,115200n8 capemgr.disable_partno=BB-BONELT-HDMI,BB-BONELT-HDMIN root=UUID=e8e4d3da-3529-4fae-ac36-a8a1783311a9 ro rootfstype=ext4 rootwait fixrtc init=/opt/scripts/tools/eMMC/init-eMMC-flasher-v3.sh
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] __ex_table already sorted, skipping sort
[ 0.000000] allocated 1048576 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Memory: 511MB = 511MB total
[ 0.000000] Memory: 505612k/505612k available, 18676k reserved, 0K highmem
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf800000 - 0xbfe00000 ( 6 MB)
[ 0.000000] .text : 0xc0008000 - 0xc07c0e18 (7908 kB)
[ 0.000000] .init : 0xc07c1000 - 0xc07fe700 ( 246 kB)
[ 0.000000] .data : 0xc0800000 - 0xc08877c0 ( 542 kB)
[ 0.000000] .bss : 0xc08877c0 - 0xc0900f40 ( 486 kB)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[ 0.000000] NR_IRQS:0 nr_irqs:0 0
[ 0.000000] Total of 128 interrupts on 1 active controller
[ 0.000000] OMAP clockevent source: GPTIMER1 at 24000000 Hz
[ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[ 0.000000] OMAP clocksource: GPTIMER2 at 24000000 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000228] Calibrating delay loop... 993.47 BogoMIPS (lpj=969728)
[ 0.029190] pid_max: default: 32768 minimum: 301
[ 0.029326] Security Framework initialized
[ 0.029385] Mount-cache hash table entries: 512
[ 0.034995] Initializing cgroup subsys cpuacct
[ 0.035018] Initializing cgroup subsys memory
[ 0.035095] Initializing cgroup subsys blkio
[ 0.035184] CPU: Testing write buffer coherency: ok
[ 0.035565] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[ 0.035620] Setting up static identity map for 0x804a3f38 - 0x804a3f84
[ 0.036535] Brought up 1 CPUs
[ 0.036550] SMP: Total of 1 processors activated (993.47 BogoMIPS).
[ 0.037331] devtmpfs: initialized
[ 0.045744] omap_hwmod: wd_timer2: _wait_target_disable failed
[ 0.097879] pinctrl core: initialized pinctrl subsystem
[ 0.098011] rstctl core: initialized rstctl subsystem
[ 0.098290] regulator-dummy: no parameters
[ 0.098600] NET: Registered protocol family 16
[ 0.099147] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.104775] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.105317] platform 49000000.edma: alias fck already exists
[ 0.105335] platform 49000000.edma: alias fck already exists
[ 0.105390] platform 49000000.edma: alias fck already exists
[ 0.106091] OMAP GPIO hardware version 0.1
[ 0.108520] gpio-rctrl rstctl.4: loaded OK
[ 0.111752] No ATAGs?
[ 0.111770] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.113000] cpsw.0: No hwaddr in dt. Using 80:f5:b5:d7:fe:b1 from efuse
[ 0.113019] cpsw.1: No hwaddr in dt. Using 80:f5:b5:d7:fe:b3 from efuse
[ 0.121230] bio: create slab <bio-0> at 0
[ 0.127499] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver
[ 0.127780] vmmcsd_fixed: 3300 mV
[ 0.129340] SCSI subsystem initialized
[ 0.129580] usbcore: registered new interface driver usbfs
[ 0.129639] usbcore: registered new interface driver hub
[ 0.129838] usbcore: registered new device driver usb
[ 0.131073] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 0.131961] input: tps65217_pwr_but as /devices/ocp.3/44e0b000.i2c/i2c-0/0-0024/input/input0
[ 0.133564] DCDC1: at 1500 mV
[ 0.134392] vdd_mpu: 925 <--> 1325 mV at 1325 mV
[ 0.135235] vdd_core: 925 <--> 1150 mV at 1125 mV
[ 0.136035] LDO1: at 1800 mV
[ 0.136822] LDO2: at 3300 mV
[ 0.138294] LDO3: 1800 mV
[ 0.139132] LDO4: at 3300 mV
[ 0.139841] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 0.140288] omap_i2c 44e0b000.i2c: unable to select pin group
[ 0.140800] omap_i2c 4819c000.i2c: bus 1 rev0.11 at 100 kHz
[ 0.142132] omap_i2c 4819c000.i2c: unable to select pin group
[ 0.142274] media: Linux media interface: v0.10
[ 0.142336] Linux video capture interface: v2.00
[ 0.142406] pps_core: LinuxPPS API ver. 1 registered
[ 0.142414] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.142878] Advanced Linux Sound Architecture Driver Initialized.
[ 0.143465] NetLabel: Initializing
[ 0.143476] NetLabel: domain hash size = 128
[ 0.143483] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.143546] NetLabel: unlabeled traffic allowed by default
[ 0.143748] Switching to clocksource gp_timer
[ 0.174959] NET: Registered protocol family 2
[ 0.175643] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.175724] TCP bind hash table entries: 4096 (order: 4, 81920 bytes)
[ 0.175818] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.175880] TCP: reno registered
[ 0.175895] UDP hash table entries: 256 (order: 1, 12288 bytes)
[ 0.175920] UDP-Lite hash table entries: 256 (order: 1, 12288 bytes)
[ 0.176146] NET: Registered protocol family 1
[ 0.176533] RPC: Registered named UNIX socket transport module.
[ 0.176544] RPC: Registered udp transport module.
[ 0.176551] RPC: Registered tcp transport module.
[ 0.176558] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.176774] Trying to unpack rootfs image as initramfs...
[ 0.352623] Freeing initrd memory: 2776K
[ 0.352990] hw perfevents: enabled with ARMv7 Cortex-A8 PMU driver, 5 counters available
[ 0.353247] CPU PMU: attempt to register multiple PMU devices!
[ 0.353272] arm-pmu: probe of arm-pmu failed with error -28
[ 0.353578] omap2_mbox_probe: platform not supported
[ 0.505545] VFS: Disk quotas dquot_6.5.2
[ 0.505681] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.506389] NFS: Registering the id_resolver key type
[ 0.506456] Key type id_resolver registered
[ 0.506465] Key type id_legacy registered
[ 0.506732] fuse init (API version 7.20)
[ 0.507186] Btrfs loaded
[ 0.507291] msgmni has been set to 992
[ 0.508886] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.508902] io scheduler noop registered
[ 0.508910] io scheduler deadline registered
[ 0.508931] io scheduler cfq registered (default)
[ 0.510077] tps65217-bl tps65217-bl: no platform data provided
[ 0.510102] tps65217-bl: probe of tps65217-bl failed with error -22
[ 0.510599] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.511959] omap_uart 44e09000.serial: did not get pins for uart0 error: -19
[ 0.512239] 44e09000.serial: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0
[ 1.280300] console [ttyO0] enabled
[ 1.284618] [drm] Initialized drm 1.1.0 20060810
[ 1.296735] brd: module loaded
[ 1.303694] loop: module loaded
[ 1.307103] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.314426] at24 1-0054: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.321674] at24 1-0055: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.328919] at24 1-0056: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.336141] at24 1-0057: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.350029] bone-capemgr bone_capemgr.9: Baseboard: 'A335BNLT,00C0,2125SBB13845'
[ 1.357794] bone-capemgr bone_capemgr.9: compatible-baseboard=ti,beaglebone-black
[ 1.365640] bone-capemgr bone_capemgr.9: Skipping disabled cape with part# BB-BONELT-HDMI
[ 1.374222] bone-capemgr bone_capemgr.9: Skipping disabled cape with part# BB-BONELT-HDMIN
[ 1.413357] bone-capemgr bone_capemgr.9: slot #0: No cape found
[ 1.450463] bone-capemgr bone_capemgr.9: slot #1: No cape found
[ 1.487572] bone-capemgr bone_capemgr.9: slot #2: No cape found
[ 1.524681] bone-capemgr bone_capemgr.9: slot #3: No cape found
[ 1.530899] bone-capemgr bone_capemgr.9: slot #4: specific override
[ 1.537465] bone-capemgr bone_capemgr.9: bone: Using override eeprom data at slot 4
[ 1.545461] bone-capemgr bone_capemgr.9: slot #4: 'Bone-LT-eMMC-2G,00A0,Texas Instrument,BB-BONE-EMMC-2G'
[ 1.555522] bone-capemgr bone_capemgr.9: slot #5: specific override
[ 1.562080] bone-capemgr bone_capemgr.9: bone: Using override eeprom data at slot 5
[ 1.570078] bone-capemgr bone_capemgr.9: slot #5: 'Bone-Black-HDMI,00A0,Texas Instrument,BB-BONELT-HDMI'
[ 1.580048] bone-capemgr bone_capemgr.9: slot #6: specific override
[ 1.586607] bone-capemgr bone_capemgr.9: bone: Using override eeprom data at slot 6
[ 1.594606] bone-capemgr bone_capemgr.9: slot #6: 'Bone-Black-HDMIN,00A0,Texas Instrument,BB-BONELT-HDMIN'
[ 1.604856] bone-capemgr bone_capemgr.9: Skipping loading of disabled cape with part# BB-BONELT-HDMI
[ 1.614418] bone-capemgr bone_capemgr.9: Skipping loading of disabled cape with part# BB-BONELT-HDMIN
[ 1.624175] bone-capemgr bone_capemgr.9: initialized OK.
[ 1.629747] bone-capemgr bone_capemgr.9: loader: before slot-4 BB-BONE-EMMC-2G:00A0 (prio 1)
[ 1.638582] bone-capemgr bone_capemgr.9: loader: check slot-4 BB-BONE-EMMC-2G:00A0 (prio 1)
[ 1.648729] OneNAND driver initializing
[ 1.653656] usbcore: registered new interface driver cdc_ether
[ 1.659809] usbcore: registered new interface driver rndis_host
[ 1.666055] bone-capemgr bone_capemgr.9: loader: after slot-4 BB-BONE-EMMC-2G:00A0 (prio 1)
[ 1.674855] usbcore: registered new interface driver cdc_ncm
[ 1.680788] bone-capemgr bone_capemgr.9: slot #4: Requesting firmware 'cape-bone-2g-emmc1.dtbo' for board-name 'Bone-LT-eMMC-2G', version '00A0'
[ 1.694808] usbcore: registered new interface driver cdc_acm
[ 1.700745] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.709102] Initializing USB Mass Storage driver...
[ 1.714216] bone-capemgr bone_capemgr.9: slot #4: dtbo 'cape-bone-2g-emmc1.dtbo' loaded; converting to live tree
[ 1.724925] usbcore: registered new interface driver usb-storage
[ 1.731202] USB Mass Storage support registered.
[ 1.736225] bone-capemgr bone_capemgr.9: slot #4: #2 overlays
[ 1.742798] bone-capemgr bone_capemgr.9: slot #4: Applied #2 overlays.
[ 1.749658] bone-capemgr bone_capemgr.9: loader: done slot-4 BB-BONE-EMMC-2G:00A0 (prio 1)
[ 1.758417] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[ 1.764982] musb-hdrc musb-hdrc.0.auto: pdev->id = 0
[ 1.770183] musb-hdrc musb-hdrc.0.auto: drivers/usb/musb/musb_dsps.c:480 dsps_musb_init: OK
[ 1.779142] musb-hdrc musb-hdrc.0.auto: *** mode=3
[ 1.784194] musb-hdrc musb-hdrc.0.auto: *** power=250
[ 1.789959] musb-hdrc musb-hdrc.1.auto: pdev->id = 1
[ 1.795183] musb-hdrc musb-hdrc.1.auto: drivers/usb/musb/musb_dsps.c:480 dsps_musb_init: OK
[ 1.804069] musb-hdrc musb-hdrc.1.auto: *** mode=1
[ 1.809096] musb-hdrc musb-hdrc.1.auto: *** power=250
[ 1.814375] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.820605] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[ 1.828952] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.836064] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.843612] usb usb1: Product: MUSB HDRC host driver
[ 1.848798] usb usb1: Manufacturer: Linux 3.8.13-bone68b musb-hcd
[ 1.855168] usb usb1: SerialNumber: musb-hdrc.1.auto
[ 1.860975] hub 1-0:1.0: USB hub found
[ 1.864943] hub 1-0:1.0: 1 port detected
[ 1.869778] mousedev: PS/2 mouse device common for all mice
[ 1.877130] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[ 1.884743] i2c /dev entries driver
[ 1.889338] pps_ldisc: PPS line discipline registered
[ 1.894720] Driver for 1-wire Dallas network protocol.
[ 1.901206] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 1.908793] device-mapper: ioctl: 4.23.1-ioctl (2012-12-18) initialised: dm-devel@redhat.com
[ 1.917681] cpuidle: using governor ladder
[ 1.922006] cpuidle: using governor menu
[ 1.926387] omap_hsmmc mmc.5: of_parse_phandle_with_args of 'reset' failed
[ 1.933574] omap_hsmmc mmc.5: Failed to get rstctl; not using any
[ 1.940226] edma-dma-engine edma-dma-engine.0: allocated channel for 0:25
[ 1.947379] edma-dma-engine edma-dma-engine.0: allocated channel for 0:24
[ 1.954637] mmc.5 supply vmmc_aux not found, using dummy regulator
[ 1.961427] omap_hsmmc mmc.5: pins are not configured from the driver
[ 1.995610] gpio-rctrl rstctl.4: gpio_rctrl_request eMMC_RSTn
[ 2.001946] omap_hsmmc mmc.11: Got rstctl (gpio:#0 name eMMC_RSTn) label:eMMC_RSTn
[ 2.009920] gpio-rctrl rstctl.4: gpio_rctrl_deassert eMMC_RSTn
[ 2.016248] edma-dma-engine edma-dma-engine.0: allocated channel for 0:3
[ 2.023326] edma-dma-engine edma-dma-engine.0: allocated channel for 0:2
[ 2.030719] mmc.11 supply vmmc_aux not found, using dummy regulator
[ 2.037363] omap_hsmmc mmc.11: pins are not configured from the driver
[ 2.071856] pinctrl-single 44e10800.pinmux: pin 44e10854 already requested by 44e10800.pinmux; cannot claim for gpio-leds.8
[ 2.083519] pinctrl-single 44e10800.pinmux: pin-21 (gpio-leds.8) status -22
[ 2.090797] pinctrl-single 44e10800.pinmux: could not request pin 21 on device pinctrl-single
[ 2.099735] leds-gpio gpio-leds.8: pins are not configured from the driver
[ 2.107658] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.114205] edma-dma-engine edma-dma-engine.0: allocated channel for 0:36
[ 2.121360] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 2.128754] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 2.134971] edma-dma-engine edma-dma-engine.0: allocated channel for 0:5
[ 2.142093] edma-dma-engine edma-dma-engine.0: allocated channel for 0:6
[ 2.152047] usbcore: registered new interface driver usbhid
[ 2.157947] usbhid: USB HID core driver
[ 2.162858] ashmem: initialized
[ 2.166504] logger: created 256K log 'log_main'
[ 2.171305] mmc0: host does not support reading read-only switch. assuming write-enable.
[ 2.179987] logger: created 256K log 'log_events'
[ 2.185131] logger: created 256K log 'log_radio'
[ 2.190189] logger: created 256K log 'log_system'
[ 2.195226] mmc0: new high speed SDHC card at address e624
[ 2.202840] TCP: cubic registered
[ 2.206812] mmcblk0: mmc0:e624 SS08G 7.40 GiB
[ 2.211586] NET: Registered protocol family 10
[ 2.217649] NET: Registered protocol family 17
[ 2.222494] mmcblk0: p1 p2
[ 2.225797] Key type dns_resolver registered
[ 2.230486] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 2.239382] ThumbEE CPU extension supported.
[ 2.243904] Registering SWP/SWPB emulation handler
[ 2.249593] registered taskstats version 1
[ 2.302037] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[ 2.308420] davinci_mdio 4a101000.mdio: detected phy mask fffffffe
[ 2.315004] mmc1: unrecognised EXT_CSD revision 8
[ 2.319937] mmc1: error -22 whilst initialising MMC card
[ 2.332566] libphy: 4a101000.mdio: probed
[ 2.336857] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[ 2.346680] Detected MACID = 80:f5:b5:d7:fe:b1
[ 2.351288] cpsw 4a100000.ethernet: NAPI disabled
[ 2.357591] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
[ 2.371306] ALSA device list:
[ 2.374458] No soundcards found.
[ 2.378670] Freeing init memory: 244K
Loading, please wait...
[ 2.453481] udevd[92]: starting version 175
Begin: Loading essential drivers ... done.
Begin: Running /scripts/init-premount ... done.
Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done.
Begin: Running /scripts/local-premount ... done.
[ 3.527092] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Begin: Running /scripts/local-bottom ... done.
done.
Begin: Running /scripts/init-bottom ... done.
Starting eMMC Flasher from microSD media
Version: [1.003: 2015-08-31: use on x15 too...]
Checking for Valid bbb-eeprom header
Valid bbb-eeprom header found [335]
copying: [/dev/mmcblk0] -> [/dev/mmcblk1]
lsblk:
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
mmcblk0 179:0 0 7.4G 0 disk
|-mmcblk0p1 179:1 0 96M 0 part /boot/uboot
`-mmcblk0p2 179:2 0 2.8G 0 part /
df -h | grep rootfs:
rootfs 2.6G 1.9G 635M 75% /
Error: [/dev/mmcblk1] does not exist
writing to [/dev/mmcblk1] failed...
[ 9.355618] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000100
[ 9.355618]
[ 9.365202] [<c001125d>] (unwind_backtrace+0x1/0x98) from [<c049a8f3>] (panic+0x5b/0x160)
[ 9.373743] [<c049a8f3>] (panic+0x5b/0x160) from [<c00332c1>] (do_exit+0x5f5/0x674)
[ 9.381727] [<c00332c1>] (do_exit+0x5f5/0x674) from [<c0033383>] (do_group_exit+0x27/0x6c)
[ 9.390344] [<c0033383>] (do_group_exit+0x27/0x6c) from [<c00333d5>] (__wake_up_parent+0x1/0x18)
[ 9.399520] [<c00333d5>] (__wake_up_parent+0x1/0x18) from [<c000c741>] (ret_fast_syscall+0x1/0x46)
