Hello
I have finally managed to get my hands on an BBB and started to try and get my system up and running the way I need by building a kernel (3.14.1).
I am attempting to use the USB client port (USB0) in host mode and think I have done all the things necessary to get this working:
Kernel config has EHCI enabled and set to host only
Hardware mod on the board to short pins 4&5 of micro socket to force USB-ID low to indicate host mode.
Changed the arch/arm/boot/dts/am335x-bone-common.dtsi file to put it into host mode usb@47401000 {
status = “okay”;
dr_mode = “host”;
}; usb@47401800 {
status = “okay”;
dr_mode = “host”;
No matter what I plug in nothing gets identified ???
Plugging into the USB1 host port is fine so the kernel is configured correctly.
Boot log shows ports being identified:
[ 2.057294] musb-hdrc musb-hdrc.0.auto: MUSB HDRC host driver
[ 2.063996] musb-hdrc musb-hdrc.0.auto: new USB bus registered, assigned bus number 1
[ 2.072673] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.079868] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.087467] usb usb1: Product: MUSB HDRC host driver
[ 2.092722] usb usb1: Manufacturer: Linux 3.14.1 musb-hcd
[ 2.098402] usb usb1: SerialNumber: musb-hdrc.0.auto
[ 2.104856] hub 1-0:1.0: USB hub found
[ 2.108880] hub 1-0:1.0: 1 port detected
[ 2.117574] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 2.124275] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 2
[ 2.133045] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.140253] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.147851] usb usb2: Product: MUSB HDRC host driver
[ 2.153105] usb usb2: Manufacturer: Linux 3.14.1 musb-hcd
[ 2.158786] usb usb2: SerialNumber: musb-hdrc.1.auto
[ 2.165268] hub 2-0:1.0: USB hub found
[ 2.169312] hub 2-0:1.0: 1 port detected
After looking at the circuit diagram I see that there is no 5V supply to the USB port for the mini USB connector. I know that this is normally for a host to supply and power the beagle via but I am plugging in a device to BE powered.
So the solution is to divert power from the 5V DC jack to the USB_DC rail.
This can be done near the TPMS chip by connecting the 5V side of C2 to the USB_DC side of C1. That will do 2 things ;
1 supply 5V to the USB connection
2 indicate to the AM335x that there is volts on the port so it can wake up and operate.
Also shorting pins 4&5 of the mini USB socket forces the port into Host mode.
Thanks Marc, these few lines are very useful since I need 2 USB hosts and don’t want to add a USB hub. About the supply, maybe adding inductor filters like on USB1 schematic would be better.
Hi Vince
Thanks for the suggestion. Issue was solved long ago but I didn’t update the post. But you are right with the use of inductors and you also need to change the mode selection to out the port into host mode.
I am also working with a Clone of BBB. In which I need to Convert USB0 as Host. I need to use both the USB0 and USB1 has Host. Kindly, suggest. How to Convert the USB0 Port to Host.
Thanks for the quick reply. I had followed the same schematics as BBB. The USB1 is working has HOST. I have Grounded USB1_ID and I have used USB1_DRVVBUS to drive the 5V and USB1_VBUS for sensing. But, USB0 is not working. I have Grounded USB0_ID and I have not Used USB0_DRVBUS. But I have connected USB0_VBUS to Permanent 5V.
The USB0 is not able to detect any device when plugged in.
I am trying to acheive a similar goal here. I want to change my USB0 to host and USB1 to device. I tried to make this change in arch/arm/boot/dts/am335x-bone-
common.dtsi file but the file structure has changed significantly. It is now having :
" &usb_otg_hs {
interface_type = <1>;
power = <250>;
status = “okay”;
}; " instead of what is posted in your querry.
Also the am33xx.dtsi file is changed in the usb part as:
" &usb_otg_hs {
power = <250>;
status = “okay”;
}; " instead of what is posted in the original querry.
