Brand new BBB, followed directions to connect USB and install Mac drivers. BBB does not show up as a USB drive (or at all) and browsing to 192.168.7.2 times out.
I’ve tried:
reflashing several times
connected to Windows machine
different mini-usb cable
booted Angstrom from microSD card
The board works; when HDMI monitor and keyboard/mouse is connected, the desktop runs just fine.
We can check that the driver installed correctly by checking the Device Manager.
Windows: Go to Start, Run, and type ‘mmc devmgmt.msc’ to open Device Manager.
If your computer is reading your BBB correctly, BBB should be listed under Gadget Serial (COM#).
If you look around the Device Manager and see an item with a yellow exclamation mark, your drivers didn’t install successfully and that is most likely your BBB.
Yes, the drivers were downloaded from there. I will go through the steps you outline tonight to see result.
Question - If plugged into the USB port of a machione with no drivers installed, should the BBB still show up as a USB thumbdrive?
OK, went through the procedure on a windows laptop with the drivers installed; nothing showed up in device manager.
To summarize, doesn't show up as a USB device on any of my macs or windows laptops (installed drivers on all), can reach with browser at 192.168.7.2. It does boot to the angstrom desktop with a monitor and keyboard attached.
thanks, but I've left it plugged in much longer than that. I tried updating with the micro SD card as well. The update bean to take, but still no USB connectivity.
if we're talking about how long it takes for /media/BEAGLEBONE to be
mounted and accessible on the host, it takes only a few seconds from
when i plug in my BBB via USB tether. is that what we're talking
about?
Hi, I just bought my BBB for the first time too, I followed the instructions on the beagleboard.org site and downloaded the drivers first, then installed them, after installing, I plugged the BBB in the USB and it detects it but it doesn’t recognize it as a USB device which is very confusing considered that I didn’t flash the eMMC or anything of the sort. I keep removing the drivers and reinstall them but still the same result. I can’t see it as a USB device but the Windows detects it in the port but can’t configure the drivers for it (other words the yellow exclamation mark on the BeagleboardBlack in Device Manager). Is there an updated version of the drivers maybe or is there a step that i missed in the instructions because I followed from the beginning. Any help would be very appreciated. Thanks.
