Hi Every body,
I’m newbie on BBB and i search sample code & schematic for use NRF24L01+ with my BBB, i try many solution from RPi orums but it doesn’t works.
thanks for your help.
Flagadajones
Hi Every body,
Flagadajones
What do you want to do?
What did you try?
What happened?
I want to make communication between an arduino and a bbb. Both have an nrf24l01+ module.
I have plug a nrf24 to the spi0 on my beaglebone.
and enabled SPI via http://elinux.org/BeagleBone_Black_Enable_SPIDEV
I use then node-nrf module and this script :
var NRF24 = require(‘nrf’),
spiDev = “/dev/spidev1.0”,
cePin = 16, irqPin = 19;
pipes = [0xF0F0F0F0E1, 0xF0F0F0F0D2],
role = ‘ping’;
var nrf = NRF24.connect(spiDev, cePin, irqPin);
//nrf._debug = true;
nrf.channel(0x4c).transmitPower(‘PA_MAX’).dataRate(‘1Mbps’).crcBytes(2).autoRetransmit({count:15, delay:4000}).begin(function () {
nrf.printDetails();
if (role === ‘ping’) {
console.log(“PING out”);
var tx = nrf.openPipe(‘tx’, pipes[0]),
rx = nrf.openPipe(‘rx’, pipes[1]);
rx.pipe(tx);
} else {
console.log(“PONG back”);
var rx = nrf.openPipe(‘rx’, pipes[0]),
tx = nrf.openPipe(‘tx’, pipes[1]);
rx.pipe(tx);
but nothing append on my BBB.
the call of nrf.printDetails() print ll default values and not my configuration result.(.channel(0x4c).transmitPower(‘PA_MAX’).dataRate(‘1Mbps’).crcBytes(2));
cePin is plug on P9_15 and irqPin on P9_16
I’ve solve a part of my problems. my cePin and irq Pin was incorrect.
Now NRF24 is recognize by bbb but i haven’t any communication between arduino and BBB.
My BBB printdetails:
SPI device: /dev/spidev2.0
CE GPIO: 51
IRQ GPIO: 48
STATUS: 0xe RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
RX_ADDR_P0–1: 0xf0f0f0f0e1 0xf0f0f0f0d2
RX_ADDR_P2–5: 0xc3 0xc4 0xc5 0xc6
TX_ADDR: 0xf0f0f0f0e1
RX_PW_P0–5: 0x0 0x0 0x0 0x0 0x0 0x0
EN_AA: 0x3f
EN_RXADDR: 0x03
RF_CH: 0x4c
RF_SETUP: 0x05
CONFIG: 0x03
DYNPD/FEATURE: 0x03 0x07
Data Rate: 1Mbps
Model: nRF24L01+
CRC Length: Disabled
PA Power: PA_HIGH
My Arduino printDetails:
STATUS = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
RX_ADDR_P0-1 = 0xf0f0f0f0d2 0xf0f0f0f0e1
RX_ADDR_P2-5 = 0xc3 0xc4 0xc5 0xc6
TX_ADDR = 0xf0f0f0f0d2
RX_PW_P0-6 = 0x04 0x04 0x00 0x00 0x00 0x00
EN_AA = 0x3f
EN_RXADDR 0x03
RF_CH = 0x4c
RF_SETUP = 0x07
CONFIG = 0x07
DYNPD/FEATURE = 0x00 0x00
Data Rate = 1MBPS
Model = nRF24L01+
CRC Length = Disabled
PA Power = PA_HIGH
can you help me to find where is the problem?
Can you share the code that you used for this project? Thanks
