I had earlier asked the procedure to flash the board in the forum and was able to succesfully flash it afterwards.
Now today a new issue has occurred where when I try to flash a new image (12.2 and 11.8 Iot eMMC images tried) in the end of flash process all 4 LEDs start blinking together.
This is the console log of boot process after the failed flashing:
U-Boot SPL 2022.04-gbaca7b46 (Jan 15 2024 - 19:59:28 +0000)
Trying to boot from MMC2
U-Boot 2022.04-gbaca7b46 (Jan 15 2024 - 19:59:28 +0000)
CPU : AM335X-GP rev 2.1
Model: TI AM335x BeagleBone Black
DRAM: 512 MiB
Reset Source: Global external warm reset has occurred.
RTC 32KCLK Source: External.
Core: 150 devices, 14 uclasses, devicetree: separate
WDT: Started wdt@44e35000 with servicing (60s timeout)
Loading Environment from EXT4... Board: BeagleBone Black
<ethaddr> not set. Validating first E-fuse MAC
BeagleBone Black:
Model: BeagleBone Black Industrial:
BeagleBone Cape EEPROM: no EEPROM at address: 0x54
BeagleBone Cape EEPROM: no EEPROM at address: 0x55
BeagleBone Cape EEPROM: no EEPROM at address: 0x56
BeagleBone Cape EEPROM: no EEPROM at address: 0x57
Net: eth2: ethernet@4a100000, eth3: usb_ether
Press SPACE to abort autoboot in 0 seconds
board_name=[A335BNLT] ...
board_rev=[EIA0] ...
switch to partitions #0, OK
Scanning mmc 1:1...
Scanning disk mmc@48060000.blk...
Disk mmc@48060000.blk not ready
Scanning disk mmc@481d8000.blk...
Found 2 disks
No EFI system partition
BootOrder not defined
EFI boot manager: Cannot load any image
Checking for: /uEnv.txt ...
Checking for: /boot/uEnv.txt ...
1712 bytes read in 3 ms (556.6 KiB/s)
Checking if uname_r is set in /boot/uEnv.txt...
Running uname_boot ...
loading /boot/vmlinuz-5.10.168-ti-r72 ...
11358720 bytes read in 715 ms (15.2 MiB/s)
debug: [enable_uboot_overlays=1] ...
debug: [enable_uboot_cape_universal=1] ...
debug: [uboot_base_dtb_univ=am335x-boneblack-uboot-univ.dtb] ...
uboot_overlays: [uboot_base_dtb=am335x-boneblack-uboot-univ.dtb] ...
uboot_overlays: Switching too: dtb=am335x-boneblack-uboot-univ.dtb ...
loading /boot/dtbs/5.10.168-ti-r72/am335x-boneblack-uboot-univ.dtb ...
210757 bytes read in 16 ms (12.6 MiB/s)
Found 0 extension board(s).
uboot_overlays: [fdt_buffer=0x60000] ...
uboot_overlays: loading /boot/dtbs/5.10.168-ti-r72/overlays/BB-ADC-00A0.dtbo ...
645 bytes read in 4 ms (157.2 KiB/s)
uboot_overlays: loading /boot/dtbs/5.10.168-ti-r72/overlays/BB-BONE-eMMC1-01-00A0.dtbo ...
1605 bytes read in 5 ms (313.5 KiB/s)
uboot_overlays: loading /boot/dtbs/5.10.168-ti-r72/overlays/BB-HDMI-TDA998x-00A0.dtbo ...
5321 bytes read in 4 ms (1.3 MiB/s)
loading /boot/initrd.img-5.10.168-ti-r72 ...
13540393 bytes read in 863 ms (15 MiB/s)
debug: [console=ttyS0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk1p1 ro rootfstype=ext4 rootwait init=/usr/sbin/init-beagle-flasher] ...
debug: [bootz 0x82000000 0x88080000:ce9c29 88000000] ...
Kernel image @ 0x82000000 [ 0x000000 - 0xad5200 ]
## Flattened Device Tree blob at 88000000
Loading Ramdisk to 8f316000, end 8ffffc29 ... OK
Loading Device Tree to 8f27e000, end 8f315fff ... OK
Starting kernel ...
[ 0.000000] Linux version 5.10.168-ti-r72 (voodoo@rpi4b4g-02) (gcc (Debian 10.2.1-6) 10.2.1 20210110, GNU ld (GNU Binutils for Debian) 2.35.2) #1bullseye SMP PREEMPT Sat Sep 30 03:37:21 UTC 2023
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] OF: fdt: Machine model: TI AM335x BeagleBone Black
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] efi: UEFI not found.
[ 0.000000] cma: Reserved 48 MiB at 0x9c800000
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000080000000-0x000000009fdfffff]
[ 0.000000] HighMem empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009fdfffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000009fdfffff]
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES2.1 (sgx neon)
[ 0.000000] percpu: Embedded 21 pages/cpu s54604 r8192 d23220 u86016
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 129412
[ 0.000000] Kernel command line: console=ttyS0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk1p1 ro rootfstype=ext4 rootwait init=/usr/sbin/init-beagle-flasher
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
[ 0.000000] Memory: 430608K/522240K available (15360K kernel code, 1448K rwdata, 4040K rodata, 1024K init, 446K bss, 42480K reserved, 49152K cma-reserved, 0K highmem)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] IRQ: Found an INTC at 0x(ptrval) (revision 5.0) with 128 interrupts
[ 0.000000] TI gptimer clocksource: always-on /ocp/interconnect@44c00000/segment@200000/target-module@31000
[ 0.000011] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000032] clocksource: dmtimer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000418] TI gptimer clockevent: 24000000 Hz at /ocp/interconnect@48000000/segment@0/target-module@40000
[ 0.002585] Console: colour dummy device 80x30
[ 0.002681] Calibrating delay loop... 995.32 BogoMIPS (lpj=1990656)
[ 0.048476] pid_max: default: 32768 minimum: 301
[ 0.049082] LSM: Security Framework initializing
[ 0.049207] Yama: becoming mindful.
[ 0.049513] AppArmor: AppArmor initialized
[ 0.049535] TOMOYO Linux initialized
[ 0.049734] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.049753] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.051439] CPU: Testing write buffer coherency: ok
[ 0.051530] CPU0: Spectre v2: using BPIALL workaround
[ 0.072911] Setting up static identity map for 0x80100000 - 0x80100060
[ 0.080496] rcu: Hierarchical SRCU implementation.
[ 0.089770] EFI services will not be available.
[ 0.100505] smp: Bringing up secondary CPUs ...
[ 0.100527] smp: Brought up 1 node, 1 CPU
[ 0.100541] SMP: Total of 1 processors activated (995.32 BogoMIPS).
[ 0.100552] CPU: All CPU(s) started in SVC mode.
[ 0.101495] devtmpfs: initialized
[ 0.144834] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.145353] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.145399] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
[ 0.149315] pinctrl core: initialized pinctrl subsystem
[ 0.150508] DMI not present or invalid.
[ 0.151474] NET: Registered protocol family 16
[ 0.154677] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.195588] l3-aon-clkctrl:0000:0: failed to disable
[ 0.196370] audit: initializing netlink subsys (disabled)
[ 0.197926] thermal_sys: Registered thermal governor 'fair_share'
[ 0.197941] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.197957] thermal_sys: Registered thermal governor 'step_wise'
[ 0.197968] thermal_sys: Registered thermal governor 'user_space'
[ 0.197978] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.198909] cpuidle: using governor ladder
[ 0.198997] audit: type=2000 audit(0.188:1): state=initialized audit_enabled=0 res=1
[ 0.199038] cpuidle: using governor menu
[ 4.802175] hw-breakpoint: debug architecture 0x4 unsupported.
[ 4.850778] Kprobes globally optimized
[ 4.872909] raid6: skip pq benchmark and using algorithm neonx8
[ 4.872944] raid6: using neon recovery algorithm
[ 4.880599] iommu: Default domain type: Translated
[ 4.885428] SCSI subsystem initialized
[ 4.889027] usbcore: registered new interface driver usbfs
[ 4.889128] usbcore: registered new interface driver hub
[ 4.889194] usbcore: registered new device driver usb
[ 4.890396] mc: Linux media interface: v0.10
[ 4.890454] videodev: Linux video capture interface: v2.00
[ 4.890675] pps_core: LinuxPPS API ver. 1 registered
[ 4.890690] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 4.890742] PTP clock support registered
[ 4.893232] NetLabel: Initializing
[ 4.893257] NetLabel: domain hash size = 128
[ 4.893267] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 4.893403] NetLabel: unlabeled traffic allowed by default
[ 4.894637] clocksource: Switched to clocksource dmtimer
[ 5.956394] VFS: Disk quotas dquot_6.6.0
[ 5.956553] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 5.956872] FS-Cache: Loaded
[ 5.957288] CacheFiles: Loaded
[ 5.958309] AppArmor: AppArmor Filesystem Enabled
[ 5.972031] NET: Registered protocol family 2
[ 5.972322] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 5.973859] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 5.974167] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 5.974241] TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 5.974303] TCP: Hash tables configured (established 4096 bind 4096)
[ 5.975030] MPTCP token hash table entries: 512 (order: 1, 8192 bytes, linear)
[ 5.975138] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 5.975177] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 5.975451] NET: Registered protocol family 1
[ 5.988931] RPC: Registered named UNIX socket transport module.
[ 5.988957] RPC: Registered udp transport module.
[ 5.988968] RPC: Registered tcp transport module.
[ 5.988977] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 5.988997] NET: Registered protocol family 44
[ 5.989866] Trying to unpack rootfs image as initramfs...
[ 6.744123] Freeing initrd memory: 13224K
[ 6.745242] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[ 6.751232] Initialise system trusted keyrings
[ 6.751701] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 6.760172] zbud: loaded
[ 6.768297] NFS: Registering the id_resolver key type
[ 6.768375] Key type id_resolver registered
[ 6.768388] Key type id_legacy registered
[ 6.768591] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 6.768608] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 6.768663] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 6.769798] fuse: init (API version 7.32)
[ 6.856956] NET: Registered protocol family 38
[ 6.856987] xor: automatically using best checksumming function neon
[ 6.857003] Key type asymmetric registered
[ 6.857016] Asymmetric key parser 'x509' registered
[ 6.857100] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 6.861494] io scheduler mq-deadline registered
[ 7.596268] ti-sysc: probe of 44e31000.target-module failed with error -16
[ 7.734692] omap_i2c 4802a000.i2c: bus 1 rev0.11 at 100 kHz
[ 7.790770] ti-sysc: probe of 48040000.target-module failed with error -16
[ 8.009412] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[ 8.134564] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[ 8.675040] debugfs: Directory '49000000.dma' with parent 'dmaengine' already present!
[ 8.675091] edma 49000000.dma: TI EDMA DMA engine driver
[ 8.705972] pinctrl-single 44e10800.pinmux: 142 pins, size 568
[ 8.707512] gpio-of-helper ocp:cape-universal: Failed to get gpio property of 'P8_03'
[ 8.707537] gpio-of-helper ocp:cape-universal: Failed to create gpio entry
[ 8.729024] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 8.733997] printk: console [ttyS0] disabled
[ 8.734166] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 20, base_baud = 3000000) is a 8250
[ 9.589577] printk: console [ttyS0] enabled
[ 9.595900] 48022000.serial: ttyS1 at MMIO 0x48022000 (irq = 27, base_baud = 3000000) is a 8250
[ 9.606566] 48024000.serial: ttyS2 at MMIO 0x48024000 (irq = 28, base_baud = 3000000) is a 8250
[ 9.617231] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 43, base_baud = 3000000) is a 8250
[ 9.627646] 481a8000.serial: ttyS4 at MMIO 0x481a8000 (irq = 44, base_baud = 3000000) is a 8250
[ 9.638046] 481aa000.serial: ttyS5 at MMIO 0x481aa000 (irq = 45, base_baud = 3000000) is a 8250
[ 9.651603] omap_rng 48310000.rng: Random Number Generator ver. 20
[ 9.658221] random: crng init done
[ 9.774833] loop: module loaded
[ 9.778357] at24 2-0054: supply vcc not found, using dummy regulator
[ 9.814066] at24 2-0055: supply vcc not found, using dummy regulator
[ 9.850061] at24 2-0056: supply vcc not found, using dummy regulator
[ 9.886053] at24 2-0057: supply vcc not found, using dummy regulator
[ 9.989438] mdio_bus 4a101000.mdio: mii_bus 4a101000.mdio couldn't get reset GPIO
[ 9.998320] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4
[ 10.004890] cpsw 4a100000.ethernet: ALE Table size 1024
[ 10.010360] cpsw 4a100000.ethernet: cpts: overflow check period 1250 (jiffies)
[ 10.017766] cpsw 4a100000.ethernet: Detected MACID = 58:2b:0a:b9:74:67
[ 10.028063] usbcore: registered new interface driver smsc95xx
[ 10.036686] am335x-phy-driver 47401300.usb-phy: supply vcc not found, using dummy regulator
[ 10.045571] am335x-phy-driver 47401300.usb-phy: dummy supplies not allowed for exclusive requests
[ 10.060369] am335x-phy-driver 47401b00.usb-phy: supply vcc not found, using dummy regulator
[ 10.069361] am335x-phy-driver 47401b00.usb-phy: dummy supplies not allowed for exclusive requests
[ 10.084999] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 10.091836] ehci-platform: EHCI generic platform driver
[ 10.097788] ehci-omap: OMAP-EHCI Host Controller driver
[ 10.117304] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[ 10.122981] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[ 10.130802] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 10.139138] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 10.146414] usb usb1: Product: MUSB HDRC host driver
[ 10.151419] usb usb1: Manufacturer: Linux 5.10.168-ti-r72 musb-hcd
[ 10.157646] usb usb1: SerialNumber: musb-hdrc.1
[ 10.163239] hub 1-0:1.0: USB hub found
[ 10.167167] hub 1-0:1.0: 1 port detected
[ 10.184593] omap_rtc 44e3e000.rtc: already running
[ 10.191329] omap_rtc 44e3e000.rtc: registered as rtc0
[ 10.197247] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01T00:01:15 UTC (946684875)
[ 10.208158] i2c /dev entries driver
[ 10.217577] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 10.225401] softdog: initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=0)
[ 10.233929] softdog: soft_reboot_cmd=<not set> soft_active_on_boot=0
[ 10.243716] cpuidle: enable-method property 'ti,am3352' found operations
[ 10.252597] sdhci: Secure Digital Host Controller Interface driver
[ 10.258907] sdhci: Copyright(c) Pierre Ossman
[ 10.263306] sdhci-pltfm: SDHCI platform and OF driver helper
[ 10.278820] sdhci-omap 481d8000.mmc: supply vqmmc not found, using dummy regulator
[ 10.286731] ledtrig-cpu: registered to indicate activity on CPUs
[ 10.295918] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 10.302285] omap-aes 53500000.aes: will run requests pump with realtime priority
[ 10.314152] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 10.320640] omap-sham 53100000.sham: will run requests pump with realtime priority
[ 10.333258] hid: raw HID events driver (C) Jiri Kosina
[ 10.339772] usbcore: registered new interface driver usbhid
[ 10.345552] mmc1: SDHCI controller on 481d8000.mmc [481d8000.mmc] using External DMA
[ 10.353462] usbhid: USB HID core driver
[ 10.358511] remoteproc remoteproc0: wkup_m3 is available
[ 10.375015] NET: Registered protocol family 10
[ 10.419050] mmc1: new high speed MMC card at address 0001
[ 10.429094] mmcblk1: mmc1:0001 W62704 3.56 GiB
[ 10.439637] mmcblk1boot0: mmc1:0001 W62704 partition 1 2.00 MiB
[ 10.451517] mmcblk1boot1: mmc1:0001 W62704 partition 2 2.00 MiB
[ 10.464953] mmcblk1rpmb: mmc1:0001 W62704 partition 3 512 KiB, chardev (240:0)
[ 10.488103] mmcblk1: p1
[ 10.495833] Segment Routing with IPv6
[ 10.499961] mip6: Mobile IPv6
[ 10.505499] NET: Registered protocol family 17
[ 10.516315] Key type dns_resolver registered
[ 10.521516] mpls_gso: MPLS GSO support
[ 10.525650] ThumbEE CPU extension supported.
[ 10.530102] Registering SWP/SWPB emulation handler
[ 10.535366] omap_voltage_late_init: Voltage driver support not added
[ 10.542794] registered taskstats version 1
[ 10.546972] Loading compiled-in X.509 certificates
[ 10.551971] zswap: loaded using pool lzo/zbud
[ 10.561282] Key type .fscrypt registered
[ 10.565341] Key type fscrypt-provisioning registered
[ 10.577549] Btrfs loaded, crc32c=crc32c-generic
[ 10.582340] AppArmor: AppArmor sha1 policy hashing enabled
[ 10.609166] OMAP GPIO hardware version 0.1
[ 10.643483] tps65217-pmic: Failed to locate of_node [id: -1]
[ 10.660462] tps65217-bl: Failed to locate of_node [id: -1]
[ 10.669224] tps6521x_pwrbutton tps65217-pwrbutton: DMA mask not set
[ 10.676628] input: tps65217_pwr_but as /devices/platform/ocp/44c00000.interconnect/44c00000.interconnect:segment@200000/44e0b000.target-module/44e0b000.i2c/i2c-0/0-0024/tps65217-pwrbutton/input/input0
[ 10.695250] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 10.702339] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 10.709580] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 10.723287] gpio-of-helper ocp:cape-universal: Allocated GPIO id=0 name='P8_03'
[ 10.730937] gpio-of-helper ocp:cape-universal: Allocated GPIO id=1 name='P8_04'
[ 10.738488] gpio-of-helper ocp:cape-universal: Allocated GPIO id=2 name='P8_05'
[ 10.746046] gpio-of-helper ocp:cape-universal: Allocated GPIO id=3 name='P8_06'
[ 10.753859] gpio-of-helper ocp:cape-universal: Allocated GPIO id=4 name='P8_07'
[ 10.761479] gpio-of-helper ocp:cape-universal: Allocated GPIO id=5 name='P8_08'
[ 10.769064] gpio-of-helper ocp:cape-universal: Allocated GPIO id=6 name='P8_09'
[ 10.776605] gpio-of-helper ocp:cape-universal: Allocated GPIO id=7 name='P8_10'
[ 10.784165] gpio-of-helper ocp:cape-universal: Allocated GPIO id=8 name='P8_11'
[ 10.791724] gpio-of-helper ocp:cape-universal: Allocated GPIO id=9 name='P8_12'
[ 10.799375] gpio-of-helper ocp:cape-universal: Allocated GPIO id=10 name='P8_13'
[ 10.807063] gpio-of-helper ocp:cape-universal: Allocated GPIO id=11 name='P8_14'
[ 10.814736] gpio-of-helper ocp:cape-universal: Allocated GPIO id=12 name='P8_15'
[ 10.822371] gpio-of-helper ocp:cape-universal: Allocated GPIO id=13 name='P8_16'
[ 10.830016] gpio-of-helper ocp:cape-universal: Allocated GPIO id=14 name='P8_17'
[ 10.837642] gpio-of-helper ocp:cape-universal: Allocated GPIO id=15 name='P8_18'
[ 10.845282] gpio-of-helper ocp:cape-universal: Allocated GPIO id=16 name='P8_19'
[ 10.852904] gpio-of-helper ocp:cape-universal: Allocated GPIO id=17 name='P8_20'
[ 10.860569] gpio-of-helper ocp:cape-universal: Allocated GPIO id=18 name='P8_21'
[ 10.868205] gpio-of-helper ocp:cape-universal: Allocated GPIO id=19 name='P8_22'
[ 10.875824] gpio-of-helper ocp:cape-universal: Allocated GPIO id=20 name='P8_23'
[ 10.883492] gpio-of-helper ocp:cape-universal: Allocated GPIO id=21 name='P8_24'
[ 10.891123] gpio-of-helper ocp:cape-universal: Allocated GPIO id=22 name='P8_25'
[ 10.898772] gpio-of-helper ocp:cape-universal: Allocated GPIO id=23 name='P8_26'
[ 10.906414] gpio-of-helper ocp:cape-universal: Allocated GPIO id=24 name='P8_27'
[ 10.914034] gpio-of-helper ocp:cape-universal: Allocated GPIO id=25 name='P8_28'
[ 10.921667] gpio-of-helper ocp:cape-universal: Allocated GPIO id=26 name='P8_29'
[ 10.929311] gpio-of-helper ocp:cape-universal: Allocated GPIO id=27 name='P8_30'
[ 10.936935] gpio-of-helper ocp:cape-universal: Allocated GPIO id=28 name='P8_31'
[ 10.944580] gpio-of-helper ocp:cape-universal: Allocated GPIO id=29 name='P8_32'
[ 10.952216] gpio-of-helper ocp:cape-universal: Allocated GPIO id=30 name='P8_33'
[ 10.959857] gpio-of-helper ocp:cape-universal: Allocated GPIO id=31 name='P8_34'
[ 10.967502] gpio-of-helper ocp:cape-universal: Allocated GPIO id=32 name='P8_35'
[ 10.975124] gpio-of-helper ocp:cape-universal: Allocated GPIO id=33 name='P8_36'
[ 10.982772] gpio-of-helper ocp:cape-universal: Allocated GPIO id=34 name='P8_37'
[ 10.990391] gpio-of-helper ocp:cape-universal: Allocated GPIO id=35 name='P8_38'
[ 10.998040] gpio-of-helper ocp:cape-universal: Allocated GPIO id=36 name='P8_39'
[ 11.005680] gpio-of-helper ocp:cape-universal: Allocated GPIO id=37 name='P8_40'
[ 11.013328] gpio-of-helper ocp:cape-universal: Allocated GPIO id=38 name='P8_41'
[ 11.021100] gpio-of-helper ocp:cape-universal: Allocated GPIO id=39 name='P8_42'
[ 11.028739] gpio-of-helper ocp:cape-universal: Allocated GPIO id=40 name='P8_43'
[ 11.036369] gpio-of-helper ocp:cape-universal: Allocated GPIO id=41 name='P8_44'
[ 11.044011] gpio-of-helper ocp:cape-universal: Allocated GPIO id=42 name='P8_45'
[ 11.051638] gpio-of-helper ocp:cape-universal: Allocated GPIO id=43 name='P8_46'
[ 11.059293] gpio-of-helper ocp:cape-universal: Allocated GPIO id=44 name='P9_11'
[ 11.066936] gpio-of-helper ocp:cape-universal: Allocated GPIO id=45 name='P9_12'
[ 11.074576] gpio-of-helper ocp:cape-universal: Allocated GPIO id=46 name='P9_13'
[ 11.082205] gpio-of-helper ocp:cape-universal: Allocated GPIO id=47 name='P9_14'
[ 11.089822] gpio-of-helper ocp:cape-universal: Allocated GPIO id=48 name='P9_15'
[ 11.097448] gpio-of-helper ocp:cape-universal: Allocated GPIO id=49 name='P9_16'
[ 11.105081] gpio-of-helper ocp:cape-universal: Allocated GPIO id=50 name='P9_17'
[ 11.112705] gpio-of-helper ocp:cape-universal: Allocated GPIO id=51 name='P9_18'
[ 11.120353] gpio-of-helper ocp:cape-universal: Allocated GPIO id=52 name='P9_19'
[ 11.128026] gpio-of-helper ocp:cape-universal: Allocated GPIO id=53 name='P9_20'
[ 11.135678] gpio-of-helper ocp:cape-universal: Allocated GPIO id=54 name='P9_21'
[ 11.143314] gpio-of-helper ocp:cape-universal: Allocated GPIO id=55 name='P9_22'
[ 11.150943] gpio-of-helper ocp:cape-universal: Allocated GPIO id=56 name='P9_23'
[ 11.158576] gpio-of-helper ocp:cape-universal: Allocated GPIO id=57 name='P9_24'
[ 11.166509] gpio-of-helper ocp:cape-universal: Allocated GPIO id=58 name='P9_25'
[ 11.174225] gpio-of-helper ocp:cape-universal: Allocated GPIO id=59 name='P9_26'
[ 11.181898] gpio-of-helper ocp:cape-universal: Allocated GPIO id=60 name='P9_27'
[ 11.189532] gpio-of-helper ocp:cape-universal: Allocated GPIO id=61 name='P9_28'
[ 11.197179] gpio-of-helper ocp:cape-universal: Allocated GPIO id=62 name='P9_29'
[ 11.204817] gpio-of-helper ocp:cape-universal: Allocated GPIO id=63 name='P9_30'
[ 11.212471] gpio-of-helper ocp:cape-universal: Allocated GPIO id=64 name='P9_31'
[ 11.220113] gpio-of-helper ocp:cape-universal: Allocated GPIO id=65 name='P9_41'
[ 11.227747] gpio-of-helper ocp:cape-universal: Allocated GPIO id=66 name='P9_91'
[ 11.235386] gpio-of-helper ocp:cape-universal: Allocated GPIO id=67 name='P9_42'
[ 11.243003] gpio-of-helper ocp:cape-universal: Allocated GPIO id=68 name='P9_92'
[ 11.250462] gpio-of-helper ocp:cape-universal: ready
[ 11.298696] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
[ 11.323994] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[ 11.343047] omap_gpio 44e07000.gpio: Could not set line 6 debounce to 200000 microseconds (-22)
[ 11.353311] sdhci-omap 48060000.mmc: Got CD GPIO
[ 11.358392] sdhci-omap 48060000.mmc: supply vqmmc not found, using dummy regulator
[ 11.395908] mmc0: SDHCI controller on 48060000.mmc [48060000.mmc] using External DMA
[ 11.477482] tda998x 0-0070: found TDA19988
[ 11.485905] tilcdc 4830e000.lcdc: bound 0-0070 (ops 0xc10ac1fc)
[ 11.493347] [drm] Initialized tilcdc 1.0.0 20121205 for 4830e000.lcdc on minor 0
[ 11.501283] tilcdc 4830e000.lcdc: [drm] Cannot find any crtc or sizes
[ 11.509627] of_cfs_init
[ 11.512703] tilcdc 4830e000.lcdc: [drm] Cannot find any crtc or sizes
[ 11.519306] of_cfs_init: OK
[ 11.526177] Freeing unused kernel memory: 1024K
[ 11.531718] Run /init as init process
Loading, please wait...
Starting version 247.3-7+deb11u4
Begin: Loading essential drivers ... done.
Begin: Running /scripts/init-premount ... done.
Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done.
Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems
done.
Begin: Will now check root file system ... fsck from util-linux 2.36.1
[/sbin/fsck.ext4 (1) -- /dev/mmcblk1p1] fsck.ext4 -a -C0 /dev/mmcblk1p1
rootfs: clean, 107053/233392 files, 694336/932864 blocks
done.
[ 21.773212] EXT4-fs (mmcblk1p1): mounted filesystem with ordered data mode. Opts: (null)
done.
Begin: Running /scripts/local-bottom ... done.
Begin: Running /scripts/init-bottom ... done.
Version: [1.20231211.0, e2fsprogs (1.47.0) disable ^metadata_csum,64bit,orphan_file...]
cat /etc/default/beagle-flasher:
#debug_over_display=tty0
source=/dev/mmcblk0
destination=/dev/mmcblk1
rfs_partition=single
rfs_rootfs_type=ext4
rfs_rootfs_startmb=4
bootloader=/opt/u-boot/bb-u-boot-am335x-evm/install-mmcblk1.sh
flash_back=beaglebone-black-emmc-to-microsd
INFO: Giving system time to stablize...
5
4
3
2
1
INFO: Preparing /tmp
INFO: [mount -t tmpfs tmpfs /tmp]
INFO: /proc/cmdline
INFO: [cat /proc/cmdline]
INFO: Preparing sysctl
INFO: [sysctl: vm.min_free_kbytes=[2770]
INFO: [sysctl: setting: [sysctl -w vm.min_free_kbytes=16384]
vm.min_free_kbytes = 16384
INFO: [lsblk -i]
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
mmcblk1 179:0 0 3.6G 0 disk
`-mmcblk1p1 179:1 [ 27.626288] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000200
[ 27.636676] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000200 ]---
0 3.6G 0 part /
mmcblk1boot0 179:256 0 2M 1 disk
mmcblk1boot1 179:512 0 2M 1 disk
INFO: copying [/dev/mmcblk0] -> [/dev/mmcblk1]
ERROR: [source=/dev/mmcblk0] does not exist
Example: /etc/default/beagle-flasher
source=/dev/mmcblk0
Is there a way to recover from here?
