Hi!
I have a BBB cloned with NAND memory installed instead of eMMC. Having successfully compiled and using u-boot with NAND enabled I can’t enable NAND in Linux kernel provided by Robert. NAND works and is boots u-boot but Linux hangs trying to send the RESET command to the NAND chip. If I boot the TI EZSDK the NAND is successfully identified. As I understand both kernels have the same roots and are pretty similar.
Does anybody know which patch spoiled the NAND detection?
