I have two Rev B beaglebone blacks. One I never used since I bought it. I recently ordered a Rev C to use for my project but I thought I might as well try to make some use the one I have never used. I wanted to put Debian 7.5 on the device so it would be similar to the one I will get in a couple of days.
I first booted the device with the factory installed Angstrom distribution. It worked well.
I then downloaded the image from http://beagleboard.org/latest-images
I downloaded
Older Debian images
BeagleBone Black (eMMC flasher)
Debian 7.5 (BeagleBone Black - 2GB eMMC) 2014-05-14 - more info - bittorrent - md5: 74615fb680af8f252c034d3807c9b4ae
I put the image on a microSd card, held the boot button down until it started to echo info to the display
It booted and the screen showed in red letters that it was a temporary installation and I needed to flash to the eMMC. I used the terminal program and it seemed to work. I didn’t have time to flash it so I shut it down.
A couple of hours later I went back to try it again and it would not boot the original Angstrom, the blue led’s all stay on and nothing happens. If I try to load the Debian image I get 3 lines on the display that I will post next.
[25.132791] libphy: PHY 4a101000.mdio:01 not found
[25.137954] net etho: phy 4a101000.mdio.01 not found on slave 1
[28.305991] tilcdc 4830e000.fb: timeout waiting framedone
Then it waits a period and seems go go to neverlnd. The display responds that it has lost its signal.
Any help would be useful.
Useful responses might be something like:
Sorry dude, your device is now bricked.
or
Maybe you can get better response here
or
Advice on how to reset the device or something.
Thank you
days.
It worked well.
I then downloaded the image from Latest Software Images - BeagleBoard
I downloaded
Older Debian images
and it seemed to work. I didn't have time to flash it so I shut it down.
You shutdown mid flash... So it never completed the eMMC install, so
yeah, you have to reflash now...
Here is the latest "stable" 7.x-wheezy/3.8 kernel/2GB:
http://elinux.org/Beagleboard:BeagleBoneBlack_Debian#BBB.2FBBG_.28All_Revs.29_eMMC_Flashers
btw, we nuked this method, now you users don't get a temp session to
play around anymore, everyone has to wait and watch the flashing
process
the original Angstrom, the blue led's all stay on and nothing happens. If I
next.
or
or
days.
It worked well.
I downloaded
Older Debian images
You shutdown mid flash… So it never completed the eMMC install, so
yeah, you have to reflash now…
Here is the latest “stable” 7.x-wheezy/3.8 kernel/2GB:
btw, we nuked this method, now you users don’t get a temp session to
process
This is great, I really appreciate your help.
I wish I had known that it was flashing. Some link sent me to this page:
http://elinux.org/Beagleboard:BeagleBoneBlack_Debian#Flashing_eMMC
which told me I had to edit a file and reflash.
To setup the standalone microSD image to automatically flash the eMMC on powerup.In /boot/uEnv.txt:
##enable BBB: eMMC Flasher:
cmdline=init=/opt/scripts/tools/eMMC/init-eMMC-flasher-v3.sh
If this is no longer valid is there something I can do to modify the page?
I would ask Jason Kridner to make the codification.
Beagleboard:BeagleBoneBlack Debian - eLinux.org
That's "only" for images without the words "eMMC-flasher" in the file name..
