My beagle bone black will not flash EMMC I am using Linux ubuntu with balena etcher to write am335x-eMMC-flasher-debian-11.8-xfce-armhf-2023-10-07-4gb.img.xz I press the SW2 User button and wait to boot from SD card. However it stops somewhere and powers down. I don’t see the start page either anymore.
how are you powering the BBB, barrel jack or usb? if usb, is it via powered hub?
Barrel jack.
Connect your serial debug channel to a Terminal at 115200 and have a look at the output.
Otherwise you’re driving with a sack over your head…
I did. Everything works well. I managed to resolve the issue. It turns out hdmi to dp converter is not active. Hence nothing display to picked up. Otherwise the BBB works well. I am able to flash EMMC and SD card boot.
