more info on these issues :
- Tried using 2.5A 5V power supply - same issues
- Flashed image using DiskImager after formating the SD card as suggested by some, still same issues.
- Tried booting with the SD card with latest Arngstrom image, still same.
Here are few screen dumps while normal booting from eMMC and while flashing :
Screendump during normal booting from eMMC :
U-Boot SPL 2013.04-dirty (Jul 10 2013 - 14:02:53)
musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, HB-ISO Rx, HB-ISO Tx, SoftConn)
musb-hdrc: MHDRC RTL version 2.0
musb-hdrc: setup fifo_mode 4
musb-hdrc: 28/31 max ep, 16384/16384 memory
USB Peripheral mode controller at 47401000 using PIO, IRQ 0
USB Host mode controller at 47401800 using PIO, IRQ 0
OMAP SD/MMC: 0
mmc_send_cmd : timeout: No status update
reading u-boot.img
reading u-boot.img
U-Boot 2013.04-dirty (Jul 10 2013 - 14:02:53)
I2C: ready
DRAM: 512 MiB
WARNING: Caches not enabled
NAND: No NAND device found!!!
0 MiB
cpsw, usb_ether
Card did not respond to voltage select!
mmc0(part 0) is current device
No micro SD card found, setting mmcdev to 1
SD/MMC found on device 1
reading uEnv.txt
26 bytes read in 3 ms (7.8 KiB/s)
4385024 bytes read in 764 ms (5.5 MiB/s)
24808 bytes read in 51 ms (474.6 KiB/s)
Booting from mmc …
Booting kernel from Legacy Image at 80007fc0 …
Image Name: Angstrom/3.8.13/beaglebone
Data Size: 4384960 Bytes = 4.2 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum … OK
Flattened Device Tree blob at 80f80000
Booting using the fdt blob at 0x80f80000
XIP Kernel Image … OK
OK
Using Device Tree in place at 80f80000, end 80f890e7
Starting kernel …
[ 0.196290] omap2_mbox_probe: platform not supported
[ 0.206854] tps65217-bl tps65217-bl: no platform data provided
[ 0.283428] bone-capemgr bone_capemgr.8: slot #0: No cape found
[ 0.320535] bone-capemgr bone_capemgr.8: slot #1: No cape found
[ 0.357643] bone-capemgr bone_capemgr.8: slot #2: No cape found
[ 0.394752] bone-capemgr bone_capemgr.8: slot #3: No cape found
[ 0.414475] bone-capemgr bone_capemgr.8: slot #6: BB-BONELT-HDMIN conflict P8.45 (#5:BB-BONELT-HDMI)
[ 0.424084] bone-capemgr bone_capemgr.8: slot #6: Failed verification
[ 0.444520] omap_hsmmc mmc.4: of_parse_phandle_with_args of ‘reset’ failed
[ 0.451814] bone-capemgr bone_capemgr.8: loader: failed to load slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 0.518300] pinctrl-single 44e10800.pinmux: pin 44e10854 already requested by 44e10800.pinmux; cannot claim for gpio-leds.7
[ 0.530038] pinctrl-single 44e10800.pinmux: pin-21 (gpio-leds.7) status -22
[ 0.537365] pinctrl-single 44e10800.pinmux: could not request pin 21 on device pinctrl-single
[ 10.028611] g_multi: ' invalid for parameter
C5’
systemd-fsck[86]: Angstrom: clean, 49262/112672 files, 275502/449820 blocks
[ 11.098934] libphy: PHY 4a101000.mdio:01 not found
[ 11.104027] net eth0: phy 4a101000.mdio:01 not found on slave 1
.—O—.
.-. o o
__ | —'| ‘–.| .-’| | |
The Angstrom Distribution beaglebone ttyO0
Angstrom v2012.12 - Kernel 3.8.13
beaglebone login:
