Nope, files are still missing… With the wiki page is written, you should see…
Press SPACE to abort autoboot in 0 seconds
board_name=[A335BNLT] ...
board_rev=[00C0] ...
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
Couldn't find partition 0:2 0x82000000
Can't set block device
Scanning mmc 0:1...
Scanning disk mmc@48060000.blk...
Scanning disk mmc@481d8000.blk...
Found 3 disks
No EFI system partition
BootOrder not defined
EFI boot manager: Cannot load any image
Checking for: /uEnv.txt ...
Checking for: /boot/uEnv.txt ...
1713 bytes read in 3 ms (557.6 KiB/s)
Checking if uname_r is set in /boot/uEnv.txt...
Running uname_boot ...
So let’s start with some basdic’s in u-boot…
Run with these 3 commands and compare, as this validate, that you correctly formatted the microSD, copied the rootfs and kernel, along with setup /boot/uEnv.txt…
=> mmc dev 0
=> ls mmc 0:1
=> ls mmc 0:1 /boot/
=> mmc dev 0
=> ls mmc 0:1
<DIR> 4096 .
<DIR> 4096 ..
<DIR> 16384 lost+found
53 ID.txt
<DIR> 4096 proc
<DIR> 4096 bin
<DIR> 4096 mnt
<DIR> 4096 dev
<DIR> 4096 run
<DIR> 4096 root
<DIR> 4096 sys
<DIR> 4096 opt
<DIR> 4096 var
<DIR> 4096 lib
<DIR> 4096 sbin
<DIR> 4096 home
<DIR> 4096 boot
<DIR> 4096 etc
<DIR> 4096 usr
<DIR> 4096 tmp
<DIR> 4096 media
<DIR> 4096 srv
<DIR> 4096 .
<DIR> 4096 ..
<DIR> 4096 dtbs
4753383 System.map-5.10.131-ti-r49
10506752 vmlinuz-5.10.131-ti-r49
7505948 initrd.img-5.10.131-ti-r49
190593 config-5.10.131-ti-r49
1713 uEnv.txt
542 SOC.sh
<DIR> 4096 uboot
