Please could someone help me, It has taken me weeks to get to this stage.
I have successfully set up a QT Creator development suite and can remote deploy my programs.
Everything works i.e the touch screen and mouse work.
But when I run my programs from a terminal with -qws the mouse doesn’t work,
If I export the paths for the touch screen then it will work.
I have tried to run a script on start up to export the correct paths but still dosent help.
What have I missed?
Andy
I had a similar problem running the QT demo Fingerpaint using the linux frame buffer (-platform linuxfb)
It turned out I did not have permissions to read the /dev/input/event*
Try running the app as root or launch using sudo
If that solves the problem, change the group for /dev/input/event* and add permissions for that group to your user.
Thank you for your help, much appreciated.
Just getting my development platform up and running was a struggle.
Could any of you help me with a QT program to display the temperature from a
BMP085? My c++ skills are my shortfall. How ever I have been making simple gui’s.
Andy
