I have a BBB just updated to the latest firmware. My version on the BBB of LIBC6 is v2.16. I am compiling a project in Eclipse which if I include the line
root@beaglebone:~/test# ldd test
./test: /lib/libc.so.6: version `GLIBC_2.17’ not found (required by ./test)
libpthread.so.0 => /lib/libpthread.so.0 (0xb6ed1000)
libc.so.6 => /lib/libc.so.6 (0xb6da0000)
/lib/ld-linux.so.3 (0xb6efc000)
However I thought this solution (below) was for Ubuntu - I am using Angstrom. Sudo is not used. Fogive me if I am being a little naive here as I am new to using Linux.
Had face the same problem. Solved it by the following steps.
Just looked again at the Stack overflow solution and it seems to be downloading a i386 file. So I am guessing that this is for the PC with the cross compiler on it (and not the Beaglebone). My host PC is running Windows 7 not Linux.
Also my host PC has the 2.17 library it is the Angstrom library on the BBB that is at 2.16 and probably needs updating somehow.
Best option you have is finding the source and building the library directly on the BBB. Or perhaps checking to see if one of the other distro’s running on the BBB have it as a package already, then moving to it.
I am not sure why some of you are still sticking with Angstrom on the BBB, as it seems to be a serious hurdle to overcome in many ways.
OK still no progress with Angstrom, but I thought I would give the new Debian image for SD card a try. This is miles easier to use than the previous - USB works out of the box . However the libc6 library was 2.13 after updating etc, however I stumbled across the following bash script
#!/bin/sh
echo "deb http://ftp.debian.org/debian sid main" >> /etc/apt/sources.list
apt-get update
apt-get -t sid install libc6 libc6-dev libc6-dbg
echo "Please remember to hash out sid main from your sources list. /etc/apt/sources.list"
Which installed a test version of 2.18
This worked fine. Now I just have to get the other bits I had working, working again on this image, oh and speed up the boot time significantly.
If you add the following to your /boot/uBoot/uEnv.txt, you will use systemd as the init process. This will speed up boot time significantly. #Optional arguments optargs=init=/bin/systemd
