BBB does not boot - only power LED on. USR LEDs OFF
The BBB was working fine till now, using it from couple of months. Now suddenly, the BBB does not boot either by SD-Card or eMMC. When powered by USB or 5V power jack, only the Power LED is on (stays on).
But all USR LEDs are off. And i have attached to serial console, no output to serial as well.
Is the board dead ??
Can anyone please help me out here…
Grab the minimal image from here:
Use etcher.io to flash it to a microSD..
  • Stick your microSD into the board
  • Hold the boot button
  • Insert power
  • Report what shows up over the serial port
Thanks for the response.
Flashed am335x-debian-11.5-minimal-armhf-2022-10-01-2gb on to microSD.
Pressed the boot button for few seconds during power up.
There is no output on the serial console ! and only power LED is on. tried the powerup cycle couple of times. Also tried both USB and power jack.
Thanks and Regards,
Roshan
20221005_121120
Sadly, looks like it’s now time to recycle that board…
Oh that’s bad. Also checked voltage drop across the USR leds, its 5V :frowning:
