BBB and Geany
Hi everyone
Can i program my BBB with Geany (EDI) ?? if that’s possible how can i do it ?? i’m using a normal PC that runs windows 7 32bits , i’m new with the BBB and i’m stocked with the programming issue , need help
Best regards
I edit files on my BB from a Windows PC using Notepad++ with its FTP
plugin. It works very well. I use putty to build.
I also use Geany from a Linux PC.
Hi Taceant,
I installed Geany in my pc , how can i configure it to compile my C programs and send them to my BBB ???
Best regards
Hi Wadi,
To compile on the PC for the BB means cross-compiling. There are many
ways of doing that, it can be tricky though, just do a Google search
or search this email list. I have done it with the BB only when I was
playing with buildroot [1] which makes it very easy.
When using Debian (or previously Angstrom) on the BB I always used the
gcc compiler that comes with them, in other words I did not
cross-compile. This is much easier, I just used gcc via putty.
[1] https://buildroot.org/
Hi Taceant,
Sorry for bothering you again , i’m knew with Linux , i have a huge problems using BBB terminal , many commands did not work and it one erreur appears in every command , the " -bash : command not found " what is the problem and how can i fix it , thanks again.
Best regards
