Okay, from your dump, U-Boot has been successfully built, installed and loaded… So your original issue is now resolved…
So, next… Did you partition the microSD for the rootfs, build and install your chosen kernel? (Or what Rootfs and kernel combination where you planning?)
Okay it’s a good news
For the kernel not yet. My first goal it’s to boot with u-boot. It’s why I’m a little bit surprise to boot on the emmc kernel. Can I wipe the emmc and/or choose to boot on the sd card ?
Yeap, you can safely erase the eMMC. The production version of u-boot will search both microSD and eMMC… As you can see, it found the /boot/uEnv.txt trigger file on the eMMC and booted the eMMC as directed…
thank you very much. Sorry for the dummies questions but I’ve a last one
I built the kernel according your tutorial but it’s says:
U-Boot SPL 2022.04 (Sep 20 2022 - 14:54:58 +0200)
Trying to boot from MMC1
U-Boot 2022.04 (Sep 20 2022 - 14:54:58 +0200)
CPU : AM335X-GP rev 2.1
Model: TI AM335x BeagleBone Black
DRAM: 512 MiB
Core: 150 devices, 14 uclasses, devicetree: separate
WDT: Started wdt@44e35000 with servicing (60s timeout)
NAND: 0 MiB
Loading Environment from FAT... Unable to use mmc 0:1...
<ethaddr> not set. Validating first E-fuse MAC
Net: eth2: ethernet@4a100000, eth3: usb_ether
** Invalid partition 2 **
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
Scanning disk mmc@48060000.blk...
Scanning disk mmc@481d8000.blk...
Found 4 disks
No EFI system partition
BootOrder not defined
EFI boot manager: Cannot load any image
Scanning mmc 1:1...
## Error: "bootcmd_nand0" not defined
starting USB...
Bus usb@47401800: Port not available.
USB is stopped. Please issue 'usb start' first.
starting USB...
link up on port 0, speed 100, full duplex
BOOTP broadcast 1
DHCP client bound to address 192.168.6.127 (308 ms)
*** ERROR: `serverip' not set
Cannot autoload with TFTPGET
missing environment variable: pxeuuid
Retrieving file: pxelinux.cfg/01-3c-e4-b0-06-9d-3e
Retrieving file: pxelinux.cfg/C0A8067F
Retrieving file: pxelinux.cfg/default-arm-am33xx-am335x
Config file not found
starting USB...
BOOTP broadcast 1
DHCP client bound to address 192.168.6.127 (2736 ms)
BOOTP broadcast 1
DHCP client bound to address 192.168.6.127 (1009 ms)
Based on your log, everything is fine, it’s going thru all the boot options, before dropping to the final dhcp/pxe boot… It looks like you didn’t copy the rootfs, kernel files, and /boot/uEnv.txt…
It’s odd, I copy everything. I’ve all linux directories, the vmlinuz-5.4.209-bone65 and the /boot/uEnv.txt. Is it possible the issue come from the fstab ??
I’ve something like that
DRAM: 512 MiB
NAND: 0 MiB
Scanning mmc 0:1...
Found 3 disks
** No partition table - mmc 1 **
Couldn't find partition mmc 1:1
starting USB...
starting USB...
BOOTP broadcast 1
BOOTP broadcast 2
DHCP client bound to address 192.168.6.127 (804 ms)
starting USB...
BOOTP broadcast 1
DHCP client bound to address 192.168.6.127 (500 ms)
BOOTP broadcast 1
DHCP client bound to address 192.168.6.127 (489 ms)
