BBB-Wireless Upgrade to Bullseye
Let me know if you want me to move this to its own thread.
I ran into a problem corrupting the eemc on BBB-Wireless working through upgrading to blaster.
I updated /etc/apt/sources.list as recommended above, then apt update → apt upgrade.
I input yes to the 2 questions asking if I wanted to update to the new distribution files. Everything seemed fine.
I then ran apt autoremove which was recommended earlier in the upgrade process and the BBB froze up.
Upon restart the power, WL & BT leds came on, but nothing on the USR leds.
I backed up & reinstalled the 4.19.94-ti-r42 flasher image and that restored everything, but upon trying to update and upgrade that with latest buster I get the corruption again. During the upgrade using cloud9 I am getting an error “Failed to write state settings” flshing quickly and disappearing.
After the update the system does start, but the USR leds are dead.
I redid the whole process using VScode remote explorer. Nothing on problems screen, nothing on output.
Upon reboot the USR leds are not functioning. Update doesn’t produce anything upgradable except c9-core-installer which doesn’t get upgraded.
I went on and updated /opt/script/tools and updated the kernel to 4.19.94-ti-r64
You can see problems with LEDs related to pinctrl in the version output shown in the uname_dogtag_version.txt uploaded file which is taken after updating, upgrading, and upgrading kernel.
Did I break it? Is there something I can do to fix it?
Any suggestions would be welcomed.
Much Thanks,
Pat
uname_dogtag_version.txt (4.2 KB)
scripts_kernelupdate terminal screen.txt (10.0 KB)
update_upgrade terminal screen.txt (82.9 KB)
Hi @Patrick_Bolton did you do this on the 4GB eMMC?
What corruption are you seeing? i don’t see anything in the logs…
cloud9 is eol, there will not be a bullseye build…
I am just not seeing the usr leds working at all. On other posts this was indicated as a corruption problem. Perhaps I jumped the gun on that conclusion.
The board is booting and accessible the usr leds are all off and not their usual functions.
I can use vscode instead of cloud9. I did use cloud9 initially.
Best, Pat
Oh, looks like an mixup between kernel and overlays:
dmesg | grep pinctrl-single
[    0.954676] pinctrl-single 44e10800.pinmux: 142 pins, size 568
[    1.370693] pinctrl-single 44e10800.pinmux: pin PIN74 already requested by 481a6000.serial; cannot claim for leds
[    1.381151] pinctrl-single 44e10800.pinmux: pin-74 (leds) status -22
[    1.387583] pinctrl-single 44e10800.pinmux: could not request pin 74 (PIN74) from group pinmux_bt_pins  on device pinctrl-single
[    1.535784] pinctrl-single 44e10800.pinmux: pin PIN108 already requested by ocp:A15_pinmux; cannot claim for 0-0070
[    1.546340] pinctrl-single 44e10800.pinmux: pin-108 (0-0070) status -22
[    1.553016] pinctrl-single 44e10800.pinmux: could not request pin 108 (PIN108) from group nxp_hdmi_bonelt_pins  on device pinctrl-single
It’s looking for A15 pinmux, we need to just remove that pin… it needs to be set, but not set by any overlay…
Hi robert,
Is it fixed ? I have same issue on my BBBW. Or, Is there any solution ?
I encountered the same problem, put me on a wrong footing. I though the BBBW had died. After connecting a TTL-USB cable to the serial console I found the same error.
Would be nice to find out how to fix this. Is it kernel stuff, or should we do something else?
Kind Regards,
Johan
it was a kernel and overlay mixup…
On bullsye please run:
sudo beagle-version
and report what it output’s for debugging…
eeprom:[A335BNLTBWA51712EW005268]
model:[TI_AM335x_BeagleBone_Black_Wireless]
dogtag:[BeagleBoard.org Debian Buster IoT Image 2020-04-06]
bootloader:[microSD-(push-button)]:[/dev/mmcblk0]:[U-Boot SPL 2019.04-00002-g07d5700e21 (Mar 06 2020 - 11:24:55 -0600)]:[location: dd MBR]
bootloader:[microSD-(push-button)]:[/dev/mmcblk0]:[U-Boot 2019.04-00002-g07d5700e21]:[location: dd MBR]
UBOOT: Booted Device-Tree:[am335x-boneblack-uboot-univ.dts]
UBOOT: Loaded Overlay:[AM335X-PRU-RPROC-4-19-TI-00A0]
UBOOT: Loaded Overlay:[BB-BBBW-WL1835-00A0.bb.org-overlays]
UBOOT: Loaded Overlay:[BB-BONE-eMMC1-01-00A0.bb.org-overlays]
kernel:[4.19.94-ti-rt-r68]
/boot/uEnv.txt Settings:
uboot_overlay_options:[disable_uboot_overlay_video=1]
uboot_overlay_options:[disable_uboot_overlay_audio=1]
uboot_overlay_options:[disable_uboot_overlay_adc=1]
uboot_overlay_options:[uboot_overlay_pru=/lib/firmware/AM335X-PRU-RPROC-4-19-TI-00A0.dtbo]
pkg check: to individually upgrade run: [sudo apt install --only-upgrade <pkg>]
pkg:[bb-cape-overlays]:[4.14.20210821.0-0~buster+20210821]
pkg:[bb-customizations]:[1.20211201.1-0~buster+20211201]
pkg:[bb-usb-gadgets]:[1.20211012.0-0~buster+20211012]
pkg:[bb-wl18xx-firmware]:[1.20210922.2-0~buster+20211007]
pkg:[kmod]:[26-1]
pkg:[librobotcontrol]:[1.0.5-git20200715.0-0~buster+20200716]
pkg:[firmware-ti-connectivity]:[20190717-2rcnee1~buster+20200305]
groups:[debian : debian adm kmem dialout cdrom floppy audio dip video plugdev users systemd-journal bluetooth netdev i2c gpio pwm eqep remoteproc admin spi iio docker tisdk weston-launch xenomai cloud9ide]
cmdline:[console=ttyO0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 quiet]
dmesg | grep remote
[   11.946497] remoteproc remoteproc0: 4a334000.pru is available
[   11.950282] remoteproc remoteproc1: 4a338000.pru is available
[   36.458758] Bluetooth: hci0: change remote baud rate command in firmware
[   43.412553] remoteproc remoteproc2: wkup_m3 is available
[   43.428661] remoteproc remoteproc2: powering up wkup_m3
[   43.428686] remoteproc remoteproc2: Booting fw image am335x-pm-firmware.elf, size 217148
[   43.428955] remoteproc remoteproc2: remote processor wkup_m3 is now up
dmesg | grep pru
[   11.946684] pru-rproc 4a334000.pru: PRU rproc node pru@4a334000 probed successfully
[   11.950542] pru-rproc 4a338000.pru: PRU rproc node pru@4a338000 probed successfully
[    1.119015] pinctrl-single 44e10800.pinmux: 142 pins, size 568
[    1.636580] pinctrl-single 44e10800.pinmux: pin PIN74 already requested by 481a6000.serial; cannot claim for leds
[    1.647067] pinctrl-single 44e10800.pinmux: pin-74 (leds) status -22
[    1.653466] pinctrl-single 44e10800.pinmux: could not request pin 74 (PIN74) from group pinmux_bt_pins  on device pinctrl-single
dmesg | grep gpio-of-helper
[    1.137901] gpio-of-helper ocp:cape-universal: ready
lsusb
Bus 001 Device 003: ID 0b95:772b ASIX Electronics Corp. AX88772B
END
Oops. was Buster.
Still, beagle-version was available.
sudo apt update
sudo apt install bb-u-boot-am335x-evm
sudo /opt/u-boot/bb-u-boot-am335x-evm/install.sh
sudo reboot
Thanks, that worked!
Kind Regards,
Johan
