I’m trying boot beaglebone black from sd card by holding S2 button before power up but not even user led’s were turning on. I’ve attached bootup messages.
U-Boot SPL 2022.04-dirty (Apr 04 2023 - 18:10:15 +0530)
Trying to boot from MMC1
U-Boot 2022.04-dirty (Apr 04 2023 - 18:10:15 +0530)
CPU : AM335X-GP rev 2.1
Model: TI AM335x BeagleBone Black
DRAM: 512 MiB
Core: 149 devices, 14 uclasses, devicetree: separate
WDT: Started wdt@44e35000 with servicing (60s timeout)
NAND: 0 MiB
Loading Environment from FAT... Unable to use mmc 0:1...
<ethaddr> not set. Validating first E-fuse MAC
Net: eth2: ethernet@4a100000, eth3: usb_ether
** Invalid partition 2 **
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
Scanning disk mmc@48060000.blk...
Scanning disk mmc@481d8000.blk...
Found 3 disks
No EFI system partition
BootOrder not defined
EFI boot manager: Cannot load any image
** No partition table - mmc 1 **
Couldn't find partition mmc 1:1
## Error: "bootcmd_nand0" not defined
starting USB...
Bus usb@47401800: Port not available.
USB is stopped. Please issue 'usb start' first.
starting USB...
link up on port 0, speed 100, full duplex
BOOTP broadcast 1
DHCP client bound to address 192.168.11.203 (603 ms)
*** ERROR: `serverip' not set
Cannot autoload with TFTPGET
missing environment variable: pxeuuid
Retrieving file: pxelinux.cfg/01-3c-e4-b0-2b-7c-90
Retrieving file: pxelinux.cfg/C0A80BCB
Retrieving file: pxelinux.cfg/default-arm-am33xx-am335x
Config file not found
starting USB...
BOOTP broadcast 1
DHCP client bound to address 192.168.11.203 (598 ms)
BOOTP broadcast 1
DHCP client bound to address 192.168.11.203 (600 ms)
It is never coming out of these messages and i’ve even connected ethernet to board.
Can you please let us know how to boot from sd card permanently.
Anusha
