I'm attempting to get a beaglebone black rev B with a 4DCAPE-43T up and running with bone-debian-8.1-lxqt-4gb-armhf-2015-07-12-4gb.img
I've put the image on a SD card and I'm running from the SD card (since rev B only has 2gb on board)
I've upgraded the image following the instructions on https://github.com/beagleboard/bb.org-overlays
sudo apt-get update
sudo apt-get upgrade
cd /opt/scripts/tools
git pull
sudo ./update_kernel.sh --lts --bone-channel
dtc --version
Version: DTC 1.4.1-g37bed390
./dtc-overlay.sh
-bash: ./dtc-overlay.sh: No such file or directory
The overlay shell is missing at this point.
I'm not sure what I need in /boot/uEnv.txt. I assume it is:
I’m attempting to get a beaglebone black rev B with a 4DCAPE-43T up and running with bone-debian-8.1-lxqt-4gb-armhf-2015-07-12-4gb.img
I’ve put the image on a SD card and I’m running from the SD card (since rev B only has 2gb on board)
I’ve upgraded the image following the instructions on https://github.com/beagleboard/bb.org-overlays
sudo apt-get update
git pull
dtc --version
./dtc-overlay.sh
This script is in the bb.org-overlays repo.
I’m not sure what I need in /boot/uEnv.txt. I assume it is:
Now I'm attempting to get this working on a Beaglebone Black rev C.
I want it to run in the internal eMMC.
I get everything to install fine.
When I change the uEnv.txt to use the blank overlay, it disables the HDMI and the eMMC, so it no longer boots.
Which overlay is needed to disable HDMI, enable eMMC and detect 4DCAPE?
Yes, there is a problem somewhere.
I've tested with am335x-boneblack-emmc-overlay.dtb
It does better - before using am335x-boneblack-overlay.dtb the lights would all go out immediately after reboot.
Now they stay on, but they transition to all lit up and hangs.
I can't shell into it anymore.
looks like I will need to use the SD card and not use the eMMC for this release.
Robert, would you be so kind to advise, if there is any mistake in my numerous attempts to connect 4dcape-43t to BBB. I’ve been trying on a number of images, following various instructions from internet, ad a screen is still black.
ubuntu@arm:~$ uname -a Linux arm 4.1.15-ti-rt-r40 #1 SMP PREEMPT RT Fri Jan 8 09:44:57 UTC 2016 armv7l armv7l armv7l GNU/Linux ubuntu@arm:~$ dtc --version Version: DTC 1.4.1-g1e75ebc9
