Ok, maybe I shouldn’t have but I bough t a BBB wireless on ebay. I have it up and running but I see no wlan0 interface but I do see an eth0. Could someone have changed the eprom so this board thinks it is a regular BBB?
version.sh shows this:
eprom:[A335BNLTO
dogtag:[BeagleBoard.org Debian Image 2019-08-03
Any help would be appreciated.
GND TP1 and run this "one" line command:
sudo dd if=/opt/scripts/device/bone/bbbw-eeprom.dump
of=/sys/devices/platform/ocp/44e0b000.i2c/i2c-0/0-0050/eeprom
^that's "one" line...
then run:
sudo /opt/scripts/tools/version.sh | grep eeprom
Thank you Robert, I hope you receive this, as I must admit I’m having issues with the forums and can’t seem to find where my post is located there.
After much searching, I was able to get the board functional using an overlay but would very much prefer to set it so that the it detects the correct configuration by default.
I used this in the uEnv.txt file.
enable_uboot_overlays=1
dtb_overlay=/lib/firmware/BB-BBBW-WL1835-00A0.dtbo
Do you know how I can get it to detect the board as above without having to use the overlay?
Thank you again.
Thank you Robert, I hope you receive this, as I must admit I'm having issues with the forums and can't seem to find where my post is located there.
First post are blocked due to spam.. The admin was traveling.....
This should fix it back to the correct stock setting:
then run:
I may have mistakenly assumed those commands you provided were to view what was in eeprom and not change it. I will run those commands as soon as I can. Sorry for the misunderstanding.
Here is the output, is this what was expected?
fpp@FPP:~$ sudo dd if=/opt/scripts/device/bone/bbbw-eeprom.dump of=/sys/devices/platform/ocp/44e0b000.i2c/i2c-0/0-0050/eeprom
0+1 records in
0+1 records out
28 bytes copied, 0.0054809 s, 5.1 kB/s
fpp@FPP:~$ sudo /opt/scripts/tools/version.sh | grep eeprom
Binary file (standard input) matches
Double check your gnd wire, eeprom has a write protect.. i forget
where TP1 is located, but it should be labeled and you tie a gnd wire
from the header to it..
You can reboot, but if it fails to boot, you can use this special
blank image that'll boot any blank eeprom board:
https://rcn-ee.net/rootfs/bb.org/testing/2019-10-21/stretch-iot/BBBL-blank-debian-9.11-iot-armhf-2019-10-21-4gb.img.xz
Is this better?
0+1 records in
0+1 records out
28 bytes copied, 0.132348 s, 0.2 kB/s
eeprom:[A335BNLTBWA50000BBWG*]
Yeap! that's what we want to see, it should be perfect now..
Thank you very much for your help, now time to start learning.
