Hi Guyz,
I followed http://wiki.beyondlogic.org/index.php/BeagleBoneBlack_Building_Kernel site and compiled my kernel and uboot and tried tftp boot,
but the kernel is not starting…it is hung and not showing anything…I dont have any clue to proceed…
Please help me in solving this issue
U-Boot 2013.04-dirty (Jun 19 2013 - 09:57:14)
I2C: ready
DRAM: 512 MiB
WARNING: Caches not enabled
NAND: No NAND device found!!!
0 MiB
musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, HB-ISO Rx, HB-ISO Tx, SoftConn)
musb-hdrc: MHDRC RTL version 2.0
musb-hdrc: setup fifo_mode 4
musb-hdrc: 28/31 max ep, 16384/16384 memory
USB Peripheral mode controller at 47401000 using PIO, IRQ 0
USB Host mode controller at 47401800 using PIO, IRQ 0
cpsw, usb_ether
mmc0 is current device
micro SD card found
SD/MMC found on device 0
reading uEnv.txt
1449 bytes read in 4 ms (353.5 KiB/s)
reading /boot/uImage
** Unable to read file /boot/uImage **
U-Boot# bootm 0x81000000
Wrong Image Format for bootm command
ERROR: can’t get kernel image!
U-Boot# setenv serverip 192.168.0.1;setenv ipaddr 192.168.0.100;tftp 0x81000000 uImage
link up on port 0, speed 100, full duplex
Using cpsw device
TFTP from server 192.168.0.1; our IP address is 192.168.0.100
Filename ‘uImage’.
Load address: 0x81000000
Loading: #################################################################
