BBB and Chipsee 7" Cap Touch
I am trying to get the chipsee 7" cap touch lcd to work on my beaglebone black. The board is a rev A5C.
I added the dtb entry to uEnv.txt and did the command line to update x. Not sure that second was needed because x isn’t supported, but did it anyway.
The screen now turns on during boot, but nothing ever shows up.
I don’t need a GUI I just need a frame buffer. I tried doing the cat /dev/urandom > /dev/fb0 and it first said no more room on the device. Then each time I did it after that it just spewed random stuff to the console.
I rebooted and now it just always says: cat: write error: No space left on device. I assume that is because fb0 isn’t really connected to anything.
I am running the latest stretch 9.5 image from here:
https://beagleboard.org/latest-images
Specifically I am running this one: Debian 9.5 2018-10-07 4GB SD LXQT
Can someone tell me how to get frame buffer to work on this setup?
Did you try on the latest images https://beagleboard.org/latest-images?
Having the same problem with the latest image (Debian 10.3) Any ideas?
Sorry, the old directions where:
dtb=am335x-boneblack-bbb-exp-c.dtb on the /boot/uEnv.txt
With the conversion to using v4.19.x this will not work today..
I need to go looking for my old Chipsee cape..
In the meantime, downgrade to v4.14.x-ti by running:
sudo /opt/scripts/tools/update_kernel.sh --ti-channel --lts-4_14
Tracking via: https://github.com/beagleboard/Latest-Images/issues/43
