I was trying to follow this guide: http://www.armhf.com/index.php/boards/beaglebone-black/
and I seem to be having some problems booting into the board. Angstrom works, of course, but the user/boot button (little raised white/black square?) seems to not budge at all. It’s on the opposite end of the full-sized USB. Did I read the schematics wrong? Do I need to hold down the button at all anymore?
These buttons are very stiff, i nearly felt like i was going to press the board in half first time I used them.
Right on the money. The buttons were alarmingly stiff during the first attempt(s). I managed to press the button and the screen looks like it's working to a degree. I have some gabled or otherwise squashed text up the upper portion of the screen. Instead of saying 1080p, it's a weird 500something format on my big screen. I've been searching through some of the posts, but haven't had a chance to look up all of them. Good news is the button works.
It is normal for the buttons to be a little stiff when first use. They will loosen up with use.
Well "1" is the eMMC... on the beaglebone black... so yeah...
Does this make sense?
mmc0 is current device
SD/MMC found on device 0
reading uEnv.txt
302 bytes read in 4 ms (73.2 KiB/s)
Importing environment from mmc ...
uenvcmd was not defined in uEnv.txt ...
trying eMMC (BeagleBone Black) ...
mmc_send_cmd : timeout: No status update
Card did not respond to voltage select!
patch:
https://github.com/eewiki/u-boot-patches/commit/3165b9c404d996f23ce9daff97a8991e7a9663fd
and added this line to the wiki page:
[As v3.2.x/v3.8.x are too vastly different kernels (board file vs
device tree) you need to uncomment one of the "uenvcmd" variables
shown in the uEnv.txt boot script, otherwise it will not boot the
kernel image.]
Your Welcome..
What 'fix'? it's the exact same setting for the serial port "ttyO0"
that's already on the wiki page..
Mark.... "Yet Again" I have no idea where you 'wandered' in the wiki
directions.. So here you go, figure it out, as I really won't be back
to debug anything till early next week..
Line by Line on my console:
http://pastebin.com/pPApkeUB
BeagleBone (white) perfectly happy booting with 3.8 (although it
really doesn't like that early proto dvi adapter..)
http://pastebin.com/T5cqn9Jn
"if" the network cable is not plugged in (and eth0 is defined in
/etc/network/interfaces), there could be a 2 minute delay as 'upstart'
is trying to get an IP 'before' giving login access. But after those
2 minutes, the login prompt will appear..
Another thing to look for... are the LED's still blinking? If not,
the board probably locked up due to lack of power.. (just noticed that
today)
Hi Robert. Thanks!
The LED are blinking similar to what they do for Angstrom . I am in the process of finding a proper ethernet cable and the instructions to try to get in/set ip address over ethernet to ensure its REALLY alive
I did somehow miss this step, Appears like this is done once correct?
Upgrade distro “device-tree-compiler” package
:~$ /usr/local/bin/dtc -v
“/usr/local/bin/” is used to not interfere with the debian package in “/usr/bin”
