When you checked your router and saw the address, was it within a day of setting the static address?
It is possible that your router was showing the address as it still had a valid lease.
Does it still show up ? If so can you release it, and try rebooting the BB
It is also possible that u-boot may be grabbing an IP address, but that would depend on how it was configured.
I’ve never had to ‘wait’, but then, I’m not router expert. On the other hand, the latest images use connman. Read here, go down to Set the BBB to use a static ip.
Hi Benedict,
I guess the easiest way to confirm is to see if you can ping the BBB at that IP. I broke it by trying to edit interfaces. I did have to put the original file back to get it to work with connman.
Best, Dan.
thanks guys
the lakeweb link looks like good info but…I have an early 2gb BBB and it’s running debian 7.5.
I have waited a good long time(nearly 2 days) and just rebooted the router. The BBB comes up with the dhcp address that the router first assigned many days ago…and the same address it always assigns when I reboot the router.
I pinged the static address after router reboot and got no response. I pinged the address that showed on the network(the same address that the router first assigned bu dhcp and the address that appears every time I reboot the router) and got 3ms.
It fits with a little room to spare. This image also updates u-boot when you flash to the eMMC, which is a nice perk since there are many improvements since that 2GB debian 7.5 image was made!
You will note that on the later BBB images network configuration is done by conman, so /etc/network/interfaces is the wrong file to edit. (I don’t recall if conman was in the 7.5 image.)
If you want instructions on how to revert to /etc/network/interfaces from conman or how to boot larger images on the RevB using NFS, see this article I wrote about it:
